Go to Post Heat Gun(n.):Your build season replacement for a microwave. - jajabinx124 [more]
  #31   Spotlight this post!
Unread 04-01-2009, 08:51
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Orbit balls breaking
you can put up to 7 of your 20 moonrocks into your robot.
- Arizona North
  #32   Spotlight this post!
Unread 04-01-2009, 08:54
jdhawg's Avatar
jdhawg jdhawg is offline
Programmer/Mentor/Parent. Pick One
AKA: Jack D Higgs
FRC #0364 (Team Fusion)
jdhawg will become famous soon enough
Originally Posted by professorX View Post
I forgot but don't all the robots start with 7 moon rocks also?
So I think the total is 178.
136+(7*6)=178
Yes, but those come from the 20 originally given to your team.
"Opportunity is missed by most people because it is dressed in overalls and looks like work." - Thomas A. Edison
"In the professional world, spelling mistakes, grammatical shortcuts, leet-speek, and misused verbiage are not interpreted as signs of cute, efficient communications. They are indicators of illiteracy, inefficiency, unprofessional behavior, and sloppy work habits." - Dave Lavery
  #33   Spotlight this post!
Unread 04-01-2009, 09:52
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We too picked up about 12 of these at Walmart, and within minutes of them arriving, one of them snapped. This is a bit worrisome in that each match will most likely have a few of these busted. In a typical regional with a 100 or so matches - they will need to supply several hundred extra. Unlike the ringers from 07 and the balls from 04 that can be stored flat, these will take up a bit more space!!
  #34   Spotlight this post!
Unread 04-01-2009, 10:10
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
Thank you for clearing up the confusion.
  #35   Spotlight this post!
Unread 04-01-2009, 10:25
scirobotics's Avatar
scirobotics scirobotics is offline
AKA: Oscar Hazelaar
FRC #2013 (Cyber Gnomes)
Team Role: Communications
scirobotics is a jewel in the roughscirobotics is a jewel in the roughscirobotics is a jewel in the rough
Im not sure, we have been punting them around for quite a wile now and they still seem to be holding up quite ok, a bit loose i guess, but o well, fun stuff, its FRC!!!
now who has more balls?
I would propably cut my self trying to screw a nut on our bot, but hey, without money we wouldn't have that nut to begin with "Support devision of 2013 motto"
2013, living after the end (2012 :@)
2007 Rookie inspiration award Greater Toronto Regional
2008 Imagery award Waterloo Regional
2008 Imagery award Greater Tortonto Regional
2008 Finalists Waterloo Regional
no we can't give you gnome hats, not they are not dunche caps, NO you can't wear my beard....
  #36   Spotlight this post!
Unread 04-01-2009, 12:08
ryanking09 ryanking09 is offline
FRC #2366 (Tesla Robotics)
Team Role: Webmaster
ryanking09 is an unknown quantity at this point
Exclamation Re: Orbit balls breaking
When you first recieve your new ball it has a rating of 5+ years old. Does this mean the rating would then be inaccurate, because the ball breaking at a glue joint with sharp plastic corners could mean danger. and if there were enough broken and enough problems/complaints. lol there may be a recall on the balls
  #37   Spotlight this post!
Unread 04-01-2009, 19:15
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Some "broken" joints can be easily fixed with some patience if they "break" right below a line of stitching.
I felt a tounge & groove/ dovetail type connection on the end of the plastic strip & was able to manipulate it within the fabric and snap it back together. All the years of hacking & fixing parts as part of the field reset crew is paying off I guess. lol
I haven't seen one without the fabric on it, but these things are going to get really mangled I do agree.
At least they won't leave foam all over the field though like the poof balls. Oh wells, no cool foam skid marks the full length of the field this year. HA!
  #38   Spotlight this post!
Unread 04-01-2009, 19:22
Sunbun's Avatar
Sunbun Sunbun is offline
AKA: Sunny
FRC #1197 (TorBots)
Sunbun is a glorious beacon of lightSunbun is a glorious beacon of lightSunbun is a glorious beacon of lightSunbun is a glorious beacon of lightSunbun is a glorious beacon of light
That explains why they've been discontinued (supposedly)...
  #39   Spotlight this post!
Unread 04-01-2009, 19:30
All 4 of the ones we found (& more other teams found) at the store were labeled (c)2007 & in a box shown here (or just loose from being played with at the store):
The ones in the kit have a simple tag on them & say (c) 2009.
Makes sense they were discontinued, & possibly the company was contacted by FIRST to make new ones??
I'm just guessing here though.
edit: Btw, I should probably give credit where credit is due for the picture.
Thanks Team 228 for the pic on FB I linked here! lol
  #40   Spotlight this post!
Unread 04-01-2009, 19:35
GregW11's Avatar
GregW11 GregW11 is offline
Mad-haired biker man
FRC #2261 (Casa MESA)
GregW11 is on a distinguished road
Send a message via AIM to GregW11 Send a message via MSN to GregW11
They were probably "discontinued" because FIRST gave such a massive order for them...
  #41   Spotlight this post!
Unread 04-01-2009, 19:42
DonRotolo's Avatar
Back to humble
FRC #0832
Thanks for the helpful tip; our was "broken" within an hour of getting it (by 12:40 at kickoff, to be exact), but I too noticed that it was a manufactured joint as opposed to something actually snapped. I'll manipulate it back on Monday and maybe add a dab of adhesive in there with a needle or something.
  #42   Spotlight this post!
Unread 04-01-2009, 19:48
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
I noticed that when the balls we purchased at Wallmart break straight across the band at a 90 degree angle, however the bands on balls from kickoff seemed to have broken at an angle creating a sharp point that would poke through the fabric.
I wonder if the (c)2007 balls are constructed slightly differently from the (c) 2009 balls?
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
  #43   Spotlight this post!
Unread 04-01-2009, 19:51
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
[quote=Elgin Clock;791553]
I felt a tounge & groove/ dovetail type connection on the end of the plastic strip & was able to manipulate it within the fabric and snap it back together. All the years of hacking & fixing parts as part of the field reset crew is paying off I guess. lol[quote]
One of our teammates went to Wall Mart to buy some orbit balls, but all the balls were broken. He talked to the manager and was able to buy them for 2 dollars each instead of 10. While we were tossing them around during the meeting one of our other teammates discovered what you found and we were able to fix most of them.
Also, it wouldnt hurt to practice with some broken balls, thats why the teammate bought them. There is a very high chance that you will be playing with broken balls at a competition, and you want to be able to accommodate for that.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
  #44   Spotlight this post!
Unread 04-01-2009, 20:03
Darkcrosbone Darkcrosbone is offline
Master of....nothing actually...
FRC #0956
Darkcrosbone will become famous soon enough
What do you expect they are made in China and sold at Wal-Mart..... that's like THE single worst combo for quality of products in the world!
  #45   Spotlight this post!
Unread 04-01-2009, 21:29
I'm sure we'll see pictures of both without the fabric on them as teams destroy these in practicing with them.
Source for Orbit Ball Cory Kit & Additional Hardware 142 08-01-2009 19:10
pic: Orbit Ball Packaging Tom Schindler Extra Discussion 19 06-01-2009 13:17
pic: Orbit Ball Packaging Tom Schindler Extra Discussion 0 03-01-2009 15:41
Falcon 1 makes orbit! Ian Curtis Chit-Chat 5 05-10-2008 01:40
new balls vs. old used up balls agndoggieboi General Forum 31 22-02-2006 14:11
