Go to Post FIRST encourages us to innovate and try new things, lets do the same for them. - Katie_UPS [more]
Unread 03-01-2009, 18:23
smartkid's Avatar
smartkid smartkid is offline
Boom!
AKA: Cody Smith
FRC #1902 (Exploding Bacon)
smartkid has a spectacular aura aboutsmartkid has a spectacular aura about
Re: Hovercraft
Originally Posted by dtengineering View Post
But perhaps, if you take the hovercraft idea and run it in reverse, you might come up with an idea to give you an edge. Let's just say... what if your hovercraft.... sucks?
I personally also brought that idea to the table, before the idea of a hovercraft. But after reading R06 a few times a vacuum under the bot would be considered a "traction device" would it not?
Unread 03-01-2009, 18:44
dtengineering's Avatar
AKA: Jason Brett
Re: Hovercraft
I'd tend to think of it as a "normal force increasing device". Technically the vacuum would not provide any traction... it would merely increase the force acting on the wheels allowing them to provide enhanced traction.
I believe the Q&A needs to answer this one, though,
Jason
Unread 03-01-2009, 18:48
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: Hovercraft
F1 buffs will get this one.
EDIT: Hmm, where did the picture go? Err, anyway...
en.wikipedia.org/wiki/Brabham_BT46B
Does anyone else remember when TBA signatures actually worked?
Unread 06-01-2009, 10:22
gregscott gregscott is offline
gregscott is an unknown quantity at this point
Re: Hovercraft
Actually, the first to use the fan concept was Jim Hall with his Chaparral 2J in 1970. Jim was a great innovator and most of the aerodynamic ideas used in racing today originate with him. His most successful from a winning standpoint was the 2E which used a moveable wing to provide downforce in corners but which could be leveled on the straights to provide minimal drag.
As usually happens, his ideas were proved so effective that they were outlawed after 1 or 2 seasons.
One of the things that happens in racing is that if you come up with a really brilliant idea, someone will try to ban it in the name of "level competition". As you write the rules tighter and tighter, there becomes less and less possibility for really great leaps of creativity...just think of NASCAR.
I worry that FIRST is going in that direction.
Unread 03-01-2009, 19:02
smartkid's Avatar
Boom!
AKA: Cody Smith
Re: Hovercraft
I like that logic. Let me ask, to get a good vacuum would you need to touch the surface of the playing field or would you be able to make a duct that comes very close to the surface but does not touch?
Unread 03-01-2009, 19:08
Racer26 Racer26 is offline
Re: Hovercraft
I would think touching the surface would be required to gain significant benefit from it, however, it might just be a use for all those banebots/FP motors my team never finds a use for, if the Q/A determines its allowed (which i think is unlikely)
Unread 03-01-2009, 19:12
smartkid's Avatar
Boom!
AKA: Cody Smith
Re: Hovercraft
When does the Q&A open anyway?
Unread 03-01-2009, 19:23
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Hovercraft
To finalize my discussion with myself about fans to augment your own acceleration, I found one designed for a maximum of 300 watts, which is in the range that a FRC robot can legally put out. It puts out 4 newtons while spinning at some mind-boggling RPMs. It would sound really cool spooling up.
So you'd have a drive motor running continuously at near-maximum output for 4 newtons of forward force. Maybe I'm not looking in the right places (after all, R/C fans are designed for applications where they are moving through air quickly), but that seems like it'd be too little force for a hovercraft to be effective.
You could build very light if you wanted maximum acceleration, but you're still hauling a big trailer behind you and you'd lose pushing matches because your absolute pushing power would be lower (you'd lose your wheel traction in proportion to your weight loss).
A maximum-weight robot would get a 15% acceleration boost by using this little fan, assuming it would be a legal thing to do, you could rig a motor and gearbox to the fan, and the constant 300 watt drain wouldn't greatly impair other robot actions.
