Thread Tools |
Rating:
Display Modes |
Re: Hovercraft
I think a pure hovercraft would be a silly idea. Throwing away the traction that you ARE allowed from your wheels and opting instead for an even harder to implement and control drive system doesn't seem like the right idea.
However, using a fan to augment your acceleration and deceleration might work. The wheels can only give you a maximum of about 26.7N of acceleration1 force. If you build a fan that's good for a few newtons of thrust2, then that can be a substantial increase in your robots straight-line handling, allowing you to outrun someone intent on dropping rocks in your trailer (and maybe even causing a bit of aerodynamic drag against them). 1: Maximum mass of robot: 54.54kg. Weight = 54.54 * 9.81 = 535N. Maximum traction: ff = uFn -> ff = 0.05 * 535N = 26.7N 2I know nothing about fans. This may very well be outside of the possibilities for a 12V fan, but it would be worth running numbers on. Last edited by Bongle : 03-01-2009 at 18:24. |
Re: Hovercraft
A $2600USD model aircraft jet engine puts out 59N: http://www.trimair.com.au/index2.html. However, it is petrol powered and obviously illegal. A $740 set of ducted fan components can put out 13-15lbs of thrust (57.9N), but uses a minimum of 3200 watts, which is 6.6 times how much power a FIRST robot can use. |
Re: Hovercraft
to keep going:
Thrust = mass flow * velocity Power = (1/2) mass flow * velocity^2 For a given thrust, we could pick any combination of mass flow and velocity, but to minimize energy used, we want greater mass flow and less velocity. max power for a single FIRST motor is 480 watts (12V * 40A). call it 500W for round numbers. So for 50 N you could do, for example, 2.5 kg/s air at 20 m/s. Now, to put this in perspective, 20 m/s = 44 mph. Seems a little high to me, but maybe not out of the question. Probably you wouldn't get anything faster than this. Now put 2.5 kg/s of air in perspective. That's 5.5 lb/s. Since a cubic foot of air has a mass of ~0.075 lb at standard temp and pressure, we need 73 ft^3/s. That's 4406 ft^3/min (scfm). That's a rather large number. Maybe not totally out of the question though. So, unless I messed up the math, I'd guess that 50N of thrust could be achievable without violating the laws of physics or any FIRST rules, but I don't think it would be cheap or easy... Quote:
Re: Hovercraft
Now, how big would the swept area on this hypothetical fan be? You've got a column of air 18.5 meters long (for my calcs) long passing through through every second, that contains 2.7kg of air, which is 2.11 cubic meters. V = pi * r * r * h 2.11 = pi * r * r * 18.5 sqrt(2.11 / (18.5 * pi)) = r 0.19 = r = 19cm radius fan, or 7.5 inches. That's a pretty big fan, but not unusably big. This could be do-able, but the speed out the back and the CFM rating seems pretty insane. I searched for 4000CFM fans, and came up with stuff sold as "whole house fans", and I doubt that those would put out the kind of velocities needed. Is this a correct calculation? Last edited by Bongle : 03-01-2009 at 19:50. |
Re: Hovercraft
Don't want to get into all the math, I don't really remember it, but from fooling around with a human-carrying hovercraft a few years ago I have a couple of things for you to consider:
First: You have to be careful with the center of mass when using a hovercraft- any manipulators carrying over the curtains will tip it. Tipping makes the air curtain hit the ground (a rule violation) and will make your 'craft drift because of the uneven airflow. And second: Yes a hovercraft will float the 120 lbs of robot. It will do so for awhile too. I remember using two car fans and the same 12 volt batteries we use now to carry myself as well as the weight of the actual craft and batteries (probably a little over 120 back in the day) |
Re: Hovercraft
O.k. Being less far-fetched, from this I've gotten that using fan(s) to boost a drive trains output is possible but to cut out the drive completely is just stupid (or not prudent).
The hovercraft would have been sweet though. Oh well ![]() |
#7
Re: Hovercraft
I did the math a little differently and got 7.2 inches for the radius. Probably a round-off difference between you and me. If anyone was seriously considering this, it would probably be better to make the fan bigger, thus it could run slower.
Re: Hovercraft
I made an excel sheet to play with these numbers: If you had a fan with a radius just wide enough to fit on the short length of your robot (35cm), you'd only need an output velocity of 3.1m/s for a 5 newton boost. It would only require 7.8 watts. For a 10N boost with the same fan, you need a 4.5m/s output. However, since a lot of that boost would get caught on the trailer (thus slowing you down), you'd need more. Edit: But it occurs to me that a giant fan would pose an entanglement risk, and so probably isn't practical, if QA allows it at all. Last edited by Bongle : 03-01-2009 at 22:55. |
#9
Re: Hovercraft
Just for arguments sake, remember robots actually weigh about 150 pounds. The 120 base that passes inspection, plus a 13 poundish battery, plus 15 pounds of battery.
Also, can you provide some documentation about motor outputs? I though CIMs output about 300 watts. ![]() |
#10
Re: Hovercraft
I don't know the specs for the individual motors, it is possible that 480 watts through one of the kit motors is impossible. |
#11
Re: Hovercraft
This might sound stupid but where would you go looking for fans / propellers? And what kind of gearing would get a CIM to spin the most efficient.
EDIT: Talking about using this to give a drive a little boost not to push an entire bot around. |
#12
Re: Hovercraft
I think it would be worth your time putting a standard house fan on a physics cart and use a spring scale to see how much force it generates. Then you could maybe replace the house fan motor with a CIM and speed it up a bit. Again, I note that you probably don't want to invest too time or money in this idea unless QA says it is legal. Their "only traction must come from rover wheels" rule could potentially be interpreted (FIRST has reached pretty far in their rule interpretations in the past) that you can't get thrust from fans either. |
#13
Re: Hovercraft
You're right, max output of a CIM is somewhere in the 300 W range. For these back of the envelope calcs, I was assuming 100% efficiency in the CIM motor (and in the gearbox, and in the fan). 12V * 40A = 480W is the maximum input to the motor. It's not 100% efficient. But, you could always use two of them put together if you wanted to...
Re: Hovercraft
This question has been vexing me as well. My good friend (http://en.wikipedia.org/wiki/Propeller) tells me that propellers max out around 80% efficiency. I'm afraid that we won't get anywhere near an optimum prop, so let's assume 10% efficiency with 300W of CIM, yielding 30 W. When your robot is moving at 2 m/s, 30 W should translate to 15 N, about 3 lbs. If you power your fan or fans with 2 CIMS, you get 6 lbs of thrust, which would make a nice adder to the 7.5 lbs you get from traction.
Now, if someone who knew what they were doing made the prop a mere 30% efficient, then they would have an additional 18lbs of thrust; enough to push anyone around. Unfortunately, I have no idea where you would purchase or how you would design this propeller. There are some big RC planes out there, but I can't find much information on thrust produced or efficiency. Anybody have any leads? |
#15
Re: Hovercraft
I think everybody's best bet as of now would just be to check out some hobby shops to get a look at propellers used for RC planes, copters, airboats or anything similar.
| pic: Hovercraft cart | ChristinaR | Extra Discussion | 41 | 09-04-2008 02:24 |
| Hovercraft? | jennpeeler | Rules/Strategy | 19 | 25-10-2006 19:46 |
| Hovercraft | edomus | General Forum | 24 | 02-06-2005 21:00 |
| pic: Hovercraft | edomus | Extra Discussion | 11 | 01-06-2005 11:55 |
