#16
Re: How can we drive on this new floor?
The fewer wheels you have will actually increase you traction because you will have more weight on the drive wheels we are thinking about having a front wheel drive with one more wheel in the back. We would use a tank drive to be able to turn with the trailer.
#17
im not sure how many of you out there live in the lovely area that gets a lot of snow. but im in new carlisle indiana. and we just get dumped on constanlty. one thing i've notices is front wheel drive cars tend to do better. you can power out of the slide (if you are able to do a car-like steering). and i have noticed that rear wheel drive causes a lot of fishtailing.(maybe not with the trailer). but the best by far is four-wheel drive. it gives you power to all four wheels. team 2197 is without a doubt going with four wheel drive. good luck to everyone. i hope you all have fun with lunacy
#19
If you are talking about R06 I don't read it that way. The tread must be in contact with the ground and the wheel axis must be parallel to the ground and through the wheel hub. However, this does not imply "inline. At first read, I do not see what rule would prohibit a crab steering configuration unless I missed something.
#20
One thing to watch for when designing the robot is turning ability when using skid steering (tank drive).
If you notice the coefficients of friction for the wheels, you will see that inline dynamic is .05 while transverse dynamic is .10. In a skidding situation the wheel will be twice as resistant to going sideways as it is to going forwards.... That means, as I read it, that your wheel is not going to want to slide sideways very easily if you use 4wd tank drive. In fact anyone planning on going with skid steering will probably want to really look at using at least six wheels to minimize the amount of skidding required in a turn. Jason |
#21
I think the intention of R06 is to prevent teams from using the non-treaded portion of the wheel as a traction surface, not rule out Holonomic or Kiwi type drive systems.
#22
2j
#23
As I think more and more about this game I've come to a conclusion.
No matter what you do, you'll still be working with limited traction. Instead of worry about getting more traction, why not just embrace the lose of traction? I think the question of "how can we drive on this new floor?" should be posed to the drivers. It'll require quite a bit of finesse and skill to master the lack of traction but those who do will be at a huge advantage. Perhaps you should have your drivers research things like Drifting, ice driving, and driving in the rain to get some ideas. I personally, dabble in a bit of drifting myself so I'd like to see if I can apply that experience to driving a robot on this surface. |
#24
I think the solution for driving on this new floor will be more likely on Software : http://en.wikipedia.org/wiki/Traction_control_system.
Gotta think how does the algorithm work on a 4W drive vehicle works...... Cheers, Marcos. |
#25
i totally agree with that. theres no way to increase traction. and i also do some drifting myself. main thing is you cant give a lot of power right away. otherwise you will just spin your tires(wheels). it will require some skills by the drivers |
#26
You can add more traction to the wheels by adding downward force onto the wheels. Any additional weight would be dispersed by the wheels regardless of where it's centered unless the robot has another point of contact with the ground (or if it goes all the way through the trailer). So you could add force with springs or with pneumatics, thereby adding traction.
But I'm wondering, could you propel yourself by say, pushing off of walls? There have got to be some ways to move outside of the traditional wheels on the ground that are still legal within the competition constraints. |
#29
It seems to me that heavier Bots will do a lot better, and I'm sure everyone will be maxed out on weight, so the question is how do you add weight....without adding weight....
*Hint hint Nudge nudge* |
| EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? | mayazk | Programming | 2 | 16-02-2008 02:17 |
| New skateboard... Just imagine the robotics drive applications this would create | Elgin Clock | Technical Discussion | 8 | 21-07-2007 12:56 |
| How can this be!?! | Mike Rush | Math and Science | 6 | 09-12-2004 13:51 |
| How many drive motors did you use (per side) this year? | Billfred | Motors | 19 | 16-10-2004 20:27 |
| How can we make this better? | archiver | 1999 | 6 | 23-06-2002 22:39 |
