Go to Post Is it weird we think speed controllers are sexy? - vivek16 [more]
Unread 03-01-2009, 09:38
Will_Sica Will_Sica is offline
FRC #0612
Will_Sica is an unknown quantity at this point
ETH 1 Port on Driver Station
Has anyone had any complications with the ethernet ports on the Driver Station?
I was loading code, from Labview, to the robot. The laptop was connected to the Eth 1 port and the Eth 2 port connected to the bridge.
Labview quit at around 50% and displayed an error message "Peer has disabled communications. Please retry." (Not exact error message)
The LED on the DS next to ETH 1 went out after this point.
Further attempts to load code were met with "Can not locate the Real-Time client", even after switching to different cables and computers.
If anyone has any experience or advice, it would be greatly appreciated.
Unread 03-01-2009, 21:53
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: ETH 1 Port on Driver Station
I have no trouble updating code wirelessly. I think the setup should be (well, this is mine)
[(Driver Station ∞ Router) & (Your Laptop ≈ Router)] ≈ Bridge ∞ cRio ∞ Axis
∞ denotes a wired connection
≈ denotes a wireless connection
Sorry this is confusing but what I mean is hook up your driver station wired to the router and then just connect wirelessly to your router network.
I can see my cRio fine, I can access Axis pictures fine, etc.
I can help you out further with Cisco configuration if that's where you are having problems. I'm not sure if this setup is correct for the kickoff but that's another worry for later =]
Edit: I messed up with the Laptop => Driver's Station so fixed.
Unread 03-01-2009, 22:04
ATannahill ATannahill is offline
AKA: Alex Tannahill
During the beta test, our ethernet port 1 got disconnected and had to be removed, I will tell people more knowledgable of the problem about this thread.
- Arizona North
Unread 03-01-2009, 22:07
keehun's Avatar
Team Captain
AKA: Keehun Nam
Another thing you could try is re-imaging the driver's station.
Unread 04-01-2009, 10:11
xnaut's Avatar
xnaut xnaut is offline
Team 79 KRUNCH
AKA: Patrick Thompson
FRC #0079 (TEAM KRUNCH)
xnaut is a jewel in the roughxnaut is a jewel in the roughxnaut is a jewel in the rough
Send a message via AIM to xnaut
We also did all of our uploading wirelessly soooo.... I would suggest trying that... Plus you don't have to be right next to your bot... You fan just sit accross the room at some table...(yah lazy people!) ... If you do that and you still get the lost conection error just wait(if wireless)
Shirley you cant be serious...
Of course i am... and don't call me Shirley
_____________________________________________
TEAM KRUNCH 79
CLEARWATER FL
Unread 04-01-2009, 10:19
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
During the beta program our ETH1 port also broke; physically fell off the board (they have fixed that problem I believe).
We ran the entire beta time running using the wireless connection and wired to the router instead of the DS. So, you can run using a single port on the DS. There maybe some debugging advantages to using the second port, but we never needed to do that.
On that note, if you really think your ETH1 has failed and updating the DS doesn't fix it then you may want to contact FIRST for a replacement.
D. Sean Kelly
Team #499
Unread 05-01-2009, 14:12
FRC #0612
Thank you for all the advice and suggestions.
After attempting many of them, however, we found both ethernet ports to be unusable and are contacting FIRST.
Unread 06-01-2009, 00:37
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Our ETH2 port has failed. I contacted kwikbyte and they said to send it to them for repair and they'll send it back. They don't seem to send you a replacement and have you send back your broken one like some companies do, so if you send it in you'll be without a DS.
Although we can program fine with only one port, we don't like this single point of failure and are thinking about purchasing a second unit and sending back the one we have for repairs. Then we'll have two, just in case.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 07-01-2009, 23:45
1951-44U's Avatar
1951-44U 1951-44U is offline
ROAR.
AKA: Phil Chang
FRC #0025 (Raider Robotix)
1951-44U has a spectacular aura about1951-44U has a spectacular aura about1951-44U has a spectacular aura about
We, too, have the same problem.
While trying to get output from the cRIO to the laptop via the DS, Eth2 knocked out (the one that connected DS to laptop). The LED refuses to light, the port refuses to connect, so we have to wire directly from cRIO to laptop to get output but have to reconnect to DS Port 1 to operate anything. It's getting annoying.
Is this a problem that REQUIRES you to send the DS back to KwikByte?
Unread 12-01-2009, 17:35
Plug the laptop, the DS, and the cRIO all into the router. They don't need to be connected directly. It's an IP network so as long as the IPs are correct everything will work fine.
Unread 12-01-2009, 18:10
Mr-Shutter's Avatar
Mr-Shutter Mr-Shutter is offline
Audiophile
AKA: David
FRC #0612 (Chantilly Robotics)
Mr-Shutter will become famous soon enough
Send a message via AIM to Mr-Shutter
The serial port broke too, on it, just a note. Hocked it up to osilascope, no pretty square waves :<
Also, our ETH2 just fell off >:|
I see in logic, Black and White
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
Mounting the Driver Station...? 1708xMr.Roboto FRC Control System 1 15-12-2008 12:34
2009 Driver Station Dimensions noxryan FRC Control System 5 27-11-2008 21:02
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
