Go to Post A pole is usually made of aluminum or steel pipe. You can get these wherever you get metal. :) As for polls, there's a check box in the "Additional Options" section of the New Thread page that you can click to create said poll. - Chris is me [more]
Unread 04-01-2009, 19:25
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Propulsion that does not involve driving wheels
Originally Posted by RobotLady View Post
On blowing balls away from the trailer, could you use pneumatic tubing to direct the force and just dump pressure from a tank to create an air jet of some sort?
You can use a pipe-like thing to direct the air. But anything regarding pneumatic tubing, or air ultimately from the on-board compressor simply does not have enough volume to be useful in this way.
Originally Posted by tjwoodin View Post
Also you could use a fan to blow above your robot to force it down and increase traction but maybe thaat is a violation of the rules?
I don't know why it would violate any rules, assuming the safety aspects were covered. An increase in "weight" (more accurately, downforce) would provide more friction and therefore traction.
Unread 04-01-2009, 20:05
sxysweed sxysweed is offline
Du Gamla, Du Fria
AKA: that Guy...
FRC #0408 (The Roboticks)
sxysweed is an unknown quantity at this point
Send a message via AIM to sxysweed Send a message via Yahoo to sxysweed
Interesting idea...
Big fans.. Maybe. Depends on the coating and the weight of the robot. Seems conviecable but you'l have to work out the number of wheels (do we have to use wheels are can we use like little bearing things?) for the least friction...
Why a big fan though? By not build a series of duct fans like on the Big RC Jets? Build a nice fat one or custom make a few by gearings the motor out and making it run 2-3 duct fans. That way you could direct the fans. You could either go for downforce or for power....
Unread 04-01-2009, 20:14
DonRotolo's Avatar
Back to humble
FRC #0832
<R06>
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA.<snip>
Yes, you can only use the specified wheels, nothing else.
Unread 04-01-2009, 20:34
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
You may be forced to use the 'rover wheels', but you could concievably create caster attachments for them.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 04-01-2009, 21:19
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Interesting idea...
1124 ran a small test with a large downward facing fan (it was powered by a .25hp motor, about 26" in diameter, so it probably wouldnt fit on a robot), but that fan and the downforce it provided gave a significant boost in the amount of friction between the robot and the ground. it actually became hard to push (we dont have the proper instruments to give you guys how much force was required to move it, but it was a lot more than without the fan turned on)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 04-01-2009, 21:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The instrument could be a bathroom scale or something simple like that, use it to push the robot with and without the fan running.
Unread 04-01-2009, 21:33
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
I dont think FIRST would let a team have a large,SHARP!, spinning object on the robots, i mean they already get on us about the sharp corners.....
imagine what would happen if there was a collision, and the fan blade shattered and sent pieces flying everywere
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 04-01-2009, 21:38
Matt H. Matt H. is offline
Long Distance Mentor
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
A fan in a cage is no more dangerous than an intricate chain system or some of the launchers we saw last year--at least in my opinion.
Unread 04-01-2009, 21:44
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
if its sufficiently caged, mounted, and protected, the above shouldn't happen.
shouldnt.
ill see if i can get the team to use the scale for force measuring tomorrow, when we are back in the high school.
RPI 2012
BREAKAWAY
gorrilla's Avatar
AKA: adam spears
i highly disagree with that.....
Adam Spears
Unread 04-01-2009, 21:49
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
And yet, people still found (and were required to find) ways to protect these systems and reduce how dangerous they actually are.
RPI 2012
BREAKAWAY
Unread 04-01-2009, 21:57
RogerHebert's Avatar
RogerHebert RogerHebert is offline
FRC #0811 (Cardinals)
RogerHebert is on a distinguished road
There is <R06> which states "No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted."
Unread 04-01-2009, 21:59
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Why not the best of both worlds? Have two cims driving the wheels and two on a fan set up. You have the same driving characteristics of everyone else with an added speed and some handling boost. The wheels alone can brake so the fans dont have to be reversed.The fans can help turning a little and best of all help blow moon rocks away. If you really get fancy, you could come up with a herding system with the fans and blow them around on the ground like a leaf blower.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 04-01-2009, 22:08
computerish computerish is offline
FRC #0619
computerish is an unknown quantity at this point
I think RogerHebert is right that you can't use a big fan on top, but what about the idea of pointing a fan (kind of like a leaf blower) over the trailer to deflect balls? Is that legal?
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
However, these fans arent providing more traction- they are increasing the normal force which in turn causes the wheels to have more traction.
perhaps this is a question for the Q&A?
RPI 2012
BREAKAWAY
pic: Hey who's that driving the robot? Koko Ed Extra Discussion 10 24-03-2006 05:17
Driving omni-directional wheels VanZuiden General Forum 4 19-01-2006 22:59
Wheels & Driving Ryan Curry General Forum 3 13-01-2002 21:43
Heres a big problem that I think Discreet does not know what they are talking about. wes16zeus 3D Animation and Competition 9 09-01-2002 23:31
