Re: New wheels / floor and encoders for position.
Why couldn't you use encoders with slipping wheels? The sensors will certainly tell you actually how fast the wheel is spinning. Maybe you can use that information with an expected PWM signal vs. speed curve for traction control?
For example, if you observe that the wheels suddenly start spinning from a low speed to a higher speed, assume that slippage is occurring and reduce the drive signal. Cars are really starting to take advantage of traction control. Maybe FIRST robots can learn from them? Russ |
| 4 encoders + mecanum wheels programing | Smoking_Gun | Programming | 4 | 18-01-2007 23:43 |
| Friction coefficients for Omni wheels and Mecanum wheels from AndyMark | Andy Baker | Technical Discussion | 11 | 16-12-2006 19:40 |
| Testing and Cause of Failure for Encoders and Hall Effect sensors | ChrisH | Electrical | 28 | 19-09-2005 01:07 |
| I think its time for some new wheels | Matt Reiland | Rules/Strategy | 1 | 24-03-2002 19:02 |
