Go to Post Gee, I wonder if AndyMark has a wedding gift registry? - KathieK [more]
Unread 03-01-2009, 20:20
ShadowNinja's Avatar
ShadowNinja ShadowNinja is offline
ShadowNinja
FRC #0231 (HIGH VOLTAGE)
Team Role: Driver
ShadowNinja is an unknown quantity at this point
What r possible drive systems under these circumstances?
Okay so basically the game contradicts itself. Slippery floor, slippery wheels. We actually had the polymer "regolith" in our room..it was used in one of our bathrooms. At first when you move your hand across the surface it feels very bumpy. But when we moved the wheels across the surface there was O friction, a concept that is hard to imagine unless you actually try it out for urself. It comes down to who has a good drive system.....which is?
Also for those who who still need help trying to figure out the substance...it is a polymer..glass liner is what it is called..it is used for bathroomwalls..not sure if it is at home depot.....
Unread 03-01-2009, 21:16
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: What r possible drive systems under these circumstances?
Since I have no experience with the material, or much insight into friction and traction, I will list a brief summary of available options.
Wheels-
2,3,4, and 6 are all possibilities I believe we will be seeing. From what I have been hearing, 6 will be far more popular than past years.
Drive-
Arcade, Tank, swerve, [4wd], [2wd].
Coming from someone who lives in a snow- and ice-plagued area, front wheel drive will probably work better than rear-wheel, with all-wheel being ideal. I would definitely not recommend swerve drive this year.
You are correct that it is more limited than past years, but there are still plenty of options.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 03-01-2009, 21:29
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
. . Any thing your Imagination can come up with!!! . . as long as there isn't a rule against it.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 03-01-2009, 21:35
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Wheels-
Drive-
i would say, that having FWD with rear wheel steering(if not AWD with front wheel steering) would be good, because you can use the brake feature on the jaguars to lock the wheels
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 03-01-2009, 21:45
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
I was thinking of balancing the robot on two drive wheels and letting the trailer keep it up right and than steer the drive wheels and if you angle the rear bumpers out to not allow the trailer to pivot. Doing this instead of driving a car with a trailer you are driving a pick up truck.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 03-01-2009, 22:06
BethMo BethMo is offline
FRC #0948 (NRG (Newport Robotics Group))
BethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to behold
Why? (My team is considering a swerve drive -- any advice I can take back to them would be a helpful addition to the discussion.)
Unread 03-01-2009, 22:09
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
Front wheel drive vehicles are only better in snow because the engine is locaed over your drive wheels therefore the force normal is greater in comparison to rear wheel drive where there is far less weight on them. Hence its not a matter of front wheel drive or rear wheel robot but a mattter of weight distrubution
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 03-01-2009, 22:14
AKA: Bryan
Originally Posted by BethMo View Post
I could be entirely wrong, and with some of these ideas it will be hard to tell until a prototype is built.
However, I don't think that the swerve wheels would get enough traction to change directions, or turn effectively.
Imagine having a three wheel set up, for example, with the back two wheels being powered by CIMs, and the swerve wheel turning via another motor. If you rotate the robot right, the try to quickly change directions left, the robot will probably keep going right for awhile before the wheel finally "catches" or grips the floor.
Unread 03-01-2009, 22:28
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
The only possible successful drive system with the rules worded as they are is a controlable drive system. The momentum of a 100lb robot at 10ft/s is too much to accurately turn in such a low friction environment. So for the strategy we've laid out, we're looking at a max of 7-8 ft/s depending on the system of turning we choose.
To all you speed mongers out there, good luck
GitHub
Unread 03-01-2009, 22:43
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
To speed mongers K=.5mv^2
Anywasy the best drive train will most likely be the one that zamboni's use becuase well, they got what 50 year of engineering behind them, so why try to reinvent the wheel in 6 weeks (don't answer that).
Is now an engineer thanks to FIRST.
Unread 03-01-2009, 22:58
AKA: Bryan
Unless I am mistaken, Zambonis just use a typical car drive (front wheels rotate, rear wheel drive).
I believe they get most of their traction from the type of wheel, and the size (their wheels are very wide), and the fact that they go very slowly.
quixeger's Avatar
quixeger quixeger is offline
FRC #0604 (Quixilver)
quixeger is an unknown quantity at this point
A Zamboni has car steering and snow tires right? It also has a massive water tank between the axles.
As for swerve drive, the stereotypical lack of grip will not likely be a problem this year. Assuming that all wheels are driven, a robot's MAX acceleration is the coefficient of stiction (mu) times g (a=mu*g). If the robot isn't AWD, then weight distribution becomes an issue. The equation mentions nothing about a robot's mass or the wheels' contact patches. Those two become important in pushing matches.
It seems the options are sill wide open!
Unread 03-01-2009, 23:00
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
The type of drive train you use isn't as important as how you incorporate it into your strategy. A four wheel drive can be just as effective as a crab drive, which can be just as effective as an omnid style drive, if used properly. Certain designs may have better potential, but I feel that it is more important that what you make works well and the robot is designed as a whole. If your drive system works well with your manipulator and your game strategy, then you can be very successful. If not, you could have the best drive train in the world, but it is useless if you don't have a game plan or a manipulator to take advantage of it.
Unread 03-01-2009, 23:34
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
In the past we have always started our design at max speed and worked from there.
I am not sure if top speed is the correct way to approach this problem. It seems that the CIM's will provide more than enough power to spin the wheels.
If we determine the amount of torque needed to spin the wheels and design the gear ratio so that max torque at the 40A level is about the same as the amount of torque needed to spin the wheels, then it would be harder for the driver to cause wheelspin. In this example the driver would have to move the joysticks to full power to cause the wheels to spin.
I think this is the lesson we were supposed to learn from the demonstration that Dean and Woody did on the playing field.
If you design for a low topspeed, there will be a lot of torque available with just a small movement of the joystick and it will be very easy for the driver to cause the wheels to spin.
Am I way out in left field here?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 04-01-2009, 01:01
Cartwright Cartwright is offline
Scouting/Manufacturing
AKA: Jamie
FRC #0234 (Cyber Blue)
Cartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to behold
However, It is important to point out the specific case of multi-wheeled robots or robots with multiple contact patches between the wheel and the surface. This is what this engineering book I have says: If the normal force is increased, per given area of contact patch, the COF decreases. As the normal force decreases, the COF increases. If this were not true, then lowering tire air pressure in cars or installing wider tires, which both increase the area of the contact patch, would have little effect on traction.
The traction force is equal to the acceleration times the mass. Therefore, wouldn't the wheel's contact patches matter?
Ideas on 6 Wheel Drive Systems char28 General Forum 1 08-01-2008 21:15
paper: Omnidirectional Drive Systems Ian Mackenzie Technical Discussion 2 28-05-2006 14:22
Drive Systems Alex Cormier Technical Discussion 3 11-01-2005 16:07
Drive Systems Sachiel7 Technical Discussion 6 24-03-2003 16:10
drive systems Greg Perkins Technical Discussion 0 13-01-2003 09:40
