Go to Post "Friends don't let friends build mecanum" - Michael Corsetto [more]
Unread 04-01-2009, 01:35
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: 2 Motors is Faster?!
48:1 is a bit of reduction, but if you use the AM planetary adapters then you could use the Toughbox and get a ratio close to that, though I suspect you would want to get gears for the toughbox for less reduction, maybe the 8:1 set, to eliminate the need for a funky sprocket ratio.
pic: Faster Than A Speeding Bullet Athleticgirl389 Extra Discussion 10 04-03-2008 17:55
When a Robot Does Rounds Patients Get Faster Discharge JohnBoucher Math and Science 0 16-07-2007 08:03
One Side Drives Faster than the Other. Craig1989 Technical Discussion 18 12-02-2007 12:19
Which is faster? Gary Bonner Programming 4 27-02-2005 00:51
