Go to Post The last 20% takes 80% of the time. Beware. - JVN [more]
Unread 03-01-2009, 21:08
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Gyros and Accelerometers
Originally Posted by excel2474 View Post
I've never used a gyro or an accelerometer. I was looking at the ones that came in the kop and I was wondering what you use to wire it to the cRIO. Do I just modify a pwm cable and if so, how do I connect it to the gyro? thanks
You can modify a PWM cable and connect it to the analog sidecar. There are two outputs on the gyro, one is temperature and one is the turn rate. Red is 5v, white/yellow is signal and black is ground.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Accelerometers & Gyros for N00bs ManicMechanic Electrical 23 09-01-2010 18:21
accelerometers and gyroscope to control arm? Hazmatt Programming 10 11-02-2008 08:46
accelerometers and gyroscope to control arm? Hazmatt Technical Discussion 10 11-02-2008 08:46
Gyros and WPILib RyanW Programming 2 28-01-2008 14:05
mounting accelerometers & gyros wireties Electrical 2 26-01-2008 20:10