Here is the fan: http://www.modelflight.com.au/rc_mod..._micro_fan.htm
Unread 03-01-2009, 19:24
Beakerone Beakerone is offline
FRC #1099 (Lions)
Beakerone is an unknown quantity at this point
Re: Hovercraft
Definitely an interesting idea, but i was wondering how you were going to get past (R18) which defines the height that the trailer must be attached to the robot - 2 and 13/16ths to the center of the Trailer Hitch from the floor., doesn't sound like it can be "floating" at different heights... which I think would occur, also they mention that it has to be rigidly attached to a fixed locations.
Unread 04-01-2009, 13:49
cj.reeves cj.reeves is offline
FRC #2589
cj.reeves is an unknown quantity at this point
Re: Hovercraft
is the coeficient of friction independent of surface area under the present conditions
Unread 04-01-2009, 15:18
n_ambrogi013 n_ambrogi013 is offline
FRC #0131
n_ambrogi013 is an unknown quantity at this point
Re: Hovercraft
i think that someone already discussed earlier in this thread using a fan to generate downforce, effectively increasing the normal force on the wheels.
my question is, how would you calculate the amount of suction force that a fan can generate against a solid surface like the playing field? using drive motors to power a fan is really only worth it if there is a significant traction increase.
also, is it legal to generate downforce with a fan?
Unread 04-01-2009, 15:20
scirobotics's Avatar
scirobotics scirobotics is offline
AKA: Oscar Hazelaar
FRC #2013 (Cyber Gnomes)
Team Role: Communications
scirobotics is a jewel in the roughscirobotics is a jewel in the roughscirobotics is a jewel in the rough
Re: Hovercraft
it is illigal to genarate downforce with a fan
now who has more balls?
I would propably cut my self trying to screw a nut on our bot, but hey, without money we wouldn't have that nut to begin with "Support devision of 2013 motto"
2013, living after the end (2012 :@)
2007 Rookie inspiration award Greater Toronto Regional
2008 Imagery award Waterloo Regional
2008 Imagery award Greater Tortonto Regional
2008 Finalists Waterloo Regional
no we can't give you gnome hats, not they are not dunche caps, NO you can't wear my beard....
Unread 04-01-2009, 19:19
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Hovercraft
Originally Posted by Prontopwnage View Post
hey you guys, your thinking to hard...
You could do the opposite and get more grip... Like that model car that can go on the ceiling! I don't know if that would work... What do you guys think?
I think you're not thinking hard enough, since you asked.
Yes, as coefficient of friction is a property of the interaction of two surfaces. But I think you want to know about pushing power, which theoretically remains the same because a larger area means a smaller force per unit area, but in reality a larger surface contact area means a very slightly increased pushing power.
Can you quote a rule please? Or is this speculation?
Unread 05-01-2009, 17:43
Electrical Engineer
Rookie Year: 1995
Re: Hovercraft
Would you mind quoting the specific rule?
Mike Betts
As easy as 355/113...
Unread 05-01-2009, 18:14
OScubed's Avatar
OScubed OScubed is offline
Lee Drake, CEO, OS-Cubed Inc.
AKA: Lee Drake
FRC #1511 (Rolling Thunder)
Team Role: Parent
OScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond repute
Send a message via ICQ to OScubed Send a message via AIM to OScubed Send a message via MSN to OScubed
Re: Hovercraft
It's pretty clear that anything that provides additional traction is ruled out by R06:
<R06>
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted.
The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads, alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game
Note the OR OTHER DEVICES INTENDED TO PROVIDE TRACTION.
Lee Drake, CEO, OS-Cubed, Inc.
Business Mentor - team 1511
Rochester, NY
Building optimal, stable, secure solutions to your business challenges.
pic: Hovercraft cart ChristinaR Extra Discussion 41 09-04-2008 02:24
Hovercraft? jennpeeler Rules/Strategy 19 25-10-2006 19:46
Hovercraft edomus General Forum 24 02-06-2005 21:00
pic: Hovercraft edomus Extra Discussion 11 01-06-2005 11:55
