Go to Post A wise man told me a few nights ago, that it is important to own up to all your mistakes, so that others can see you doing that and wont deny and try to hide their own. - Josh Hambright [more]
Unread 04-01-2009, 17:39
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
Is pinning opposing robots trailers allowed?
Our team was thinking of building a robot that would pin other robot's trailers to the wall close to our alliances throwers so that way they could easily throw the rocks and cells into the trailer. We would do this by having an indent on the front of our robot the shape and size of half of the trailer. This indent would have bumpers all around it, so it would just be bumper to bumper contact. the indent would just fit inside the 38in. width requirement. I can't find any rules that would prevent this.
Unread 04-01-2009, 17:42
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: Is pinning opposing robots trailers allowed?
Just logic; If you stop, your trailer stops, and you become a easy target. For the other two robots, and the other 3 throwers
Is now an engineer thanks to FIRST.
Unread 04-01-2009, 17:43
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
I don't see what would stop the other robot from pulling their trailer away from you. They'd have their full pulling power, and would gradually pull away from you. You'd slow them down for sure, but I don't think you could actually permanently pin them. It'd be even easier for them if they were partially on the carpeted area, while you'd be on the regolith.
Unread 04-01-2009, 17:44
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
There is no rule against pinning this year, and as long as the system you have doesn't qualify as "entanglement" of the other robot (and maybe the trailer, unsure about that) and doesn't physically attach to the trailer, there is no rule that expressly forbids this.
Schneidie
Unread 04-01-2009, 17:53
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
I don't think you could build official bumpers in an indent, because the bumper zone is defined by the polygon formed if you wrap a string around your robot, so you can't have official bumpers in indents.
Unread 04-01-2009, 17:56
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
I dunno this might be stretching it, but everything else(2/3) of the robot were covered by bumpers, then technically they'd have enough of the robot covered in legal bumpers, and the others were just extra.
So i dunno. Thats probably pushing it a little too far.
Unread 04-01-2009, 18:11
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
To answer your question, yes, pinning your opponent and/or their trailer is allowed. The practicality however is questionable.
When you pin them:
-You are on regolith and they are on carpet (This is the intent of the carpet).
-They stop making them an easier target.
-You also stop making you an easier target.
-You are close to your opponent making it more likely that your human player will accidentally hit your trailer...I know, I know, you have perfect aim right?
On the other hand, pinning them to dump the contents of your robot into their trailer may be a more viable strategy.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 04-01-2009, 18:23
AKA: Greg
Originally Posted by ICanCountTo19 View Post
When you pin them:
Is there a rule saying that you can't make something that pushes and pulls your trailer back and like a tail wags, making it a harder target? As long as its within the dimensions.
Unread 04-01-2009, 18:31
ShadowNinja's Avatar
ShadowNinja ShadowNinja is offline
ShadowNinja
FRC #0231 (HIGH VOLTAGE)
Team Role: Driver
ShadowNinja is an unknown quantity at this point
the truth is pinning has pros and cons..
pro-u get a rbot against a wall con-we r on ice like surface a push might not work
con the wall is a scary place and makes u an easy target..
Unread 04-01-2009, 18:33
GaryVoshol's Avatar
Cogito ergo arbitro
Try <G29>
(since 2004)
Unread 04-01-2009, 18:37
Brdn666's Avatar
Brdn666 Brdn666 is offline
AKA: Brandon
FRC #2604 (Metal & Soul)
Brdn666 is an unknown quantity at this point
Send a message via Yahoo to Brdn666
If your robot could be fed while you sit there and pump rocks into the pinned robot, then you'd have a viable pinning strategy.
Unread 04-01-2009, 18:53
Originally Posted by GaryVoshol View Post
Try <G29>
<G29>Arena Interaction –ROBOTS may push or react against any elements of the ARENA, provided there is no damage or disruption of the ARENA elements. With the exception of a ROBOT towing a TRAILER, ROBOTS may not grab, grasp, grapple, or attach to any ARENA structure. If a ROBOT violates this rule, the TEAM will be given one warning. If the referee determines that the TEAM is disregarding the warning, their ROBOT will be disabled for the remainder of the MATCH. ROBOTS that become entangled in the ARENA elements will not be freed until after the MATCH has finished, unless the entanglement represents a safety hazard.
I'm not sure that applies. As long as you do not touch the trailer or hitch with anything except bumper to bumper contact you should be good. You'll have to innovative there. You also run into the problem of the friction of forward wheels "wagging" sideways which is basically double the friction which is still basically none though.
Mike Schreiber
Unread 04-01-2009, 18:56
GaryVoshol's Avatar
Cogito ergo arbitro
GBilletdeaux930, in the post I responded to, wanted something that would wag the trailer back and forth like the tail of a dog. That sounded like grasping the trailer to me.
(since 2004)
Unread 04-01-2009, 19:03
AKA: Greg
Yea the only way to do it would involve grasping...
So your pretty much stuck.
Unread 04-01-2009, 19:11
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
And you must use a specific design of trailer tongue defined within the rules, so you can't do it that way. Just swerve back and forth constantly
Does anyone else remember when TBA signatures actually worked?
Removing game pieces from Trailers PhilBot Rules/Strategy 51 06-01-2009 17:19
Clarification on Pinning Stu Bloom Rules/Strategy 2 15-03-2006 05:07
Should technical mentors be allowed to help repair robots during finals? eugenebrooks Rules/Strategy 20 12-04-2005 23:34
Driving Robots under/into the Goals ... allowed? erniep Rules/Strategy 8 11-01-2005 22:32
Lifting opposing robots D. Gregory Rules/Strategy 2 07-01-2003 14:06
