Go to Post Okay, okay, I'll bring your Krispy Kremes to the Championships ... I bought them right after the '03 Championships ... I'm sure they are still in the attic - Natchez [more]
Unread 03-01-2009, 23:25
Jaybee1405
Posts: n/a
Re: 2 bots v. 3 bots Trailer question
Originally Posted by iCurtis View Post
Look at the image in 6.2.3 "Launch Pads." Your alliance's TRAILERS (and vice versa) start directly in front of the opposing alliance's HUMAN PLAYERS. A decent human player should be able to make almost every single ball into the stationary TRAILER sitting three feet away. If there was a robot attached to the TRAILER, the TRAILER would be moving and farther away, making it significantly harder to make shots in. It doesn't deal with the number of trailers or robots, it's the ease of the Human Player's shot.
I was referring to this:
If only 2 TRAILERS are placed on the field, the alliance with the no-show has an advantage.
Unread 03-01-2009, 23:46
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by Jaybee1405 View Post
I see that as very unlikely. If the trailer would indeed be place out alone, how would it be stood up? It only has two wheels so I assume the hitch would be used as a "leg," and I assume that could scratch the floor (which naturally wouldn't be desirable). Furthermore, it would be pushed and knocked over the playing field, likely falling over at some point due to its two wheels, and causing problems for everyone.
The trailers didn't seem to have any real problems staying upright at the Manchester Kickoff event.
They just kind of sit there chilling, like "Hey I'm a trailer, where's my robot?"
Art Dutra IV
世上无难事,只怕有心人.
Unread 04-01-2009, 00:02
Jaybee1405
Posts: n/a
I stand corrected. Thanks.
Unread 04-01-2009, 00:25
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I'm certain that they'll still set the trailers on the field even if a robot doesn't show up. Otherwise, if your alliance didn't field any robots, the other alliance couldn't score any points. Elimination matches are going to be pretty boring if no one wants to put their robot on the field.
I do expect, though, that as in past years, human players will still be allowed to participate, even if they do not bring a robot.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 04-01-2009, 00:34
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Originally Posted by Daniel_LaFleur View Post
My guess is that if a robot does not show up then the team would not be allowed to play during that match. That would mean that one of their payload specialist stations would be unmanned and 20 moonrocks would go unused.
I don't think so. This hasn't been true in the past, and according to 9.6.3, it doesn't look like it'll be true this year.
9.3.6 A TEAM is declared a no-show if no member of the team is in the ALLIANCE BASE, FUELING STATION, or OUTPOST at the start of the MATCH; a no-show team will be disqualified from that MATCH. (emphasis mine.) Thus, a team is only DQed as a no-show if a human player, not the robot, does not show up. And that seems pretty standard.
Originally Posted by pyrome View Post
There are even a few more factors than that in optimizing traction.
However, to put it simply:
Friction is a function of normal force (weight).
Traction is a function of normal force AND surface area.
Notice: high school student in the room. I'm going to try my hand at this--please correct me if I'm wrong. Here goes nothing:
This distinction seems ill-placed. While both definitions are correct in certain circumstances, the circumstances, not the terms are different.
(I believe) there is no actual difference between friction and traction. Traction is simply a term frequently used to describe static friction, particularly in drive systems.
According to Columb (and basically everyone else), friction, in theory, is solely the product of the robots mass (essentially) and the coefficient of friction (static for rolling or non-moving surfaces, kinetic for sliding). Thus, the only ways to control friction are through robot weight (i.e. max it out at 120lbs) and wheel movement--keep them rolling, not sliding. The latter can only be accomplished by keeping acceleration below the maximum force allowed by the mu_s. (F=ma=Ff=mu*Fn=mu*mg, so a=mu*g, and so without modifying gravity, we're pretty stuck.)
Now, according to life in general, surface area plays a part. But it's not in the equation! Ah, but it is. Surface area can effect mu (actually, probably more often vice-versa). Softer surfaces (better traction) require more surface area (think side wall weight support) to be structurally sound and to withstand greater wear and tear. There are some other dynamic contact issues that arise when the "ground" surface is non-uniform, but that's less of an issue on regolith--not to mention even a little more out of my depth to explain.
