Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
  #106   Spotlight this post!
Unread 04-01-2009, 15:40
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Re: How can we drive on this new floor?
What if we did a air boat type drive train. where we take a floor fan gut the motor and replace it with a shaft and a belt drive to a few CIMS (or direct connect). Then our wheels would be attached to casters. To steer we would have directional flaps powered by servos on the back.
+: could defend the trailer if powerful enough, takes away some traction problem.
-: stopping could be an issue (but thats what brakes are for), and the power of the fan could not be powerful enough to move the robot.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
  #107   Spotlight this post!
Unread 04-01-2009, 15:43
adaptingthought adaptingthought is offline
AKA: Alecia Payne
FRC #2859 (Blaster Bots)
adaptingthought is an unknown quantity at this point
Im with the fan idea for propulsion. Not sure if it's legal though
  #108   Spotlight this post!
Unread 04-01-2009, 15:53
cj.reeves cj.reeves is offline
FRC #2589
cj.reeves is an unknown quantity at this point
You want as little interaction between the wheels and floor as possible, although the fan is risky there are other ways to move your robot without interaction with the sourounding medium. As we all know a tank steer or skid steer is out of the question a 40lb flywheel spinning at a couple thosand rpm spun by the windsheild wiper motor on the horizontal axis should spin the robot on a dime just how NASA stabalizes their satelites in space it works on SW 2008
  #109   Spotlight this post!
Unread 04-01-2009, 16:04
How would the fan not be legal? It could stay within size constraints, you would have to enclose it but that wouldn't be that hard if you use a premade fan, and you still use the wheels on the ground.
  #110   Spotlight this post!
Unread 04-01-2009, 16:07
But how would you move across the field? the flywheel would make you spin but the trailer would mess that up, plus to put in a fly wheel would take up a lot of space.
  #111   Spotlight this post!
Unread 04-01-2009, 16:41
Dan2081's Avatar
Dan2081 Dan2081 is offline
AKA: Dan
FRC #2081 (Icarus)
Dan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to behold
Can the battery power a large fan for 2:15' straight???
09 IRI #7seed and Semifinalists
09 BMR GM Industrial Design
08 BMR Engineering Inspiration
08 Archimedes #5 seed
07 BMR Rookie All-Star
  #112   Spotlight this post!
Unread 04-01-2009, 16:51
AKA: Alecia Payne
someone found a fan thats legal by FIRST regulations
http://www.modelflight.com.au/rc_mod..._micro_fan.htm
i dont know the calculations to find out how long the battery could power it though
  #113   Spotlight this post!
Unread 04-01-2009, 16:57
don't know might not but you only use the fan as the major draw of power off the battery i don't see why not. think about it using 4 CIMS to move a robot on wheels with high friction/wieght and a pnuematic system drained most of our battery last year. but if we where to use only the fan it would be 1-4 CIMs moving at most a 5 pound fan (im being very heavy) in a circle constantly, in my opion would not drain the battery that much.
  #114   Spotlight this post!
Unread 04-01-2009, 17:00
im not using any rules as backing here but from what i know as long as the fan is enclosed (no sharp/dangous appendages) and you use CIMs to power it not the motor that came with the fan (illegal motor) the fan would be legal
  #115   Spotlight this post!
Unread 04-01-2009, 17:16
GregW11's Avatar
GregW11 GregW11 is offline
Mad-haired biker man
FRC #2261 (Casa MESA)
GregW11 is on a distinguished road
Send a message via AIM to GregW11 Send a message via MSN to GregW11
Originally Posted by johnr View Post
Does this make any sense? Six wheeled bot. Four corner wheels driving forward and two side centered wheels driving backward as needed. Or, one wheel dead center of bot that would spin oppisite as needed. Then hand the whole thing over to programers. They can make it work.
I would guess this is roughly the setup you had in mind with wheels:
_ _
(with possibly more series of sideways and forward-facing wheels)
Vertical wheels are forward facing, horizontal are sideways facing, in case people don't know.
And that wouldn't exactly be difficult to program, but the operators would have to have incredible coordination, since assuming you're driving in tank mode it would require three joysticks (two for each set of wheels, plus one more to operate the side wheels.) Add more motors if you want additional sets of wheels, unless you can put three wheels on one motor...
Either that or have the side wheels spin in conjunction to the outputs of the joysticks (i.e. if left is spinning full forward and right is spinning full backward, the wheels will turn in the direction that will provide the most traction. I'd have to run a simulation to determine exactly which would be the best way, whether you want more turning force, causing the trailer to possibly fishtail, or less to stabilize it.)
