| Thread Tools |
Rating:
Display Modes |
Anyone know how to get a live video feed from your axis cam?
We hooked up the camera to a pc and got a video feed, then when we put it on the robot the screen was blank. the ethernet port on the cRIO wans't blinking...anyone know how to do it?
Re: Anyone know how to get a live video feed from your axis cam?
Did you use the special orange cross-over ethernet cable to connect the camera to the cRIO port 2?
I did find an open-source C#-based program called CV (Google it) that lets you hook into and view feeds from IP cameras such as the one shipped with the 2008-2009 kit.
Also, the format is HTTP-packeted MJPEG (Moving JPEG), I believe, similar to any standard IP camera. You could probably just use VLC Media Player to watch it live. |
I'd also like to get some more information on this topic. We as a team have configured the webcam according the the control system manual and got a live feed when we were directly hooked to the camera. We then hooked it back up into port 2 and wanted to try to view the camera another way with no success.
Is there anyway to view a live feed wirelessely or by hooking up a laptop to the router or driver station? If so, do we need another crossover cable or is an ethernet cable fine? Do we hook up to the router or driver station? Thanks... |
The setup that you would use to view it wireless is to get the image from the cRio. If you make a new dashboard project in LabView and type in the correct IP address for the robot, you should be able to see your video feed. I was able to see it for the first time today! It's a little blurry but I'm guessing there's a way to adjust the focus.
You also may have to make a new project in labview, point the correct cRio IP and go to "Tools" and then do "Set up AXIS Camera" Are you able to deploy projects to the cRio? Is everything else set up correctly? |
In LabView, if you use one of the default examples that ships with the cRio, it is easy to add a front-panel element to get a live preview of the camera while developing code. Right click one of the wires in the code diagram that carries an image, and select "Add Indicator". This will add a front panel element that will show you the video in semi-live mode - there is a few seconds of delay from the wireless transmission and all.
#7
I keep hearing that the LabView Dashboard is usable when WindRiver is used to program the cRio. Does anyone know how this setup works?
#8
The laptop running the dashboard must have a static IP of 10.x.y.6. The data is automatically streamed to this IP address, and no other. Make sure you've set that up properly, or else the LabView Dashboard won't get any data.
| New Video Blog Entry: "Video from Live LabVIEW Session for FRC Competitors in Toronto | LVMastery | NI LabVIEW | 0 | 13-12-2008 08:09 |
| WATCH LIVE FEED FROM OUR MEETING | Raikon | General Forum | 9 | 05-02-2008 22:18 |
| Does anyone know where to get a 9" interdiameter PVC? | cvhsrobotics | Chit-Chat | 2 | 21-09-2004 01:14 |
| Anyone know where I can get a sample.. | Jason_384 | General Forum | 4 | 30-01-2002 23:04 |
