Go to Post Chances are it's an electrical or mechanical problem... - mechanicalbrain [more]
Unread 04-01-2009, 08:22
GaryVoshol's Avatar
Cogito ergo arbitro
Re: New Bumper Rule makes West Coast drive Illegal?
This year's rule: "nut and bolt fasteners are recommended" - Last year that was a MUST.
Additional fastener parts can be attached to the bumper itself this year - the rules specifically mention brackets.
There is in increase to 18 pounds for max bumper weight (was 15).
The pool noodles can be beveled at the ends of the bumper pieces to make a fit around the outside corners of the robot.
(since 2004)
Unread 04-01-2009, 08:57
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Originally Posted by Tristan Lall View Post
That's exactly why it's hazy, though: let's say I use a 0.19 in thick × 1.00 in tall strip of polycarbonate as the backing material, with several screws into the bumper plywood. Will it be strong enough across a 20 in span? My gut feeling is that under most gameplay, it would not break, or even deflect appreciably. But what if the team used (brittle) acrylic instead? Or if they turned the strip 90° to buttress the plywood? I don't think it makes much sense for inspectors to be trying to make that particular determination—it will just be their best guess, and it's ripe for debate that serves no useful purpose.
If your bumper plywood ever breaks, even with no backing (and especially with the aluminum angle depicted in Fig. 8-1), you're probably doing it wrong. And if you use high-quality hardwood marine plywood (as opposed to the regular softwood stuff), you could probably span over 30 in without any backing, and suffer no ill effects.
I just don't think it's valuable to add a specification here, given that it's one more thing for teams to worry about, one more thing that needs to be checked (consistently) at inspection, and is probably superfluous anyway, given moderately-well-constructed bumpers.
in 2007 we had 38" bumpers on the back of our robot only supported on the ends. They were constructed out of high quality plywood and they were snapped in half, twice.
Unread 04-01-2009, 10:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Last year we had the end bumpers (26") fully supported by the chassis, and the side bumpers (36") well supported at the ends, and just touching two standoffs along the sides of the robot (with cantilevered axles). We had no problems at all with the bumpers. Since another team only supported their bumpers at the ends, and did have them break, it seems that not all teams understand what it takes to properly support the bumpers...and that means that the rule does have some merit. But it does change our design plans for this year!
Unread 04-01-2009, 12:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by Paul Copioli View Post
I noticed the changes in the bumper rules, but the picture didn't change. It looks like it specifically allows other forms of attachment other than what is pictured. Good, now I do not have to "discuss" this with Tristan and Ed Sparks at Championship this year.
Believe me, I'm just as relieved as you are that they greatly improved the bumper rule for this year.
Unread 24-01-2009, 01:52
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
..... Good, now I do not have to "discuss" this with Tristan and Ed Sparks at Championship this year.
I'm sure we'll find other things to "discuss" ......
Ed Sparks
MECH TECH FRC-3959
Unread 29-01-2009, 21:54
The phenom's Avatar
The phenom The phenom is offline
FRC #1569
The phenom can only hope to improve
so they always have to be touching?
Unread 29-01-2009, 23:14
Do what always have to be touching? The wheels or the bumpers?
If it's the wheels, no.
If it's the bumpers, they better never touch the regolith intentionally...
Unread 30-01-2009, 01:27
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
I think he meant that the bumbers must always be touching the robot at all points. and that is true, not just the robot though, the "robot frame/chassis" but don't worry about it just mount a small piece of something outside your wheels and bolt your bumpers to that. it's like a one pound maximum fix.
Unread 30-01-2009, 02:15
NickE's Avatar
NickE NickE is offline
_
However, the Q&A has clearly clarified that not anything counts as a structural frame member. I would consider an 1/8" aluminum plate slightly more than "a small piece of something", yet the GDC has said that it is not structural [enough] and does not fulfill the intent of the rule. For those teams that typically build a west-coast drive, it is certainly worth worrying about.
Unread 30-01-2009, 10:16
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
We dissasembled last years robot and found a cracked piece of marine grade plywood for the 27" bumper, but it held.
A structural piece of aluminum angle would work for the "frame support", A plate would be suspect. Just my opinion though.
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
"West Coast" drive? pogenwurst Technical Discussion 32 17-12-2008 19:50
pic: West Coast Drive: Spokane Style CraigHickman Extra Discussion 31 14-12-2008 20:02
New Bumper rule interpretation - straight from the lead inspector Gary Dillard Rules/Strategy 17 12-03-2007 14:56
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
