Go to Post The game starts, we learn, the game changes, we learn some more, the game changes again, we learn even more . . . - Bill Moore [more]
Unread 24-06-2002, 00:16
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
pBasic
Posted by Robert Hennessy at 2/4/2001 10:59 PM EST
Student on team #254, Cheesy Poofs, from Bellarmine College Preparatory.
I am having great difficulty trying to understand the shiftin and shiftout functions. What is the cpin exactly? Is it user-defined or is there a specific pin that it must be defined as? Does it have to connect to a specific part of a sensor? Also, how do you access the robot interface internal clock? Thank you for any help in advance.
#0047 (ChiefDelphi)
hey...
Posted by EJ at 2/5/2001 2:09 AM EST
Student on team #254, Cheesy Poofs, from Bellarmine.
In Reply to: pBasic
Posted by Robert Hennessy on 2/4/2001 10:59 PM EST:
when did u start helpin out w/ the programmin? that's Jay's job...has he been slackin of...??
#0047 (ChiefDelphi)
Re: pBasic
Posted by Lloyd Burns at 2/5/2001 2:16 AM EST
Other on team #188, Woburn Robotics, from Woburn Collegiate and Canada 3000, ScotiaBank, Royal Bank Financial.
In Reply to: pBasic
: I am having great difficulty trying to understand the shiftin and shiftout functions. What is the cpin exactly? Is it user-defined or is there a specific pin that it must be defined as? Does it have to connect to a specific part of a sensor? Also, how do you access the robot interface internal clock? Thank you for any help in advance.
. SHIFTOUT/IN is not needed in the RC, as without tampering, you cannot access the pins on the pBasic interpreter. For other purposes, yes, you must designate a pin as cpin (as is done for fpin with the RC's SEROUT/IN commands).
. To access sensor number # (# = 1 to 7), change the value of the c_sensor# CON in the list from 0 to 1, and in the SERIN statement, in the appropriate place in the variables list, have a variable ready to receive the value.
. If you need timing, check the rate that the "basic run" LED on the RC is flashing: it should take about 80 ms to blink on then off, or, it should come on 125 times in 10 s. If this is the case with your final program, then each loop through your program takes 40 ms, since the LED is toggled (turns on if off, off if on) once per loop.
. The minimum loop time is determined by the OI, which sends a new package of data no more quickly than once every 40 ms. (The way to extend it is to write a complicated loop.) Every packet has a packet number (accessed as with sensor#, as explained above, by reading it), so if you note the packet number when you turn something on, and wait until the packet number is the same again, you will have to wait 256 * 40 = 10 240 ms or 10 and a quarter seconds. You can also subtract the old value from the new one to tell how many periods of 40 ms you have waited (if less than 10.24 s).
. The variable delta_t tells how long your loop is taking, but since the communications are generally good and the loop time in a particular program won't change unpredictably, forget delta_t, time your loop, and write the final program with that time value in mind.
Hope this helps
#0047 (ChiefDelphi)
bad data changes loop time
Posted by Joe Johnson at 2/5/2001 5:58 AM EST
In Reply to: Re: pBasic
Posted by Lloyd Burns on 2/5/2001 2:16 AM EST:
The loop time can jump around quite a lot if you have a noisy radio condition or if another radio is stomping on you radio signals (for instance in the pits on channel 40).
I recommend that you use delta_t or packet_num to keep track of time rather than simply counting loops.
Joe J.
[IMG] code is Off
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
RoboEmu 1.09 (supports PBASIC 2.5) rbayer Programming 22 21-01-2003 17:22
PBASIC Loop Speed? archiver 2001 3 23-06-2002 23:46
