Go to Post My Worst Decision of the Week?? Reading this thread!! :) :) :cool: :cool: - BobC [more]
  #61   Spotlight this post!
Unread 03-01-2009, 21:25
gorrilla's Avatar
gorrilla gorrilla is online now
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: How can we drive on this new floor?
Originally Posted by Dracco1993 View Post
I still need help on thebluealliance thing please.
try here
http://www.thebluealliance.net/tbatv.../teambadge.php
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
  #62   Spotlight this post!
Unread 03-01-2009, 21:32
Zyck_titan's Avatar
Zyck_titan Zyck_titan is offline
FRC #0114 (Eagle Strike)
Zyck_titan is an unknown quantity at this point
Send a message via AIM to Zyck_titan
So here's my basic Idea for anyone who was following, Use a fan or such to provide thrust downward, or basically a (much) lower pressure area underneath the bot, the result (hopefully) would be more weight force downwards, making up for that lost weight force from the low traction, I'm not entirely sure exactly how to implement, and I'm not bothering to run the math on how much airflow is required to make up even say 200 lbs, but something like this might be sufficient,
any thoughts?
  #63   Spotlight this post!
Unread 03-01-2009, 21:38
gorrilla's Avatar
AKA: adam spears
any thoughts?
the rules specify that the Rover Wheels are the only thing allowed to provide "traction"
Adam Spears
  #64   Spotlight this post!
Unread 03-01-2009, 21:39
gorrilla's Avatar
AKA: adam spears
I still cant get it to be my signiture though.
after you do the colors, you have to get the "code" and put it in your signature....
Adam Spears
  #65   Spotlight this post!
Unread 03-01-2009, 21:49
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Originally Posted by corpralchee View Post
What if your robot had two drive trains? One in the forward direction and one in perpendicular to the forward direction. You lifted one drive train to use the other. Kinda like the trucks that are made to drive on the road and railroad tracks.
This is something that Buzz (FRC175) has done to great success in the past. Look up some old video - it's pretty spectacular.
  #66   Spotlight this post!
Unread 03-01-2009, 21:58
pdelbarba pdelbarba is offline
FRC #2641
pdelbarba is an unknown quantity at this point
Isn't using a fan to create a low pressure zone not considered a traction device? I doesn't directly contact the ground nor does it actually constitute any solid form of traction as it would rely on a limited power supply. Such a device could not be used continuously throughout the match (just an estimate, no supporting math) as it would deplete the battery and rob power to the wheels. This is, of course, dependent on your drive configuration (four wheel/two wheel drive) and other systems such as pneumatics. This would, however, be very useful for acceleration and cornering if it could be designed with minimal spin-up time.
On a separate note, is there a rule stating that we cannot use any sort if thrust based propulsion system and just mounting the wheels as unpowered casters? Such a device wouldn't even rely on traction at all...
  #67   Spotlight this post!
Unread 03-01-2009, 22:11
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
How effective would it be to use an accelerometer and a rotation sensor to not allow the wheels to go far beyond wheel slippage. You could maximize the traction with out spinning all over the place.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
  #68   Spotlight this post!
Unread 03-01-2009, 22:20
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Is that low pressure zone intended to increase your traction/performance on the playing surface? If it does, then I would believe it would be defined as a form of traction enhancement. Contact does not matter.
  #69   Spotlight this post!
Unread 03-01-2009, 22:58
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
"fans" = shades of CanAm Chapparel 2Js. They only raced the one year way back... kinda funny to see shredded debris ejected by the two 45hp ducted fans though. Quickly banned as not fitting the FIA racing rules.
  #70   Spotlight this post!
Unread 03-01-2009, 23:42
Homsar66 Homsar66 is offline
AKA: Ryan
FRC #0122 (NASA Knights)
Team Role: Human Player
Homsar66 will become famous soon enough
Think. If this were true, then weight could be "a form of traction enhancement", similar to any traction control ect. Meaning anything on the robot is outlawed, as it adds weight to increase traction.
  #71   Spotlight this post!
Unread 04-01-2009, 00:34
ScottX's Avatar
ScottX ScottX is offline
FRC #0047 (Chief Delphi)
ScottX is an unknown quantity at this point
haha its like a car on ice...=D
SCHOOL ROCKS!
  #72   Spotlight this post!
Unread 04-01-2009, 00:40
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Obviously you don't drive the robot.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
  #73   Spotlight this post!
Unread 04-01-2009, 00:46
Originally Posted by Enigma's puzzle View Post
Sorry to break it too you all but tank drive is going to be a pain, Tank drive has an axis of rotation around the center of the robot. BUT you have a trailer, you are going to be dragging the trailer wheels side ways it will be a battle.
Also the trailer anytime that you backup you will jack knife almost immediately, then you will be unable to control your backwards motion, turning with the trailer.
Hate to break it to you, but a lot of teams have some innovative programming planned. *hint hint* *wink wink*
There are always ways to work around obstacles...even if they're on the moon.
  #74   Spotlight this post!
Unread 04-01-2009, 00:49
The siguniture still does not work. =(
Guys no back to back conversations in threads please. Either stay on topic or use something like AIM or the PM function.
  #75   Spotlight this post!
Unread 04-01-2009, 00:53
smartkid's Avatar
smartkid smartkid is offline
Boom!
AKA: Cody Smith
FRC #1902 (Exploding Bacon)
smartkid has a spectacular aura aboutsmartkid has a spectacular aura about
^ No double posting, theres an edit button for that
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
New skateboard... Just imagine the robotics drive applications this would create Elgin Clock Technical Discussion 8 21-07-2007 12:56
How can this be!?! Mike Rush Math and Science 6 09-12-2004 13:51
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How can we make this better? archiver 1999 6 23-06-2002 22:39
