Go to Post I'm 5'5", and I'm our team's drive coach. Our drivers are nearly always taller than me. In my case, it's not the driver's station that needs to be made of lexan...it's our drivers. - StephLee [more]
Unread 04-01-2009, 17:12
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Gyros and Accelerometers
Originally Posted by pogenwurst View Post
I'm a bit curious to know what teams didn't like about this method, as it's the one we're considering, but we've never done it before.
The short story is that since both the gyro and the accelerometer outputs an analog voltage, any connection made is extremely susceptible to electromagnetic interference, especially if the sensor is placed near a motor or solenoid. Additional connectors mean more points of weakness for the signal to deteriorate. A direct soldered connection is a more robust way to connect a wire to a pad than through an additional connector.
On a side note, if the interference gets too bad, you can always shield and ground the cable - doing that on an especially bad signal line can clean things up a little.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Accelerometers & Gyros for N00bs ManicMechanic Electrical 23 09-01-2010 18:21
accelerometers and gyroscope to control arm? Hazmatt Programming 10 11-02-2008 08:46
accelerometers and gyroscope to control arm? Hazmatt Technical Discussion 10 11-02-2008 08:46
Gyros and WPILib RyanW Programming 2 28-01-2008 14:05
mounting accelerometers & gyros wireties Electrical 2 26-01-2008 20:10
