Go to Post Never should an idea be ridiculed, because ideas are exactly that just an idea. - Tim Delles [more]
  #32   Spotlight this post!
Unread 04-01-2009, 18:03
JagWire's Avatar
JagWire JagWire is offline
Team 1742 College Mentor
AKA: Tim Long
FRC #1742 (Shockwave)
JagWire has a spectacular aura aboutJagWire has a spectacular aura about
Send a message via AIM to JagWire
Re: How can we drive on this new floor?
Originally Posted by Cyberphil View Post
Did anyone else see the size of that fan? Do you really think that would be worth buying 30 of those for a little bit more propulsion? Personally, I think its a waste of time, and how can we have tank treads if the rules state: "The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted."
I think they were referring to what is called "tank drive" which you can think of like driving a bulldozer, only without the tracks, just the wheels. The wheels on one side would operate together independently from the other side.
Team 1742: Shockwave
2006 Robot "Sprocket"
2007 Robot "Rampzilla"
2008 Robot "Trigonosaurus"
Aut viam inveniam aut faciam.
I'll either find a way or make one.
www.team1742.com
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
New skateboard... Just imagine the robotics drive applications this would create Elgin Clock Technical Discussion 8 21-07-2007 12:56
How can this be!?! Mike Rush Math and Science 6 09-12-2004 13:51
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How can we make this better? archiver 1999 6 23-06-2002 22:39
