Go to Post Fame... Fortune... Bleh I'm inspired and thats all that matters to me - Noah Melamed [more]
  #76   Spotlight this post!
Unread 04-01-2009, 00:55
pinkanese pinkanese is offline
FRC #0401
pinkanese is an unknown quantity at this point
Re: How can we drive on this new floor?
Originally Posted by Zyck_titan View Post
So here's my basic Idea for anyone who was following, Use a fan or such to provide thrust downward, or basically a (much) lower pressure area underneath the bot, the result (hopefully) would be more weight force downwards, making up for that lost weight force from the low traction, I'm not entirely sure exactly how to implement, and I'm not bothering to run the math on how much airflow is required to make up even say 200 lbs, but something like this might be sufficient,
any thoughts?
I have one, the fan in the link draws 8a of current and the hardware we have can only take 3/4a. Also I am thinking that there is little way of creating enough force to hold the robot to the Crater. One of my team mates did the math and estimated that you will need to move over 900 cubic feet of air per minute . It might very well be possible to use a fan to create more downforce, I know it has been done in racing, but the question is going to be one of how much weight can you spare to add it in, how much room do you have for it, and more importantly can you spare that mush energy from your system to power it and all the other essential items.
  #77   Spotlight this post!
Unread 04-01-2009, 00:58
Originally Posted by smartkid View Post
^ No double posting, theres an edit button for that
The post was meant to point out to specific people.
Nevertheless, touche.
  #78   Spotlight this post!
Unread 04-01-2009, 00:59
CraigHickman
Posts: n/a
Originally Posted by Akash Rastogi View Post
Hate to break it to you, but a lot of teams have some innovative programming planned. *hint hint* *wink wink*
There are always ways to work around obstacles...even if they're on the moon.
Eh, figure it's time to stick my nose in here.
Anyway, Titan's idea about augmenting the robot's downward force is an interesting one. Keep working on that, you really could have something there.
Folks, FIRST just took the box we've all been thinking in and ripped it to pieces. Even a kit chassis is stuck in the high traction environment we've had. It's time to shed all these ideas of how we used to move, and really DESIGN around CONSTRAINTS, much the way the real world works. What you're all seeing and experiencing is a valuable skill, so don't blow this one off.
That being said, I have absolutely NO idea what to advise my team to do... I've spent all of today doing different designs, all of which end halfway when I realize different factors.
  #79   Spotlight this post!
Unread 04-01-2009, 01:01
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Originally Posted by markulrich View Post
Has anyone felt the new playing surface? How much does it cost? Would plane old hallway concrete be a suitable substitute?
We bought two 4' x 8' sheets of that "ice" material ($30 per sheet) for the floor and did some testing. We compared traction on the "ice" the carpet and plain old tiled floor. The ice was the slickest. The carpet was slick but not as bad. The tile was surprisingly almost the same as the ice. So, to answer your question, if you cannot afford to buy some of the ice material, use a tiled floor as your best simulation.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
  #80   Spotlight this post!
Unread 04-01-2009, 01:04
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Many teams used 4 CIMS for their drivetrain in past competitions. It seems that 2 CIMS would be sufficient to drive the wheels this year. How much more traction would you get from 2 CIMS driving fans? what if the fans were used for purplusion instead? i.e. like an airboat.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
  #81   Spotlight this post!
Unread 04-01-2009, 01:12
Did you collect and numbers to help us compare?
I was thinking that we might stretch a large sheet of plastic over a tile floor and tape down the edges. If the plastic is thick enough, hopefully the robot will not wrinkle and tear it long enough to practice.
  #82   Spotlight this post!
Unread 04-01-2009, 01:15
hahaha, I do love these propulsion ideas.
But i think that teams are making this much tougher for themselves by not looking at what by some people has been described and explained to me as simple physics. Why make it harder on yourself by making that hypothetical propulsion robot? Think of the new challenges you create for yourself. A part of engineering, as what I've been taught by my grandfather, is not only creating solutions, but moving closer to the obstacles at hand, and not creating new ones for yourself.
Sure propulsion would be innovative in an FRC robot, sure it'd be tons of fun, but look at the new challenges you're bringing up for your own team. How would this effect the physics of you carrying the trailer? When you turn, the inertia of that trailer will lead you into a corner with propulsion. A hybrid of propulsion and wheels is almost useless even if it is deemed allowed (which by the "no other traction on the field allowed" part of the rules can't be done anyway).
Ranting aside, my point is just for teams to think more clearly in their ideas. I'm not an engineer so I'm not saying you even have to listen to me or consider my advice, just don't create new obstacles for yourselves.
Originally Posted by sdcantrell56 View Post
So does anyone want to chime in about using these wheels as omniwheels. Would it even be possible. I am feeling slightly lost since all of my preseason designs involved mega-traction and multi-speed high torque transmissions
Yup Sean, it looks possible. I've gone over the CoF with a lot of people and depending on the orientation of your wheels, you could in theory do a Kiwi type holonomic drive. I'd rather test it out though.
  #83   Spotlight this post!
Unread 04-01-2009, 01:16
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is online now
AKA: Sean
FRC #2415 (Wired Cats)
Mentor 2415
  #84   Spotlight this post!
