#31
Re: The Game Floor
We fount some at Home Depot for around $30 for a 4X8 sheet.
#32
Re: The Game Floor
Still confused whether this is the smooth surface (implied by "gel coated" as stated in the Arena Manual) or rough as stated by some observers. This seems important to me... Don't want to run off to local home center quite yet only to get the wrong kind !!
#33
Re: The Game Floor
Can someone measure the thickness of what is known to be the right stuff?
#34
Re: The Game Floor
It has a bumpy surface, assuming we got the right stuff. Kinda shiny too, if you use rubber, like on your tennis shoe you actually get good traction. Too bad we gotta use the "rover wheels"
#35
Re: The Game Floor
I'm not sure we will know what the "right stuff" is until we get access to the Q&A forums Wednesday.
#36
Re: The Game Floor
I was just at Menards, Lowes, and Home Depot and 'gel coated' means that it has a glossy surface which makes it more durable.
#37
Re: The Game Floor
The glasteel.com (one of the biggest FRP manufacturer)
defines gel coated as a smooth and embossed as a pebble finish. If I am correct FRC manual(6.2.1)specs the floor as a "gel-coated". |
#38
Re: The Game Floor
Also just wondering, does anyone else notice that after running the new wheels on this stuff after a while the floor and wheels start to wear (also they start to smell)? I getting white dust off my wheels only after running them back and forth after a while. Maybe we need to break them in first. Last edited by Lowfategg : 03-01-2009 at 23:23. |
#39
Re: The Game Floor
Re: The Game Floor
I have not checked it out yet, but I hear that this material is available at home depot for right around $28 per sheet.
I am going to go take a look tomorrow morning. We probably will not buy enough to build a whole field because of the cost. But we will at least do some of it. |
#41
Re: The Game Floor
The animation clearly shows a slightly bumpy surface if you watch carefully. But, i don't know how the "gel coating" affects the surface.
#42
Re: The Game Floor
You can also hit up any home improvement store and find this stuff. ex Home Depot, Lowes, ect... All it is is pretty much that really cheap slippery plastic covering that you will find in bathrooms.
#43
Re: The Game Floor
Could somebody who attended Kickoff in NH please confirm whether the floor was the smooth "gel-coat" or bumpy "pebbled-finish" Glasliner FRP?
#44
Re: The Game Floor
glasliner frp, fiber reinforced polymer, is the name of the flooring and we found it at lowes
#45
Re: The Game Floor
photos from kickoff show that the surface is pebble coated so thats what we bought.
| 174 gets off the floor | Tetraman | Robot Showcase | 9 | 25-02-2008 17:04 |
| Are the goals bolted to the floor? | Leav | Rules/Strategy | 1 | 11-01-2005 03:31 |
| Robots Hanging from the Floor | Todd Derbyshire | Rules/Strategy | 16 | 13-01-2004 14:10 |
| Height of the box stack from the floor | tenfour | General Forum | 4 | 07-01-2003 10:26 |
| Conduit on the floor | Kyle Fenton | General Forum | 2 | 06-01-2002 14:49 |
