Go to Post These two options can both be used effectively to create a wonderful experience for the students, but limiting them to one area is like taking a globe, slicing it in half, and saying, "You can only explore this half." - Alex Golec [more]
Unread 03-01-2009, 18:49
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
robot design question
so, we're trying to figure out if it's legal to design the bot so part of the trailer would be within the robot's dimensions, kind of like something between a fork. Can't find anything in the rules. Help?
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 03-01-2009, 18:54
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
Re: robot design question
<R18> To attach the TRAILER to the ROBOT, TEAMS must use a Trailer Hitch constructed from
materials provided in the 2009 Kit Of Parts. Details on the construction of the Trailer Hitch
are provided in Drawing “GE-09040.”
There it is, so if your design includes that then I don't think it's a violation.
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 03-01-2009, 18:57
Otaku's Avatar
AKA: Michael Baker
what we had thought up was something like a [ shape, with the trailer hitch in the middle of the vertical section in between the 'prongs'.
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Just found this too:
D. The Trailer Hitch must be located on an outer edge of the ROBOT structure such that it may
easily connect with the tongue of the TRAILER (attached to the TRAILER).
E. The Trailer Hitch must be placed such that, as the TRAILER swings from side to side, the
first contact between the TRAILER and ROBOT is BUMPER-to-BUMPER and not TRAILER-
tongue-to-BUMPER (to prevent placing excessive stress upon, and possibly damaging, the
TRAILER tongue). See Figure 8-6.
This is all under <R18> so look at that once more, if there are no violations in your design I say it's all good.
Ben Kellogg
Unread 03-01-2009, 19:00
Otaku's Avatar
AKA: Michael Baker
<r18> section D says outer edge, technically the inside of a bracket would be inside edge, thus illegal.
oh well.
Unread 03-01-2009, 19:01
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Well if it's up vertically and attached, will that allow it to swing side to side, because it has to do that.
Oh w8 look at this:
B. The Trailer Hitch must be rigidly attached to a fixed location on the ROBOT, with the long
dimension of the Trailer Hitch horizontal
and the opening of the C-channel facing away from
the ROBOT. The horizontal center line of the Trailer Hitch must be 2-13/16 inches above
the floor.
If you are planning a vertical fork it won't work
Ben Kellogg
Unread 03-01-2009, 19:03
Otaku's Avatar
AKA: Michael Baker
i'll try and get a 3d image of what i'm talking about.
Unread 03-01-2009, 19:28
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
The dimensions of the trailer with bumpers range from approximately 34" (distance between midpoints of opposite sides) to 39" (distance between opposite corners). This would make it near-impossible to fit within a U-shape, as each side of the U could only be 2 inches wide.
Also note that the trailer tongue protrudes about 10" from the trailer, so you would not be able to achieve a tight fit.
Unread 03-01-2009, 19:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
dimension of the Trailer Hitch horizontal and the opening of the C-channel facing away from
the floor.
Also note that you may not move the hitch mount after the match has started.
GitHub
Unread 04-01-2009, 01:03
Otaku's Avatar
AKA: Michael Baker
image is top view, and not to scale completely, but you get the general idea.
The question is "Is this legal?". In so far as what constitutes an "outside" edge. The rule's not completely unambiguious about this. Can parts of the robot "wrap around" the trailer so to speak? Would we be allowed to make a design that limits the lateral movement, through the placement of the hitch alone and no other modifications, of the trailer, assuming that trailer to robot contact is still going to be bumper-to-bumper?
EDIT: also, this design won't ever see field time, I kinda wanna keep the real one hidden, so just imagine that the trailer isn't as engulfed as it is here. The same questions apply, though.
Unread 04-01-2009, 02:24
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
AKA: Katie Widen
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
I've been doodling that all day with a scale and dimentions, and with the size restrictions, its possible, but hard. If you do, as you sketched, you're in the clear, but there is a rule about the trailed bumper and your robot 's contact, its clearly stated in <R18>.
Unread 04-01-2009, 02:41
Otaku's Avatar
AKA: Michael Baker
So long as the trailer only contacts the robot bumper to bumper, it's legal, then.
Alright.
Unread 04-01-2009, 02:43
Iceman1330's Avatar
Iceman1330 Iceman1330 is offline
FRC #2523 (Lab Rats)
Iceman1330 is an unknown quantity at this point
I think what you are talking about is this. (16"x36" contact base)
The red areas are the "blocking spaces where balls can't be thrown. All measurements are ballpark (within 1-2" accurate, Proof of Concept)
The robot fits in the "box" and hugs at least half of the trailer. Weight issues might be a problem, but if you make the shroud light enough and place the batteries and heavy stuff in front you might be OK.
Unread 04-01-2009, 03:04
Racer26 Racer26 is offline
A neat design, nice drafting in the short time since kickoff.
My $0.02 is that with such a design, and the way it effectively eats your entire size envelope, you cant hopper up the balls to bring them to your human players more effectively, and you can't really fit a launcher in there either, meaning two key ways of scoring are severely hindered... not sure if its a net gain or not.
EDIT: also, the CoG being off center like that could make you easily tippable/have problems with moving on this already difficult to move on surface.
Furthermore, strategies like this will just make the human players go for your teammates goals, since they're wide open they're more likely to score there, rendering the protection they give more or less redundant.
Unread 04-01-2009, 08:16
GaryVoshol's Avatar
Cogito ergo arbitro
//images deleted//
Are those short segments adjacent to the trailer proper 6" minimum lengths? (You count the plywood, not the foam.)
Is 2/3 of the BUMPER PERIMETER enclosed by bumpers? I think so, if the short pieces are at least 6".
BUMPER PERIMETER is defined by the outermost corners of the robot. The "outer" location for the trailer hitch is not defined.
(since 2004)
Is it allowed (Website Design/Award Question) Schu Website Design/Showcase 18 06-02-2006 23:02
Another layout design question Raven_Writer Chit-Chat 3 08-12-2003 16:50
a web design trivia question robot180 Website Design/Showcase 5 17-10-2003 19:46
A question about gearbox design . . Frank(Aflak) Technical Discussion 14 02-10-2003 14:57
gearing design calculation question caffel Motors 4 24-03-2003 17:34
