Go to Post A robot is never "complete" - [more]
Unread 04-01-2009, 16:07
DonRotolo's Avatar
Back to humble
FRC #0832
Propulsion that does not involve driving wheels
Several threads discuss wheels, friction and traction.
I propose moving a robot around like a swamp boat. A 27" fan on each end, driven by 2 CIM motors each, with steering vanes, might allow for a far greater acceleration than wheels on the ground.
You'd still have wheels of course - I am not proposing a hovercraft (or eels) - they would just be mounted as casters, with no function other than supporting the weight of the robot against the playing field.
Two fans running in the same direction would push the robot. To slow down, reverse them both (no need to turn around). Run them both blowing outward, maybe you can blow moon rocks away from your trailer as the other alliance lobs them to try to score...
Steering is a little bit poor however. For this, we use a horizontal reaction wheel (think bicycle wheel with a heavy rim, spinning parallel to the floor). Driven by two FP motors at about half speed (to allow speed headroom both faster and slower), you would slow it down quickly - conservation of momentum would cause the rest of the robot to spin in the opposite direction. The same effect would occur, but in the other direction, but sharply accelerating the wheel. the wheel would be brought back to idle speed somewhat slower than during a steering maneuver.
An alternative to this would be a vertical flywheel (the axle would be horizontal) in the center of the robot which is turned opposite the direction you want to steer the robot. Gyroscopic effect would work to keep the wheel from moving, so the robot beneath it would move instead. This idea is not mine, I give credit to C J Reeves.
Thoughts and comments on these ideas are requested, along with other ideas for propulsion not involving driving wheels.
Don
Unread 04-01-2009, 16:20
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Re: Propulsion that does not involve driving wheels
Don- were you in my back seat driving back from NH? Uncanny....
will the battery allow it?
WC - tis the question
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 04-01-2009, 16:47
DonRotolo's Avatar
Back to humble
FRC #0832
Great minds think alike?
Anyway: The battery will certainly allow four 2.5" CIMs to be driven to near maximum output - our robot does that almost every year. Maybe we'll be near the limit after 2:20, but that also depends upon how it is driven. The real question is whether this will provide more propulsive force than 4 or 6 (or x) wheels on the graound, driven conventionally.
Test results will be posted ASAP.
Unread 04-01-2009, 16:53
dtengineering's Avatar
AKA: Jason Brett
In '06 we were contemplating a robot with fans that would sit underneath the goal and attempt to blow the poof balls away. The poof had a bit too much mass, but in this application.... it will be interesting to see how much air movement is required to deflect an orbit ball.
Of course, once you've got the fans, you could also use them to suck air from underneath the robot to increase your traction.
Safety is a concern, of course.
Jason
Unread 04-01-2009, 17:21
antoineft's Avatar
antoineft antoineft is offline
FRC #2609 (BeaverworX)
antoineft is just really niceantoineft is just really niceantoineft is just really niceantoineft is just really niceantoineft is just really nice
Also, does it seem conceivable that you could have the fans blowing overtop of your trailer all the time to stop all/some balls from being scored? Does this seem like a cheat of the game?
Antoine Trabulsi
Team 2609
Unread 04-01-2009, 17:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We were thinking of using a smaller high speed blower (leaf blower type) but decided that would not be safe because of the high air velocity.
Hopefully someone will build a swamp buggy on ice prototype soon
Unread 04-01-2009, 17:34
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Mathematically, this concept is possible. You'd need some extremely high-volume fans (4000 cubic feet per minute for 50N), and as your trailer filled up you'd lose a lot of your propulsion. The size of the fan required rules out quick reverses, not to mention that the structure of your robot ahead of the fan would reduce its efficiency.
I'm not sure why you'd want your wheels undriven though. You might as well make use of the 26 newtons of frictional force that the wheels provide. There's no good reason to simply have them be casters when they can provide as much propulsion as a big fan.
