Go to Post Band geek FIRST geeks = uberparty! - Nuttyman54 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 03-01-2009, 23:12
wolfeman wolfeman is offline
Mentor, Team 2590
FRC #2590 (Nemesis)
wolfeman is an unknown quantity at this point
c-base chassis issue?
As we were picking up this year's KoP, the person
showed us a page describing a possible problem
with the c-base KoP chassis. They said a complete
description of the problem was on-line and you'd have
to ask for a replacement part if you had the problem.
It had something to do with the fit of the corner connectors
into the rails.
I can't find any mention of the "problem" on the FIRST site
or the Andy Mark site... Anyone pay closer attention
than I did and know what we should be looking for?
Unread 03-01-2009, 23:17
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Re: c-base chassis issue?
Yup, we got the same information at our kick off. Seems like someone made a mistake on machining the parts.
All but 2 of our corner rails fit together. They were both oversize by about .090, and one has a bit of the casting still left in one of the slotted holes. Does Andy have any recommendations on fixing this or should I just throw it on our mill and take it off?
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 03-01-2009, 23:27
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
If you have a mill to take the .009 off, I would just do it that way.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 03-01-2009, 23:33
quixeger's Avatar
quixeger quixeger is offline
FRC #0604 (Quixilver)
quixeger is an unknown quantity at this point
If milling it is an option, it may be faster and more convenient. Ours are a tight fit, but they fit well. If the parts were too narrow, it would be obvious. If all else fails, break out the hammer!
Unread 03-01-2009, 23:37
Lowfategg's Avatar
AKA: Tyler Moser
Its not .009 its .090. Probably just going to do that since I don't think its worth shipping new ones.
Milling is not the problem (I like using our Bridgeport), but I can't believe how off they are.
Unread 03-01-2009, 23:56
Yea i have to agree with that. I like AM products but that doesn't seem like a good first impression on new teams. just imho
Unread 04-01-2009, 08:33
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
What's the internal clearance of the C-base rails? I'm going to mill down some brackets for another team, but I only have the brackets and not the C rails.
The oversize brackets measure 1.095".
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 04-01-2009, 10:32
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Just to make things easier to understand, sometimes mistakes happen. In this case a bad run or two of this corner connectors happened, but was only caught later and too late to fix all of them. AndyMark had to have all these c-bases shipped out to FIRST about a month ago so all teams could get their kits. They did recognize that there are some defects and there was an email sent out. This was not a wide spread problem among all of FIRST but rather, there are some bad connectors out there.
I personally love all of the AM products and have not had one problem ever with their quality. Even if you do recieve a bad product, AM will often replace the defect free of charge. Talk about customer service!
Also, this is the first year that AM is providing the kit chassis. Big order, small deadline. Some small mistakes are gonna happen.
Unread 04-01-2009, 10:34
None #0612
Do you have a copy of the email? Does it contain the correct dimensions?
Unread 04-01-2009, 11:04
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
This issue was a known problem before yesterday. Kickoff sites received boxes with replacement pieces to be issued to teams with defective parts. If they run out of replacements, contact andymark, andy@andymark.biz, and they will handle your issue as soon as possible. Remember, when producing parts in such bulk quantities, there are bound to be some that are a bit off.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Gone Fishin'
I personally do not, but will and try to track one down for you. One should have been sent to each teams main contact.
Unread 04-01-2009, 21:46
None #0612
I found the correct dimension of the corner brackets here:
http://andymark.biz/am-0212.html
It should be 0.995" thick. The ones I have are 1.095".
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
Knowledge Base Leon Machado IV Programming 15 02-08-2005 12:24
Important Issue! archiver 2000 7 23-06-2002 22:37
Delphi Base archiver 1999 0 23-06-2002 22:03