Unread 04-01-2009, 02:59
PowerOfKings PowerOfKings is offline
AKA: Jon
FRC #1891 (BullBots)
PowerOfKings is an unknown quantity at this point
So Zyck_titan it seems you had the same idea I did... >.< and I thought I was original.
We did the math and with a 480 watt (the maximum wattage motor allowable) you could produce just under .2 psi. (allow variance for rotor blade type) Numbers for this were taken from a website publishing the Static Pressure capabilities of their 480 watt fans. (we then did conversions to psi)
Now you have to multiply by the square inches (maximum allowable 1064 = 28x38) and we get about 213 pounds of extra force.
So if you had a skirt around the entirety of your robot you could conservativly expect to roughly double the weight/normal force of your robot. (you'd lose a lot due to inefficiencies)
This means that when applied to F=MA in regards to your acceleration you can expect to take it from roughly .6 m/s (static friction with no fans) to 1.2-1.5 m/s (static friction with fans)
Now logistics might be a tad tough but hey if it gives you double your friction then it's worth it in my book. The real problem... ripping up the play area. If it isn't secured you would just vacuum it up and be completely stuck. This seems a real problem to me since when you look here ( http://thebluealliance.tumblr.com/po...field-elements ) at the end you can see the edge of the field which is merely secured with TAPE and now if this is a thin linoleum style roll you would just suck it right up and then... you wouldn't be able to move and might even get a penalty for destroying the field.
...after further research ( http://www.frpshop.com/pdf/installat...structions.pdf ) assuming FIRST followed these rules for the construction of a gasolenar frp floor it might not be too much of a problem...
  #85   Spotlight this post!
Unread 04-01-2009, 03:23
dtengineering's Avatar
AKA: Jason Brett
Omniwheels are specifically designed to have a lower coefficient of friction in the transverse direction than in the inline direction.
These wheels, according to the manual, have a transverse coefficient of friction that is about twice that of the inline direction. They are, by my reading... anti-omni wheels.
Jason
  #86   Spotlight this post!
Unread 04-01-2009, 03:27
Jaime65's Avatar
Jaime65 Jaime65 is offline
AKA: Jaime
FRC #3398
Jaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud of
Originally Posted by thefro526 View Post
As I think more and more about this game I've come to a conclusion.
No matter what you do, you'll still be working with limited traction. Instead of worry about getting more traction, why not just embrace the lose of traction?
I think the question of "how can we drive on this new floor?" should be posed to the drivers. It'll require quite a bit of finesse and skill to master the lack of traction but those who do will be at a huge advantage.
Perhaps you should have your drivers research things like Drifting, ice driving, and driving in the rain to get some ideas. I personally, dabble in a bit of drifting myself so I'd like to see if I can apply that experience to driving a robot on this surface.
I agree
2015 • Team #3398 Crushing Crusaders • Mentor
2008 – 2009 • Team #65 Huskie Brigade • Mentor
2003 – 2007 • Team #65 Huskie Brigade • Human Player
Most Of The Time You Will Fail, But You Will Also Occasionally Succeed.
Those Occasional Successes Make All The Hard Work And Sacrifice Worthwhile. - Dean Kamen
  #87   Spotlight this post!
Unread 04-01-2009, 04:47
Lesman's Avatar
Lesman Lesman is offline
FRC #1014 (Bad Robot)
Lesman will become famous soon enough
The coefficient of transverse static (or kinetic for that matter) friction is significantly higher than the Inline coefficients of friction. I can't help but imagine that some use could be had from the transverse friction.
The the higher friction could be used to create a centripetal force to assist in turning, which would require that the wheels rotate.
Or, a foot could be made from a perpendicularly positioned wheel, and use the transverse coefficient of friction to help stop the robot. Would that be legal?
  #88   Spotlight this post!
Unread 04-01-2009, 04:54
AKA: Jon
It doesn't make sense to me why one would be higher than the other the wheels are molded and don't have any sort of "stepping" that would cause this ... any idea as to why one would be greater than the other?
  #89   Spotlight this post!
Unread 04-01-2009, 06:53
GaryVoshol's Avatar
Cogito ergo arbitro
Did you do any testing on terrazzo floors? (The stuff where a slurry is poured, and then polished after it hardens)
(since 2004)
  #90   Spotlight this post!
Unread 04-01-2009, 07:37
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Alot of people's response to this problem reminds me of an exercise we had to do at a workshop that work had us do to advocate thinking outside of the box. They had us put up our hand and the guy would push it. Of course out of reflex we would resist. And he asked us why we resisted? Because it our habit to do so. Sometimes instead of just resiting the forces that are working against you is to loosen your control and work with those forces and allow them to do the steering.
Seems to me what people have the biggest problem here with is being in complete control of their robot and are trying to come up with every possible solution to regain that control when maybe the best solution is to embrace the lack of control and use it to the advantage like the guys who suggest the drifting training. You could waste alot of time and energy otherwise.
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
New skateboard... Just imagine the robotics drive applications this would create Elgin Clock Technical Discussion 8 21-07-2007 12:56
How can this be!?! Mike Rush Math and Science 6 09-12-2004 13:51
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How can we make this better? archiver 1999 6 23-06-2002 22:39
