Go to Post Why does school have to get in the way of more important things like FIRST? When would we ever need to know about the stuff there teaching in here? - Briansmithtown [more]
Unread 03-01-2009, 21:01
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Gyros and Accelerometers
I've never used a gyro or an accelerometer. I was looking at the ones that came in the kop and I was wondering what you use to wire it to the cRIO. Do I just modify a pwm cable and if so, how do I connect it to the gyro? thanks
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 03-01-2009, 21:08
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Gyros and Accelerometers
You can modify a PWM cable and connect it to the analog sidecar. There are two outputs on the gyro, one is temperature and one is the turn rate. Red is 5v, white/yellow is signal and black is ground.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 03-01-2009, 21:14
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Ok, that's kind of what I thought, but I'm not sure how to connect the wires to the gyro. Is there some type of technique?
Unread 03-01-2009, 21:22
I was going to link you to the sensor manual ( http://usfirst.org/uploadedFiles/200...r%20Manual.pdf ), but that link isn't working for me at the moment. Perhaps it is because everyone is downloading everything, hopefully it will work soon. [EDIT] Actually, it was because my computer loves installing language packs and not telling me.
Both boards have the "standard" 3xN pin interface: .1" space, Signal 5V Ground.
The Accelerometer has an extra power and ground pin in line with the signal pins to allow teams to use a 5x1 connector.
Easiest method is to solder the male end of a PWM cable in for each signal, with white being signal. Female end goes into the analog breakout.
Alternatively, solder a female connector in and then insert the cable into that. We had feedback that some teams didn't like this method, so we didn't force it.
Unread 04-01-2009, 02:00
Racer26 Racer26 is offline
<unsure if i'm stating the obvious>
The "technique" to which you would be referring is Soldering, http://en.wikipedia.org/wiki/Soldering
</unsure>
I personally like the suggested method of soldering the male end of a pwm wire right to the board.
Alternately, you could just solder some wire to the boards, preferably with a strain relief and then connect it to the analog breakout board with a pwm connector.
Unread 04-01-2009, 13:05
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
I'm a bit curious to know what teams didn't like about this method, as it's the one we're considering, but we've never done it before.
Unread 04-01-2009, 17:12
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
The short story is that since both the gyro and the accelerometer outputs an analog voltage, any connection made is extremely susceptible to electromagnetic interference, especially if the sensor is placed near a motor or solenoid. Additional connectors mean more points of weakness for the signal to deteriorate. A direct soldered connection is a more robust way to connect a wire to a pad than through an additional connector.
On a side note, if the interference gets too bad, you can always shield and ground the cable - doing that on an especially bad signal line can clean things up a little.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 04-01-2009, 19:40
Ubuntu User
AKA: Brian
Sparks
Oh! That clears things up nicely, thank you.
Unread 08-01-2009, 11:02
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
So, all of you received an accelerometer at the KoP?
We didn't get one, they said to my coleague who went to NY go get our KoP they were short on accelerometers this year..
and I was so eager to use it.
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 10-01-2009, 12:07
CDH Jeff's Avatar
CDH Jeff CDH Jeff is offline
FRC #2450 (Raiderbots)
Team Role: Electrical
CDH Jeff is an unknown quantity at this point
our team didn't get either the accelerometer or gyro last year, and now we don't know how to wire, even with the help from this forum and the link. which holes are the xyz out? on the 3x3 grid on the accelerometer is it the unlabled row, or the one labereld OV? thats pretty much my only question, thanks for that link to the manual eric.
"why are 'standard' and 'metric' different?! metric should be the standard!"
Unread 10-01-2009, 13:22
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
moving from the xyz to the edge of the board it its:
signal
5v
ground (0v)
A2D Solving the Imaginary Error Function...
Accelerometers & Gyros for N00bs ManicMechanic Electrical 23 09-01-2010 18:21
accelerometers and gyroscope to control arm? Hazmatt Programming 10 11-02-2008 08:46
accelerometers and gyroscope to control arm? Hazmatt Technical Discussion 10 11-02-2008 08:46
Gyros and WPILib RyanW Programming 2 28-01-2008 14:05
mounting accelerometers & gyros wireties Electrical 2 26-01-2008 20:10
