Go to Post Getting that degree is the reason for going to college. Failing out of school because you mentored isn't really a good reason. - [more]
Unread 04-01-2009, 09:10
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
New wheels / floor and encoders for position.
It is great that First included encoders and the ability to mount them to the gearbox. It's too bad that combination will be effectively useless this year. With the limited traction, there will be so much wheel spinning, as well as lateral sliding, that gearbox encoders will not give any useful information about where the bot is, and what it's doing.
<R06> talks a great deal about what wheels can be used for traction, and that no devices may be used to increase traction. What about a high traction wheel that touches the ground, but does not affect traction? Say, a wheel with an encoder attached? The way I interpret the rule, this would be acceptable.
Any disagreement?
Former Mentor Team 1771
Former mentor Team 4509
Unread 04-01-2009, 09:42
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: New wheels / floor and encoders for position.
The thing you would have to ensure is that the wheel can offer no resistance when pushed sideways (which is pretty hard). Even a caster design would offer some form of resistance until its direction was changed.
Unread 04-01-2009, 09:50
martin417's Avatar
AKA: Martin Wilson
Actually, a caster was what I had in mind. I believe that any resistance from the caster will be at least an order of magnitude less than wheel friction, so in engineering terms is "negligible", therefore can be ignored.
Unread 04-01-2009, 09:58
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
If the wheel was mounted so the axis of rotation was fixed, it would provide lateral traction. Even if the wheel was mounted so it could swivel, it would provide an instantaneous amount of traction while the wheel swiveled to its new position. The only way I can see this feasible is if you mounted a sphere in the middle, like the ball for an old mouse. Even then you would have to prove to FIRST that it provided no additional traction. Unfortunately, I don't think they would accept this.
You could mount a wheel that was not powered. As long as you have good bearings that provide negligible friction in the axle, it won't slip. An encoder could be attached to the axle. The issue with this is that you loose precious traction with each wheel that touches the ground that is not powered. If your willing to go this route however, you could mount a wheel in a perpendicular direction to receive encoder values for both the x and y axis. The wheels have such little traction, a wheel in the perpendicular direction won't resist motion provided by the other wheels.
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 04-01-2009, 10:17
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Why couldn't you use encoders with slipping wheels? The sensors will certainly tell you actually how fast the wheel is spinning. Maybe you can use that information with an expected PWM signal vs. speed curve for traction control?
For example, if you observe that the wheels suddenly start spinning from a low speed to a higher speed, assume that slippage is occurring and reduce the drive signal.
Cars are really starting to take advantage of traction control. Maybe FIRST robots can learn from them?
Russ
Unread 04-01-2009, 10:30
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Any disagreement?
Not quite correct
<R06>
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted. The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads, alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game.
R06 does not stop you from increasing traction, it just prevents you from using anything else to provide traction
Negligible traction is still traction.
Russ
Traction control and accelleration control will be key this year to winning alliances. IMHO
___________________
- Tennyson, Ulysses
Unread 04-01-2009, 11:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It looks like now is a great time to start programming! Traction control and robot position/velocity/acceleration information could really help a team control their robot.
Those of us who don't have to drive on icy roads are probably at a disadvantage....oh well....
Unread 04-01-2009, 11:25
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I think this is the 1st time I've heard that driving in icy conditions is an advantage
___________________
- Tennyson, Ulysses
Unread 04-01-2009, 11:32
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
We've been exploring intelligent slip-prevention systems, and that would be quite the challege even without trying to use the camera to track and shoot balls at a target... we're probably going to try but it will be tough.
As to the idea of providing another wheel which would be measured with the encoders, perhaps a trans-wheel? it would have extremely low friction when moving sideways, and trans-wheels are not "wheels, tracks, legs, or other devices intended to provide traction"
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 04-01-2009, 11:44
MrForbes's Avatar
AKA: Jim
How about using and old ball type computer mouse? it's a sensor...so it's not intended to provide traction. I wonder if they're still available COTS?
Unread 04-01-2009, 11:51
Mad Scientist
AKA: Me
FRC #2040 (DERT)
My guess is (for official rules wait for the FIRST Q&A forum) that if it contacts the floor it will be illegal.
How about a IR mouse? It doesn't need to contact the surface.
___________________
- Tennyson, Ulysses
Unread 04-01-2009, 11:54
paulcd2000's Avatar
AKA: Paul Dagnelie
I don't know how optically "interesting" this floor will be. namely, is there going to be a visible difference between one spot on the floor and another? it might need something as precise as a laser mouse. it's an interesting idea.
Unread 04-01-2009, 12:02
I was part of a group that used optical mice as encoders. It was a bit of a pain in the neck to start, but worked well once it worked at all.
One idea I'm fiddling with is measuring the current to the motors to approximate torque. A 20% difference between slip and grip should be measurable. I wish we had CAN this year, since the Jag's have that feature built in.
Unread 04-01-2009, 12:04
minisimon's Avatar
minisimon minisimon is offline
AKA: Simon Helmore
FRC #0238
minisimon will become famous soon enoughminisimon will become famous soon enough
Your encoder wheel doesn't have to rob (much) traction from the rest of your robot. If you mount a fifth rover wheel on a swing arm or something similar, it will use only its own weight for traction. Then it's just a question of how good of a bearing do you need. ABEC 7 anyone?
Unread 04-01-2009, 12:32
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Anti-lock brakes in cars use accelerometers plus wheel encoders to detect wheel slip.
4 encoders + mecanum wheels programing Smoking_Gun Programming 4 18-01-2007 23:43
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Testing and Cause of Failure for Encoders and Hall Effect sensors ChrisH Electrical 28 19-09-2005 01:07
I think its time for some new wheels Matt Reiland Rules/Strategy 1 24-03-2002 19:02