Again, not apparently difficult to program.
edit: (with random concerns I think of)
The only thing I could see right now is collisions of of the chains (if they're used to provide the moving force for the wheels) from the forward/sideways wheels. Seems it could be remedied by using varying radii with the grabbers on the wheels (spaced the name of them) that move the chain.
  #116   Spotlight this post!
Unread 04-01-2009, 17:21
PowerOfKings PowerOfKings is offline
AKA: Jon
FRC #1891 (BullBots)
PowerOfKings is an unknown quantity at this point
Originally Posted by vivek16 View Post
Look, all the ideas with fans:
Why not take your 200 pounds of force going downwards, point that to a side, and use it as a means of propulsion? It would certainly be a lot more efficient than using the force to increase the traction (it will still be low traction).
-Vivek
The 200 pounds of force comes from the fact that it is a vacuum creating pressure underneath the robot so in a 10x10 area with 1 psi (pound per square inch) you would have 100 pounds of force. You would not have nearly the same force from simply the fan on the side.
However we calculated that it would only take 7 pounds of force applied from the side to start a robot moving sliding sooo...
  #117   Spotlight this post!
Unread 04-01-2009, 17:48
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Did anyone else see the size of that fan? Do you really think that would be worth buying 30 of those for a little bit more propulsion? Personally, I think its a waste of time, and how can we have tank treads if the rules state: "The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted."
  #118   Spotlight this post!
Unread 04-01-2009, 17:56
JagWire's Avatar
JagWire JagWire is offline
Team 1742 College Mentor
AKA: Tim Long
FRC #1742 (Shockwave)
JagWire has a spectacular aura aboutJagWire has a spectacular aura about
Send a message via AIM to JagWire
Unless I'm off my rocker, 200g of thrust means a little less than a half-pound of thrust? You'd need something like 14 of them to be roughly equivalent to the amount of force produced by frictional interaction from wheels.
I made that approximation based off a calculation of maximum frictional force by multiplying the weight (120lb.) by the *kinetic* coefficient of friction (.05 from the first manual), yielding a maximum force of 6lbs. to accelerate the robot. So, that's a lot of fans. Running all of them at their maximum of around 300 Watts each, that accounts for 4200 watts, and, I could be wrong, but I believe that would mean it would discharge one of the 12v 18Ah batteries in around 3 minutes.
So, that particular fan sounds pretty in-efficient to me. I would suggest looking for one with a much larger prop. Larger, slow moving props tend to have a higher efficiency (not to mention they tend to be a little safer). A larger prop would also mean more thrust, and fewer fans. Knock the number of fans needed down to 4 or so, and it would be manageable I think.
I'm still intrigued by the possibility of a fan-propelled bot. I think it would be quite spectacular to watch in action.
*EDIT*
This is all completely without regard to the legality of the fan and motor, merely assessing the viability of the particular product.
Team 1742: Shockwave
2006 Robot "Sprocket"
2007 Robot "Rampzilla"
2008 Robot "Trigonosaurus"
Aut viam inveniam aut faciam.
I'll either find a way or make one.
www.team1742.com
  #119   Spotlight this post!
Unread 04-01-2009, 18:03
JagWire's Avatar
AKA: Tim Long
I think they were referring to what is called "tank drive" which you can think of like driving a bulldozer, only without the tracks, just the wheels. The wheels on one side would operate together independently from the other side.
www.team1742.com
  #120   Spotlight this post!
Unread 05-01-2009, 12:47
chuckmerja chuckmerja is offline
FRC #1696 (RoboRevolution)
chuckmerja is an unknown quantity at this point
Interesting that game team used "traction" with respect to wheels etc, and didn't use the word "propulsion", thus maybe leaving a fan solution open to possibility. Hmm
2005 - Sacto quarterfinalist
2006 - Sil Valley quarterfinalist
2007 - AZ semifinalist, 2 judges awards, Woodie Flowers Award
2008 - smallest team from smallest school in FIRST - 3 person team!! - Seattle semifinalist
2009 - let's just say this bot would not have qualified for a trip to Mars
2010 - redoubled quality effort - won quality award and WINNER Utah Regional (first MT team to win an FRC regional) also won state FTC tourney (team 724)
2011 - Finalist UTAH regional
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
New skateboard... Just imagine the robotics drive applications this would create Elgin Clock Technical Discussion 8 21-07-2007 12:56
How can this be!?! Mike Rush Math and Science 6 09-12-2004 13:51
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How can we make this better? archiver 1999 6 23-06-2002 22:39
