#31
Re: Removing game pieces from Trailers
Hi Kevin,
I'm not sure I agree with your blanket statement that you can touch trailers. I agree that they can be touched in the bumper zone but <G32> seems pretty clear about any contact out side the bumper zone. <G32> ROBOT to ROBOT Interaction - ... ...E. Contact outside of the BUMPER ZONE is not acceptable, and will result in a PENALTY. The offending ROBOT may be disqualified from the MATCH if the offense is particularly egregious or if it results in substantial damage to another ROBOT. Joshua |
#32
I know that CONTACT outside the bumper zone is illegal (<G32>), but is it illegal for a robot that is smaller than the specified dimensions to extend outside its bumper zone during the match, but not touch any other robots?
#33
Yes. if you stay in 28"x38"x60"
#34
As far as I'm aware you can't have anything outside your bumper limits at any given time?
#35
Still, that means compressing your robot into a smaller space than usual (unless your a team that built a tiny drive train in overdrive). The best way one could do this is some kind of tower, which might be topheavy. ultimately, This idea is extremely hard to pull off. it would take a stroke of genius for one topic in a forum to do this.
#37
P.S. I would not put it past F.I.R.S.T.* to declare in the first update that we can expand from the starting position, putting us all back a few days in design. *For Inspiration and Recognition of Science and Technology Last edited by ATannahill : 03-01-2009 at 23:19. |
#38
I read through the rules and I didn't find anything that stated that robots must remain within their BUMPERS. There is a size limit, but my interpretation of the rules is that a smaller robot may extend slightly, but stay within the dimensions specified in <R11>, to score more easily. If someone can find a rule that limits a robot to stay within the bumper limits, I would like to know. I have read through the robot rules and the game rules at least 4 times and I have not found one.
#39
So "ROBOT to ROBOT" Interaction does not automatically include the Trailer. Just because the ROBOTS cannot touch outside the bumper zone does not automatically prohibit one ROBOT touching another Trailer. Another example of this...All "Posession" rules apply to the ROBOT, but do not include the Trailer. eg: Your ROBOT cannot Possess two Empty Cells, but you could have 4 in your Trailer. |
#42
By your extremely permissive interpretation, you cannot touch the following items when they are not between 1 and 7 inches from the floor: -Field structures -Moon rocks -Empty cells -Super cells <G34> specifically addresses ROBOT-to-ROBOT interaction, right there in the name. TRAILERS are brought into the description as well as a seemingly separate issue. At worst you could assume that <G34> applies to all ROBOTS, aside from your own, and all TRAILERS, including your own. In which case, you would be correct that descoring would be much more difficult. Phil and I are pointing out that Section E. doesn't seem to apply to TRAILERS as it is written, and thus it isn't a problem. We're certainly open to correction from the GDC, but that's the way it appears to us at the moment. In a more general sense, I assume that if the GDC hasn't specifically forbidden something, they're probably allowing it. Especially as they seem to have considered other forms of descoring (tipping goals). I can't bring myself to believe they didn't consider whether teams might attempt descoring in this fashion. |
#44
So, correct me if I'm wrong, but as I am seeing it. The robot is able to contact other robots legally because remember as they said at kickoff. The surface leaves room for contact, but I seriously doubt that someone is going to speed up across the floor and ram an alliance member to knock out moon rocks.
So far, there are no rules saying this or that about descoring, but I can be positive, they are probably very soon to come. It seems to me like as of now, there is no rule against it... The only problem is fitting the robot inside that imaginary box that it must fit into every single moment of the match which is what is being interpreted. Whatever happened to starting the match inside of the box and being able to extend as the match goes on??? |
#45
Blocking your own trailer should be legal if you could figure out how to be able to stay in your 28x38x50 dimensions. First didn't put any rule up against that... yet.
| Possible Game Pieces | R.C. | FRC Game Design | 7 | 25-05-2008 16:49 |
| removing trackball from overpass | Tyler Grooms | Rules/Strategy | 4 | 15-01-2008 12:39 |
| Game pieces on sale | JohnBoucher | General Forum | 17 | 10-01-2007 13:41 |
| FIRST game pieces | sheltie234 | General Forum | 5 | 22-04-2006 19:31 |
| Removing encryption from the pdf's | Mike Soukup | General Forum | 6 | 08-01-2004 17:43 |
