Re: Trailer Weight
They told us at the kickoff that the trailer weighs about 30 pounds.
Re: Trailer Weight
a team at VCU weighed it and said it was close to 40 pounds...and you could still push it with no effort on carpet
Re: Trailer Weight
Pushing it in the directin of it's wheels rotation and having it skid sideways along the floor are to different matters. The 2nd of which is compounded further by the fact your force is not bein applied directly through the wheels, but rather through the trailer hitch. |
Re: Trailer Weight
Re: Trailer Weight
(correct me if im wrong with my analogy...im not a physics major at ALL )for example, think of it this way. you and your younger sibling are spinning in a circle. you are the robot, and your sibling is the trailer. as you are spinning, or turning, things are all hunky dory. while you might be able to stop on a dime, your sibling, who is spinning in a larger circle, is generating a lot more centripetal (?) force, which makes it harder for them to stop. so while you might stop, they'll keep going for a little while longer. that extra amount of time that they move, while still attached to you, will pull you in the direction that they are going. the same principle applies while turning. i guess what im trying to say is, get that trailer built quick, so you can start seeing what type of difference it will make on movement, because its gonna make things extra...umm...fun. |
Re: Trailer Weight
Re: Trailer Weight
I went through and estimated the weights of all of the parts on the trailer per the drawings. My estimate is that the total weight will be 40.2, lose to the 40 pounds as noted in a previous post.
#8
Re: Trailer Weight
Thanks Mike!
| trailer dimensions | mackfix | General Forum | 2 | 03-01-2009 20:21 |
| Trailer Cover? | darkpheonix | Rules/Strategy | 1 | 03-01-2009 19:46 |
| Weight? Estmate weight? | Arkorobotics | General Forum | 21 | 29-01-2007 17:34 |
| To Trailer or Not to Trailer? | Carol | General Forum | 14 | 25-06-2006 18:14 |
| Wait...weight...weight!!!! | Greg Perkins | General Forum | 3 | 22-02-2006 07:42 |
