Re: Tell me more about the regolith coating.
Can someone please post a video of just how slippery this stuff is. Not for me, necessarily, but for other teams and people. Maybe use another robot of yours, if you haven't already destroyed it. And if you can, use the Rover Wheels. That would be good for a lot of people. Thanks!
I can not post a video however it is a hard concept to imagine..we have regolith in one of our batroom walls...we moved the wheel across it and it seems the calculated friction the predicted is incorrect..with 130lb robots traveling at 10 mph with the coefficint of friction at .0021..it means u will drift 5-12 ft with a drastic turn...goodluck to anyone who can work around this issue...it is realy slippery...please try to practice this urself and then think of ideas...
Joey |
The bumps on the "regolith" make less of the surface area of the wheel contact it at once which decreases traction even more. It's not bad to walk on beause shoes are made of soft rubber, but we got a sheet of an almost identical product from Home Depot and it was unbelievable how little traction there was between it and the wheel. We couldn't find anything else that had such little traction paired with the wheel, the closest was some sort of hard granite looking tiling used in the cafeteria of my school which we may end up using as a practice area if we don't buy lots more of the plastic/fiberglass surface.
HOWEVER, be advised that when we went to pickup the kits, they had a sample of the field in FIRST HQ, and while my sneakers were the same, the snow we tracked inside made it MODERATELY slippery inside there on them material. Bottom line is, as long as the field stays dry, & no one spills some soda or water on part of the field (or ruptures a compressor hose, and/or leaks some gear oil on the field) then it SHOULD be ok to walk on from a team member's standpoint most of the time. Be cautions anyways, & always plan for safety first! |
Yeah my shoes were wet too. In order to see the field at kick off we needed, and living in WI, there is always snow and wet outside. I could tell that the slip was because of the mass amounts of wet shoes on the field, not the field itself. |
#7
In all seriousness though, like Elgin said, this stuff isn't slippery to the sneakered foot. |
#8
Alright, now Richard, just because you are spending all of your time sliding around on the highways between Missouri and Michigan, doesn't mean we have to make our emcees into hockey pucks as well!
![]() Last edited by catsylve : 09-01-2009 at 09:39. |
| Crab Steering on Regolith | Dan2081 | General Forum | 33 | 09-01-2009 16:35 |
| Tell MSNBC About Your FIRST Team! | Amanda Morrison | General Forum | 0 | 11-09-2007 09:33 |
| Show off your team website picture galleries and tell me a little bit about them!!!! | Elgin Clock | Website Design/Showcase | 14 | 30-06-2004 11:23 |
| powder coating | Ben.V.293 | Technical Discussion | 0 | 07-04-2004 22:46 |
| Tell us a little about yourself... | Dan 550 | Chit-Chat | 55 | 18-11-2002 17:37 |
