Go to Post I wouldn't want to replay Lunacy -- the Moon is a harsh mistress! - Richard Wallace [more]
Unread 04-01-2009, 03:36
dtengineering's Avatar
AKA: Jason Brett
Re: 2 Motors is Faster?!
Originally Posted by Hachiban VIII View Post
Having taken my fair share of physics I do not for the life of me understand how this is possible.
More force should equal greater acceleration, for the same mass. Correct?
They will reach the same speed, but the 4 motor bot will accelerate faster.
Notice the coefficients of friction published in the manual. The static coefficient (where the wheel is NOT skidding) is .6 the coefficient of dyanamic friction (where the wheel IS skidding) is .5
If a four motor drive and a two motor drive are both given the same input signal the four motor drive will generate twice as much torque. This will make the wheels skid (spin freely, do a burnout, whatever you want to call it) sooner than with a two motor drive. At this point you have shifted from static to dyanamic friction.
As soon as that happens, your friction, and thus your accelleration, drops by almost 20%.
It is quite possible for four motors to be equally as fast as two on this surface, but since the determining factor is traction, teams will have to build their robots to avoid spinning their wheels in order to achieve maximum accelleration and pushing power.
Jason
Unread 04-01-2009, 03:43
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Actually, I think they were 0.05 and 0.06. They're really easy to slide....
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 04-01-2009, 08:32
President, VEX Robotics, Inc.
This was posted in another thread, but here are the equations:
General force equation (assuming constant mass and somewhat constant accel which is good enough for now):
F= mass * accel
The wheel to floor interaction is governed by this equation:
F = mass * g * COF (Coefficient of friction)
Set the equations equal to each other and solve for acceleration:
accel = g * COF
So your maximum acceleration is entirely based on the planet you are located and your coefficient of friction. Since the GDC couldn't control where we play the game, they simulated this by mandating a certain COF for all.
Assuming the COF is actually 0.05, then our maximum accel is 32.2 f/s^2 * 0.05, or 1.61 feet / sec^2
Anyone with more acceleration than that will slip. This is not about 1 motor or 2, but about how we manage acceleration.
For those of you that think this doesn't make sense, just think of this:
While it is true you can get more pushing force from a higher weight, it is also true that you get less acceleration due to the increased mass. This trade off is the center of drive base design for this year's game. If you can control acceleration, then you will control the game play.
Unread 04-01-2009, 08:51
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Okay, so I think we all saw the demo where Dean and Dave race a 2 motor robot against a 4 motor robot and they reach the finish at the same time.
So did they reach the end at the same time simply because the 2-motor bot's lightness made up for its lack of power?
After several transmission/motor swaps in '08 our team pretty much convinced ourselves that 4 motors was ALWAYS the way to go.
4 motors give out too much torque, which when there is low traction just spins the wheels. If you have ever watched a drag race where a car didn't heat up the tires well, they go, but also just spin the tires down the track. The trick for this year is finding the right amount of torque i think.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 04-01-2009, 10:19
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Not quite true. You can gear the output of 4 CIMS so that your wheels won't slip (Read Pauls post above). That being said, I don't believe you'd gain much by doing so.
@ Paul Copioli,
Technically I believe that the wheel to floor interaction is governed by
F = CoF * downward force (which usually is gravity * mass, but can have other forces interacting with it as well)
___________________
- Tennyson, Ulysses
Unread 04-01-2009, 10:52
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Because of the extremely low friction (mu=.06), the max acceleration a robot can experience is well below what the two motors can provide, so the max acceleration of a two/four motor drive are the same. HOWEVER, i think the 4 motor drive could have a much higher high speed. However, i don't think you could readily attain it on the field because the field is actually pretty short.
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 04-01-2009, 11:12
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Nor do I think you want to. Remember everyone that you'll need to stop too, and that also requires traction
___________________
- Tennyson, Ulysses
Unread 04-01-2009, 11:18
paulcd2000's Avatar
AKA: Paul Dagnelie
that is a very good point... while refs will be less ready to issue ramming penalties, deliberately ramming into the end wall at high speed is probably still discouraged.
My team considered using raisable and lowerable wheels as brakes, angled perpendicular to the direction of motion.
Unread 04-01-2009, 11:21
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Not alloew according to <R06>
<R06>
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted. The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads, alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game
___________________
- Tennyson, Ulysses
Unread 04-01-2009, 11:27
paulcd2000's Avatar
AKA: Paul Dagnelie
that.... is a good point. i imagine our rules guru would have caught that, but thank you.
Unread 04-01-2009, 11:28
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
<R06>
A wheel perpendicular to the direction of travel can meet all of the criteria of this rule. The tread of the wheel is contacting the ground and the wheel's axis of rotation is parallel to the ground.
If having wheels skid sideways violated this rule, wouldn't all teams violate it at some point during a match as they're pushed around by their opponents?
--Madison--
...down at the Ozdust!
Unread 04-01-2009, 11:37
paulcd2000's Avatar
AKA: Paul Dagnelie
If having wheels skid sideways violated this rule, wouldn't all teams violate it at some point during a match as their pushed around by their opponents?
This may be something that will get updated in future rule sets. I agree that as stated, it doesn't forbid it, but i would be careful about designing a robot that way.
Unread 04-01-2009, 11:38
Mad Scientist
AKA: Me
FRC #2040 (DERT)
In his application, the wheels are purposely not in their "normal" orientation.
___________________
- Tennyson, Ulysses
Unread 04-01-2009, 11:40
paulcd2000's Avatar
AKA: Paul Dagnelie
"normal" as specified only refers to vertical orientation, not which way it's facing.
Unread 04-01-2009, 11:48
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
I do not believe that they meant "normal" when they say "normal".
I beleive that they are using the word "normal" to mean perpendicular to the floor. As long as the rotational axis is parallel to the floor, then the wheel is being used in it's "normal" position.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
pic: Faster Than A Speeding Bullet Athleticgirl389 Extra Discussion 10 04-03-2008 17:55
When a Robot Does Rounds Patients Get Faster Discharge JohnBoucher Math and Science 0 16-07-2007 08:03
One Side Drives Faster than the Other. Craig1989 Technical Discussion 18 12-02-2007 12:19
Which is faster? Gary Bonner Programming 4 27-02-2005 00:51
