Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
Unread 03-01-2009, 21:06
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
What if we want to use the camera to track orbit balls?
I believe that the most obvious (and intended) use for the AXIS camera is tracking trailers. They do have bright pink and green posts, after all.
But, what if we want to track the orbit balls? You may say "well, go right ahead," but each team only got one ball in the KOP. We may not be able to get more of them, and we are not sure of colors those around us got.
This really would only be useful in autonomous of course, but with all those balls flying into the crater and the inevitable large number of missed ones, I was thinking it may be more productive to use the same manipulator in autonomous that the team was planning on using for teleop to pick up the balls.
Thoughts?
Team 2052- KnightKrawler
Mentor and volunteer
Unread 03-01-2009, 21:32
Dracco1993's Avatar
Dracco1993 Dracco1993 is offline
AKA: Jordan Miller
FRC #1741 (Red Alert Robotics)
Dracco1993 is an unknown quantity at this point
Re: What if we want to use the camera to track orbit balls?
I think you will have a had time telling the balls apart. The moon rocks and the empty cells are so close in coler. I think it would be cool to try though.
Jordan Miller
___________________________________________
2010 Dean's List Semi-Finalist, Boilermkaer Regional
FRC 1741 --- Mentor
Vex 323a --- Mentor
Unread 03-01-2009, 21:37
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
If you use the NI Vision Assistant to start off the code to track the balls, you can just import pictures from either the camera or your computer - hence you can download someone's pictures that have all the balls in nice quality.
I think its a good idea and all, but I think where you will most likely have the most trouble is getting a good acquire of the balls via the camera, due to the small color area, the similar colors, and the variable lighting. It probably could work and will work, but I doubt it would be reliable enough to control the robot with.
-Tanner
Unread 03-01-2009, 21:39
Dracco1993's Avatar
AKA: Jordan Miller
Talking Re: What if we want to use the camera to track orbit balls?
You could do it with the super cells though.
Jordan Miller
FRC 1741 --- Mentor
Vex 323a --- Mentor
Unread 03-01-2009, 21:55
AKA: Bryan
I agree that it would be more difficult to acquire good images on the field. We may try it out then decide whether to continue with it.
As for color similarity- We would probably either just go for the moon rocks, or if we get an ally capable of getting a super ball, that. That way, we wouldn't have to worry about similarity between the empty balls and moon rocks.
Unread 04-01-2009, 08:23
Dracco1993's Avatar
AKA: Jordan Miller
Exclamation Re: What if we want to use the camera to track orbit balls?
Sounds like it might work...but if the camera thinks there are two moon rocks on the playing field but they are realy both empty cells and you pick them up then you just got penelty.
Jordan Miller
FRC 1741 --- Mentor
Vex 323a --- Mentor
Unread 04-01-2009, 12:15
bayesianlogic bayesianlogic is offline
ekzept
AKA: Jan Theodore Galkowski
bayesianlogic is an unknown quantity at this point
Lightbulb Re: What if we want to use the camera to track orbit balls?
Unless it's against the Rules (don't know), y'might consider adding additional, cheaper cameras. There are "pet and surveillance" netcams available for under US$100.
Also, y'might look at transition edges in scans of the Moon Rocks on each color channel and use those as discriminating features.
Unread 04-01-2009, 12:27
Dracco1993's Avatar
AKA: Jordan Miller
We have not found a rule yet that says that you can not add more cameras but we will have to see when the fourms open. If you had 2 cameras tou coulld also use trianglelation to find the distance on an opposing trailer.
Jordan Miller
FRC 1741 --- Mentor
Vex 323a --- Mentor
Unread 04-01-2009, 13:39
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
you dont need two cameras to find the distance of a trailer because you know the height of the camera,the height of the trailer, the tilt, and the pan. that is all you need and then you do some trig.
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 05-01-2009, 00:14
ekzept
"... but there's always more than one way to do it!" Need? Who said anything about need? Besides, a little study of the pixellation of those Moon Rocks suggests finding a stable visual feature will be a challenge, let alone tracking them. The target on the trailer looks pretty good visually, though. Wonder how much their gonna wobble?
Unread 12-01-2009, 21:10
Dracco1993's Avatar
AKA: Jordan Miller
You are right, but as we have found from tests the camera some times has a has a hard time getting the disstance corect.
P.S Sorry about my spelling.
Jordan Miller
FRC 1741 --- Mentor
Vex 323a --- Mentor
Orbit balls breaking Greg Needel General Forum 88 20-02-2009 12:57
WE WANT YOUR BALLS! Trav-O Chit-Chat 21 10-04-2008 22:21
Camera Works Well with the Balls! JHale Programming 10 01-02-2008 00:04
Which operating system do you use/want to use? neutrino15 Programming 17 12-01-2008 00:05
Track balls off the overpass in Hybrid mode- who scores? Japper Rules/Strategy 1 07-01-2008 11:24
