Go to Post Stand scouting allows you to get to know the robot. Pit scouting allows you to get to know the team. - Taylor [more]
Unread 04-01-2009, 03:36
dtengineering's Avatar
AKA: Jason Brett
Re: 2 Motors is Faster?!
Originally Posted by Hachiban VIII View Post
Having taken my fair share of physics I do not for the life of me understand how this is possible.
More force should equal greater acceleration, for the same mass. Correct?
They will reach the same speed, but the 4 motor bot will accelerate faster.
Notice the coefficients of friction published in the manual. The static coefficient (where the wheel is NOT skidding) is .6 the coefficient of dyanamic friction (where the wheel IS skidding) is .5
If a four motor drive and a two motor drive are both given the same input signal the four motor drive will generate twice as much torque. This will make the wheels skid (spin freely, do a burnout, whatever you want to call it) sooner than with a two motor drive. At this point you have shifted from static to dyanamic friction.
As soon as that happens, your friction, and thus your accelleration, drops by almost 20%.
It is quite possible for four motors to be equally as fast as two on this surface, but since the determining factor is traction, teams will have to build their robots to avoid spinning their wheels in order to achieve maximum accelleration and pushing power.
Jason
pic: Faster Than A Speeding Bullet Athleticgirl389 Extra Discussion 10 04-03-2008 17:55
When a Robot Does Rounds Patients Get Faster Discharge JohnBoucher Math and Science 0 16-07-2007 08:03
One Side Drives Faster than the Other. Craig1989 Technical Discussion 18 12-02-2007 12:19
Which is faster? Gary Bonner Programming 4 27-02-2005 00:51
