Go to Post I've always thought that what makes an average person exceptional is not their inability to make mistakes, but rather their ability to recognise, rectify, and learn from them. - artdutra04 [more]
Unread 04-01-2009, 13:35
Dan2081's Avatar
Dan2081 Dan2081 is offline
AKA: Dan
FRC #2081 (Icarus)
Dan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to behold
Crab Steering on Regolith
In Lunacy this year, will a crab steer be allowed in the form of a brake?
I know the rules specify that all wheels must be in orientaion with the robot, but with crab steer, you could possibly turn your wheels to stop you from gliding more efficiently before you change directions.
Is this a legit idea or do the rules not permit it?
09 IRI #7seed and Semifinalists
09 BMR GM Industrial Design
08 BMR Engineering Inspiration
08 Archimedes #5 seed
07 BMR Rookie All-Star
Unread 04-01-2009, 13:42
nitsua60 nitsua60 is offline
FRC #2785 (Prometheus)
nitsua60 will become famous soon enoughnitsua60 will become famous soon enough
Re: Crab Steering on Regolith
Originally Posted by Dan2081 View Post
...you could possibly turn your wheels to stop you from gliding ....
<R06> Seems to create a problem with any type of steered wheel this year: if the axis of rotation of the wheel has to be parallel to the ground, then you can't rotate the wheel about a vertical diameter, as you typically would while steering. However, according to the rule you could rotate the wheel about a horizontal diameter and make use of the higher transverse coefficient of friction do propel the bot. I hope we see some clarification of <R06>.
Unread 04-01-2009, 13:46
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
The only rule I'm aware of which could limit it is R06, and as I read it I don't see any problems with your idea.
However, you won't get more stopping force from that since the friction with the ground would still be equal. My guess would be that you'd have better luck either running the wheels in reverse, or at least equal results by using encoders and some simple programming to prevent the wheels from moving when you want to stop.
Originally Posted by <R06>
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted. The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads, alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game
Eric Haskins KC9JVH
Unread 04-01-2009, 13:50
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
horizontal axis of rotation just means that you have to put the wheels flat on the ground. the horizontal axis is your axle so you can spin your axle on a horizontal plane .
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 04-01-2009, 13:55
AKA: Eric Haskins
As i interpret this rule the key part is
The axis i believe they're referring to is the axle. So then I interpret it as saying the wheel must remain vertical, relative to the ground, but doesn't necessarily need to maintain its orientation relative to the robot chassis.
I could be misinterpreting this, so if it a serious issue for your design it would be best to contact FIRST for clarification.
Eric Haskins KC9JVH
Unread 04-01-2009, 14:13
cj.reeves cj.reeves is offline
FRC #2589
cj.reeves is an unknown quantity at this point
why not try using a massive flywheel and rev it up to a couple thousand rpm, next turn the flywheel with your windsheild wiper motor in the direction you want to go, see how the robot reacts to this inertia, if it does not turn on a dime in zero friction enviornment why would nasa use it on their shuttles and other vehicles?
Unread 04-01-2009, 14:24
DonRotolo's Avatar
Back to humble
FRC #0832
This is known as a "reaction wheel". You should research if it will provide more turning capability than what you can already do with a standard wheeled drivetrain. If it will, then use it, but if it won't....
EDIT: Oh, typically you would use a reaction wheel horizontally, speeding it or slowing it rapidly to transfer the angular momentum to the robot chassis. What you propose is a simple gyroscope, which could also be effective.
Unread 04-01-2009, 14:25
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
I was wrong... about the flywheel, still think it's risky
Secondly, the crap drive concept seams legal, since the wheel is turning about a horizontal that would be parallel to the playing surface, the wheel is able to turn becuase it whole drive assembly/input power shaft can turn with it. Those rules make it so teams don't lay wheels on their side (axis of rotation is perpendicular with the plane of play), or thats what I think.
Is now an engineer thanks to FIRST.
Unread 04-01-2009, 14:30
FRC #2589
I am not using it to acelerate but to turn in tight conditions, the primative skid (coded) tank steering or omni steering is old news and the wheels would skid out of control. this steering works in SOLIDWORKS and it can cause the robot to turn about an axis without interacting with the ground but under no circumstances will it acellerate the robot.
Unread 04-01-2009, 14:58
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Talking Re: Crab Steering on Regolith
It hasn't seemed to have been mentioned here, so I'll point it out.
You may wish to consider that especially on this playing surface, the orientation of the wheel doesn't really matter when it comes to putting on the breaks against a pushing robot. Any of the motors generally chosen for the drive train of a robot are more than capable of holding the wheels locked (not rotating) when pushed on this surface - the friction between the wheel and playing field is much less than the force required to overcome the stall torque of the motor. That said, the orientation of the wheel to the direction of undesired motion doesn't really matter.
Additionally once you are sliding, it will be very difficult to regain control of the robot by slamming on the gas in the direction you want to go. Your already sliding wheels would still have very little traction, so it would take a while to regain control of your robot.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 04-01-2009, 15:43
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
So this hasn't really been debated yet but would a crab drive even be particularly effective on this surface?
It seems to me that the lack of friction would make it so that turning the wheels would not really result in a change of direction quickly. It could actually be worse since the wheels would be skidding and thus kinetic friction would apply.
Mentor 2415
dtengineering's Avatar
AKA: Jason Brett
Note that the published values for the wheel's transverse coefficient of friction are almost twice that for the inline coefficients.
In other words, yeah... turning the wheel 90 degrees to your direction of travel will bring you to a stop more quickly than just stopping the wheel.
The downside is that you will be in a skid at that point and will have sacrificed directional control.
Jason
Unread 04-01-2009, 15:52
AKA: Sean
So based off of the transverse frictional value a crab drive could actually be effective. It seems like the programming might be even more difficult than a normal crab drive though to get full performance from the system.
Mentor 2415
Unread 04-01-2009, 15:59
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
How would the direction of the wheels dictate the friction any more than normal? Technically your "contact patch " doesn't grow or shrink any, and the wheels have no lip (read: they're rounded), so you don't have any edge to dig in to.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 04-01-2009, 16:01
AKA: Sean
That is something I dont understand either. The wheels are molded from a uniform material and there is no tread pattern so I dont see how friction would be different. Maybe it is due to the plastics grain or something like that.
Mentor 2415
pic: steering edomus Extra Discussion 10 05-06-2005 11:12
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
What is crab steering?? Adam Y. Technical Discussion 18 30-12-2002 08:12
tank steering archiver 2000 10 23-06-2002 22:28
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
