Go to Post We design for being on a dysfunctional alliance: all the time. - boomergeek [more]
Unread 04-01-2009, 08:16
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: How can we drive on this new floor?
Originally Posted by Dracco1993 View Post
Some of my team members and I calculated that using 2 sim's and suction cup properly you caould add an extra 600 pounds to your robot with ever touching the ground... Any Ideas?
Shade of 2003.
Teams used suction cups to plant themselves at the top of the ramp. That worked for the first few matches and then after getting ran over by robots for a while the field surface got worn down a bit and the suction cups stopped working.
I suspect the same would happen this year as well.
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
New skateboard... Just imagine the robotics drive applications this would create Elgin Clock Technical Discussion 8 21-07-2007 12:56
How can this be!?! Mike Rush Math and Science 6 09-12-2004 13:51
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How can we make this better? archiver 1999 6 23-06-2002 22:39
