Re: How can we drive on this new floor?
For tank drive systems, what do you guys think about 4 vs 6 coplanar, evenly spaced wheels? Would there really be any difference?
Has anyone felt the new playing surface? How much does it cost? Would plane old hallway concrete be a suitable substitute? |
im not sure how many of you out there live in the lovely area that gets a lot of snow. but im in new carlisle indiana. and we just get dumped on constanlty. one thing i've notices is front wheel drive cars tend to do better. you can power out of the slide (if you are able to do a car-like steering). and i have noticed that rear wheel drive causes a lot of fishtailing.(maybe not with the trailer). but the best by far is four-wheel drive. it gives you power to all four wheels. team 2197 is without a doubt going with four wheel drive. good luck to everyone. i hope you all have fun with lunacy
One thing to watch for when designing the robot is turning ability when using skid steering (tank drive).
If you notice the coefficients of friction for the wheels, you will see that inline dynamic is .05 while transverse dynamic is .10. In a skidding situation the wheel will be twice as resistant to going sideways as it is to going forwards.... That means, as I read it, that your wheel is not going to want to slide sideways very easily if you use 4wd tank drive. In fact anyone planning on going with skid steering will probably want to really look at using at least six wheels to minimize the amount of skidding required in a turn. Jason |
We bought two 4' x 8' sheets of that "ice" material ($30 per sheet) for the floor and did some testing. We compared traction on the "ice" the carpet and plain old tiled floor. The ice was the slickest. The carpet was slick but not as bad. The tile was surprisingly almost the same as the ice. So, to answer your question, if you cannot afford to buy some of the ice material, use a tiled floor as your best simulation.
I was thinking that we might stretch a large sheet of plastic over a tile floor and tape down the edges. If the plastic is thick enough, hopefully the robot will not wrinkle and tear it long enough to practice. |
#7
So does anyone want to chime in about using these wheels as omniwheels. Would it even be possible. I am feeling slightly lost since all of my preseason designs involved mega-traction and multi-speed high torque transmissions
#8
These wheels, according to the manual, have a transverse coefficient of friction that is about twice that of the inline direction. They are, by my reading... anti-omni wheels. Jason |
#9
| EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? | mayazk | Programming | 2 | 16-02-2008 02:17 |
| New skateboard... Just imagine the robotics drive applications this would create | Elgin Clock | Technical Discussion | 8 | 21-07-2007 12:56 |
| How can this be!?! | Mike Rush | Math and Science | 6 | 09-12-2004 13:51 |
| How many drive motors did you use (per side) this year? | Billfred | Motors | 19 | 16-10-2004 20:27 |
| How can we make this better? | archiver | 1999 | 6 | 23-06-2002 22:39 |