So, MEs and physicists alike, help me out here. I think that's right.
Unread 04-01-2009, 00:44
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
traction is calculated by Force of Friction combined the surface area of contact between two objects.
Force of friction is just the weight (in newtons) times the coeffecient of friction for the objects.
Or so I believe...
Unread 04-01-2009, 00:49
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Originally Posted by Thermal View Post
If surface area didn't mean anything why do dragsters use wide racing slicks instead of lighter skinnier wheels?
The surface area vs. traction issue has been beaten to death on these forums, so here's the Cliffs Notes. Ideally, surface area doesn't change frictional force. In past FIRST applications, surface area typically has impacted frictional force, because of how common tread materials tend to interlock with the carpet. This is also what happens with soft rubber on asphalt, as in your example. However, since there's little to no interlocking going on with this year's materials, the results should conform much closer to the results expected in Ideal Land.
_
Unread 04-01-2009, 00:57
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
Ideal land rocks
Sounds good to me
Unread 04-01-2009, 01:37
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Question about missing Robots?
If a robot is missing can they still have a human player as a payload specialist? And if they're not allowed can the other teams put a person in there place? Also does that team lose some of it's moon rocks?
Unread 04-01-2009, 01:47
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Question about missing Robots?
Historically (particularly on practice day), teams could send their payload specialist (then known as the "human player") to play even if the robot was not present. This avoided a disqualification for no-show. From my initial reading, 9.3.6 would appear to permit that.
Note that no-show is based on team member presence not robot presence.
Unread 04-01-2009, 01:48
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Well also, if a team cant make a match, wouldnt that mean that the other alliance has one less goal to score in on the field?
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 04-01-2009, 01:52
The Pre's Avatar
The Pre The Pre is offline
College kid who cant quit FIRST
AKA: JP
FRC #1652 (LakeView Legends)
The Pre will become famous soon enough
Send a message via ICQ to The Pre Send a message via AIM to The Pre Send a message via MSN to The Pre
yea there would be one less goal but one of the robots would be double teamed
Unread 04-01-2009, 01:59
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
AKA: Katie Widen
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
Although, if you haven't noticed, the trailers can't hold an unlimited amount of balls, so assumingg they still have their human players (who are doing well), and their robots are scoring just as much, it could be evenly matched, if not tipped in favor of the smaller alliance.
Unread 04-01-2009, 02:08
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You don't know this. It's not specifically covered in the rules, but <G10> says:
ROBOT Starting Positions – Prior to the MATCH, each TEAM negotiates within their ALLIANCE to select one of the three LAUNCH PADS of the ALLIANCE. Each ROBOT is then HITCHED to the TRAILER assigned to the selected LAUNCH PAD. The ROBOT and TRAILER are then placed entirely within the LAUNCH PAD, and positioned such that the TRAILER is in contact with the AIRLOCK or guard rail (as appropriate).
Which implies that TRAILERS are assigned to LAUNCH PADS, whether there's a robot or not. Which means, there'd be 3 TRAILERS, even if there were only 2 ROBOTS. There is definitely a Q&A question here, just to be certain, but I'm pretty sure the TRAILERS stay. If they didn't, why would you bother putting any robots out? No robots = no goals to be scored in. As long as your opponent was foolish enough to field a robot, you'd only have to land a single moon rock to win the match.
Unread 04-01-2009, 02:09
KarlSTA KarlSTA is offline
FRC #2574
KarlSTA is an unknown quantity at this point
where's the rule that prevents three teams from having no robots and only players...they can't be scored on but they can still score?? I haven't found it yet!
pic: Bots on Bots CD 47 Mike Martus Robot Showcase 18 15-02-2007 12:40
A question for ramp bots Cody Carey General Forum 9 28-01-2007 22:23
Art Bots wildcatsfive General Forum 6 28-07-2003 19:09
Bots v Bots archiver 2001 17 23-06-2002 22:06
All these mouse bots gives me an evil idea- CAT BOTS! Patrick Wang General Forum 2 09-03-2002 22:43
