Go to Post Eliminate the scavenger hunt, stop updating the software every two seconds, and make sure your examples and tutorials work. That will help a majority of the people I feel. - sircedric4 [more]
Unread 31-12-2008, 19:56
ravena ravena is offline
FRC #1444 (Lightning Lancers)
ravena is an unknown quantity at this point
Power Distribution Board making noises
Our power distribution board started making noises. It makes both a mid level hum and a separate crackling or arcing noise. All lights are correct and everything else seems to work.
Anyone else experienced anything like this?
Thanks,
Tony
Team 1444
Unread 31-12-2008, 20:06
mbeardsworth mbeardsworth is offline
Lord of the Subversion Repository
AKA: Michael Beardsworth
FRC #2521 (South Eugene High School Robotics)
mbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of light
Re: Power Distribution Board making noises
From 3-FRC Control System Component Datasheets
When under light load, the 24V boost supply will emit an audible whining noise and have a larger voltage ripple. This is an artifact of its power saving mode, and should not cause concern.
Unread 31-12-2008, 20:15
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
There was some similar discussion on the usfirst forums before. Take a look here.
Hope this helps,
Jason Law
Unread 02-01-2009, 15:49
hum and crackling noises sound like a problem to me. Start by removing all cricuit breakers and then turn the power back on. If the hum and crackling have gone away, try installing breakers one at a time. Breakers do go bad and are known to have manufacturing defects. The crackling noise could be a bad contact in a breaker. If the hum remains with all breakers out, doulbe check your outboard voltage wiring to the camera, CRIO, and sidecars. You might have crossed connections, which is producing a short on the output of one of these independent power supplied internal to the power distro board.
Unread 02-01-2009, 23:03
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Something else to check is that if you have the camera installed its mounting is electrically isolated from the rest of the robot. We had a loose wire touching the frame and causing sparks before we discovered and corrected this problem.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 04-01-2009, 00:52
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Does anyone with perfect pitch want to identify that pitch? I'll post it on Monday if no one else does... (oh I'm not perfect pitch but I'll identify it)
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 04-01-2009, 08:41
The frequency is a function of battery voltage and load. The load is a function of what the bridge or cRIO are doing. You can actually hear it sing a boot melody if you listen close enough.
5v LED on Power distribution board? Hadi379 FRC Control System 6 18-12-2008 15:59
Our Power Distribution mjgard Electrical 17 23-01-2008 15:17
Power Distribution Block kE7JLM Electrical 4 17-01-2008 08:48
Power Distribution Block.. beemgruem Electrical 21 11-01-2008 08:11
Power Distribution xxmaddjxx Electrical 13 30-01-2005 00:43
