Go to Post NOOOOOOOOOOOOooooooo!!!!! I hate regolith. - apalrd [more]
Unread 04-01-2009, 17:12
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Measuring distance with cameria
If the cameria on your robot measures that the hieght of a marker is " p " pixels at an distance of " c ", then if you are to move this item, and the item is " p' " pixels tall, then the distance of the object would be
d=c+ [(p-p')*(sec 1.79)]
if 1.79 is degrees, rounded (1 degrees, 47 minutes, 23.68 seconds to 1 degree, 47 minutes, 24 seconds)
right?
Is now an engineer thanks to FIRST.
Unread 04-01-2009, 18:48
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Measuring distance with cameria
I wasn't going to try to determine the distance with the camera, instead I was going to use an ultrasonic sensor pointed in the same direction as the camera. I don't think the difference in the height would be great enough, and you really need an accurate measure of distance in order to shoot a ball at it.
Unread 04-01-2009, 19:11
GaryVoshol's Avatar
Cogito ergo arbitro
The vision target on the trailer is at a fixed height. Your camera will be mounted on your robot at a fixed height; make it lower than the vision target. If you measure the angle (above horizontal) that your camera is at to point at the target, you can use trig to figure out how far away you are from the target.
(since 2004)
Unread 04-01-2009, 23:23
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
right?
No. It's surprisingly much more complicated than that. The main reason is that in order to do that you have to account for the distortions caused by the camera. I actually performed a calibration for my optics project using a 200.00 dollar camera. The distortion for some areas of the image was as high as 20 pixels.
Unread 05-01-2009, 01:04
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Photographers and camera geeks make a huge deal about lens distortions.
Why not simply use trig and a pan-tilt servo deal so you can read the elevation to the target?
Unread 05-01-2009, 01:22
nitsua60 nitsua60 is offline
FRC #2785 (Prometheus)
nitsua60 will become famous soon enoughnitsua60 will become famous soon enough
There's the magic word. Given the uncertain inputs to the analytical solution (unless you want to take apart that camera and do some serious optics testing) why not just image the vision target at a range of distances and generate an image height vs. distance curve? If that goes by too quickly, do it repeatedly in different areas of the image to correct for the aberrations.
Unread 05-01-2009, 07:24
Adam Y.'s Avatar
Adam Y.
no team (?????)
That is pretty much the idea. I unfortunately don't know what type of Labview distribution you have which means that it may or may not have the capability to do the calibration.
Here is a URL for some concepts about camera processing.
Unread 05-01-2009, 08:08
XXShadowXX's Avatar
They call me Cody.
sounds by far the simplest solution, of course the object will still get smaller the further you are from the object, so it wall have some margin of error, it will still need some optic curve...
Unread 05-01-2009, 08:26
pgaston pgaston is offline
FRC #2103
pgaston is an unknown quantity at this point
And, what about the mass of the image you've found? i.e., the number of pixels inside the image blob defined by your color parameters.
That *should* vary enough to give you some measure as to distance - though experimentation is obviously next. Perhaps this could be combined with the trig calculation?
Unread 05-01-2009, 08:28
XXShadowXX's Avatar
They call me Cody.
see first post, that what i was doing, but as i understand it the angle that objects change size at changes meaning you have to use a curve not only that but you need to account for optical defermations in the lens
Unread 05-01-2009, 14:44
elfinn elfinn is offline
Team 166 Mentor
AKA: Beth Finn
FRC #0166 (Chopshop Team 166)
elfinn is an unknown quantity at this point
Size of the target is an easily obtained value and would be a more accurate measure of distance than the mass. The mass may be misleading if the particle returned has holes or is truncated by glare or bad parameters. But the height and width of the particle would vary directly with distance.
White Paper Discuss: Measuring Distance with Analog Potentiometers Daniel Extra Discussion 4 26-11-2008 13:52
Help with Angles and distance charlie1218 Programming 5 13-12-2007 18:54
Measuring Muzzle Velocity Team 614 Rules/Strategy 8 28-01-2006 14:53
Measuring Motor Characteristics DonRotolo Motors 1 08-01-2006 19:39
SHU measuring stick sanddrag Rules/Strategy 13 08-01-2003 21:23