To see someone who ran the numbers, read drkiraco's post here
Unread 04-01-2009, 17:35
clark_noah's Avatar
clark_noah clark_noah is offline
FRC #1245
clark_noah has a spectacular aura aboutclark_noah has a spectacular aura aboutclark_noah has a spectacular aura about
Team 2609
I wouldn't think it would be cheating, but it would have to be pretty powerful to stop them if they are being directly dumped into your trailer....
it might work but it would have to be very very powerful, which means heavy most of the time....
Unread 04-01-2009, 17:36
roboraven15's Avatar
roboraven15 roboraven15 is offline
FRC #1188 (Oaktown Crewz)
roboraven15 is an unknown quantity at this point
Send a message via AIM to roboraven15
we have begun to descus the options of a fan boat type effect, but u have to remember those huge fan boats have very poor acceleration on the water, and from what we saw in the kickoff video the robots could accelerate just with some slipping and stuff. the fan you would use on your robot would be even smaller, and probally have less power to work with you can only pull 40 amps at max. the fans ability seems doubtful to be any better than wheels.
Unread 04-01-2009, 17:37
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
i was talking about this in another thread. see URL="http://www.chiefdelphi.com/forums/showthread.php?t=71037&page=8"]http://www.chiefdelphi.com/forums/showthread.php?t=71037&page=8[/url] well my idea for this is to mod a off the shelf floor fan (something with a protective cage) to use the CIMs to power the fan blades and then use servo turned fins to "guide" your air flow for steering. Then for your wheels you would just stick them on casters.
then for the power situation but if using my past experience becuse last year we where using 4 CIMS to move a robot (120lbs) on wheels with high friction/wieght and a pnuematic system. this drained most of our battery last year. but if we where to use only the fan idea it would be 1-4 CIMs moving at most 5 pounds of fan blades (im being very heavy). Then with no other major draw of power the batterys most likely won't have a problem with this type of drive train.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 04-01-2009, 17:45
King Duke's Avatar
King Duke King Duke is offline
FRC #0991 (Dukes)
King Duke is a jewel in the roughKing Duke is a jewel in the roughKing Duke is a jewel in the rough
Send a message via AIM to King Duke
http://www.treehugger.com/files/2008...antarctica.php
relevant... maybe
cool..... yes
Mr. Ames
#991 The DUKES!!!!! from Phoenix, Arizona
Cornell MineSweeper- Business is Booming.
Unread 04-01-2009, 18:17
feilmeier feilmeier is offline
FRC #0585
feilmeier will become famous soon enoughfeilmeier will become famous soon enough
At Bongle, did the 26 Newtons of frictional force come from each wheel, or from all of the wheels together, and how heavy was the robot? Anyways, a mentor and I had the same idea of having fans blowing like in a swamp boat. We calculated that a battery with an 18AH life would be capable of holding out for the length of the match, with a bit of time left over.
Unread 04-01-2009, 18:29
RobotLady's Avatar
RobotLady RobotLady is offline
FRC #0686
RobotLady is an unknown quantity at this point
On blowing balls away from the trailer, could you use pneumatic tubing to direct the force and just dump pressure from a tank to create an air jet of some sort?
Unread 04-01-2009, 18:37
Michael Hill's Avatar
hint: mini turbine-engine
Unread 04-01-2009, 18:46
tjwoodin's Avatar
tjwoodin tjwoodin is offline
The Maverick (Not McCain)
AKA: Tim Woodin
FRC #0885 (The Green Team)
Team Role: Student
tjwoodin is an unknown quantity at this point
Question Re: Propulsion that does not involve driving wheels
Also you could use a fan to blow above your robot to force it doen and increase traction but maybe thaat is a violation of the rules?
pic: Hey who's that driving the robot? Koko Ed Extra Discussion 10 24-03-2006 05:17
Driving omni-directional wheels VanZuiden General Forum 4 19-01-2006 22:59
Wheels & Driving Ryan Curry General Forum 3 13-01-2002 21:43
Heres a big problem that I think Discreet does not know what they are talking about. wes16zeus 3D Animation and Competition 9 09-01-2002 23:31
