Go to Post FIRST competitions ARE holidays, or they should be at least. - Kel D [more]
Unread 04-01-2009, 01:17
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Driver Station not allowing team number change
As a forewarning: This has been tried ONLY with an un-updated, "out-of-the-box" Drivers Station.
Anyways, as you may have guessed, we are having trouble changing the team number of the drivers station.
We hold down the middle (down) button for quite a bit of time (far more than the instructions' 4 seconds), with no change on the screen. The instructions say that after 4 seconds, the screen should ask you to input a team number, but we get the same screen as always- the status screen.
Do we have to update the DS first? Do we have to do something else that i am missing?
Team 2052- KnightKrawler
Mentor and volunteer
Unread 04-01-2009, 01:52
Re: Driver Station not allowing team number change
Originally Posted by Tanis View Post
As a forewarning: This has been tried ONLY with an un-updated, "out-of-the-box" Drivers Station...
YES.
You could have gotten the answer sooner by reading the directions (which do tell you to update the DS firmware before changing the team number) or by searching the forums (which have several threads describing this exact situation).
Unread 04-01-2009, 12:26
AKA: Bryan
Sorry, I didn't see any other topics in the control system forum about it, and the manual doesn't mention updating under the "setting your team number section," it just has instructions for setting the number.
Thanks for the help, got it working now.
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
team number change savage General Forum 5 03-10-2006 23:26
Serial Driver and 2K6 Encoder Driver Not compatible Tom Bottiglieri Programming 6 12-02-2006 01:11
Change Team Number on 2004 RC bob2004 Programming 4 18-02-2004 22:08
bug: Can't change team number to Team 0 Joe Ross CD Forum Support 1 18-12-2003 09:52
