Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
  #31   Spotlight this post!
Unread 04-01-2009, 02:18
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
AKA: Katie Widen
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
Re: Question about missing Robots?
Originally Posted by Kevin Sevcik View Post
You don't know this. It's not specifically covered in the rules, but <G10> says:Which implies that TRAILERS are assigned to LAUNCH PADS, whether there's a robot or not. Which means, there'd be 3 TRAILERS, even if there were only 2 ROBOTS. There is definitely a Q&A question here, just to be certain, but I'm pretty sure the TRAILERS stay. If they didn't, why would you bother putting any robots out? No robots = no goals to be scored in. As long as your opponent was foolish enough to field a robot, you'd only have to land a single moon rock to win the match.
Originally Posted by KarlSTA View Post
where's the rule that prevents three teams from having no robots and only players...they can't be scored on but they can still score?? I haven't found it yet!
Thats what Kevin is talking about.
It'll prolly come up in the Q&A.
Although I think they'll still leave your trailer out, for that reason.
  #32   Spotlight this post!
Unread 04-01-2009, 02:25
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Although it isn't clearly specified and needs to be brought up in Q&A, I'd tend to agree that there will be three trailers per alliance on the field regardless of the number of robots, both to avoid providing a competitive advantage to teams that fail to bring a robot and to simplify field reset mechanics.
Based on past observation of match procedures, I expect Field Reset will probably reposition the trailers in their launch pads and reset the orbit balls to their proper starting locations while match N-1 is removing their robots. Then they'll flag the match N teams to bring in their robots, hitch up, and adjust position within the launch pad. This avoids having to carry the trailers in and out of the arena, which would have two negative effects:
  • Increasing turnover time by adding to the things being carried through the field entry/exit gates
  • Requiring designating a trailer parking lot in the queuing area, which is already quite congested in some venues
  #33   Spotlight this post!
Unread 04-01-2009, 10:18
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
What happens if a robot isn't on the field for a match?
Would the trailer still be placed on the field in some fashion? This would be difficult, considering that the trailer cannot support itself (it only has two wheels).
If a trailer is not placed on the field when the robot can't play, then an alliance with three no-shows would win every game.
  #34   Spotlight this post!
Unread 04-01-2009, 10:33
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: What happens if a robot isn't on the field for a match?
In your scenario, three no shows on one alliance would be a 0-0 tie, since neither team can score.
Former Mentor Team 1771
Former mentor Team 4509
  #35   Spotlight this post!
Unread 04-01-2009, 10:34
Killraine Killraine is offline
Team Robot
AKA: Josh Lucas
FRC #2016 (Mighty Monkey Wrenches)
Killraine will become famous soon enoughKillraine will become famous soon enough
I assume if your robot is no-show, than your team shouldn't be able to throw balls? Does anyone have a rule on this? I would like to see this clarified.
  #36   Spotlight this post!
Unread 04-01-2009, 10:39
scirobotics's Avatar
scirobotics scirobotics is offline
AKA: Oscar Hazelaar
FRC #2013 (Cyber Gnomes)
Team Role: Communications
scirobotics is a jewel in the roughscirobotics is a jewel in the roughscirobotics is a jewel in the rough
Hm...weird, the actual rules dont say anything about this i think. I would say that a no show would in this case result in that each side would have one less hitch? i am really not sure
  #37   Spotlight this post!
Unread 04-01-2009, 11:24
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Also something interesting to consider--If your team does not send a robot out for the match, but the alliance you were supposed to be on either doubles or triples the opposing alliances score, does your team still lose its game pieces the next match?
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
  #38   Spotlight this post!
Unread 04-01-2009, 11:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
There are two other threads about this already, both as inconclusive as this one will end up being:
http://www.chiefdelphi.com/forums/sh...d.php?p=790444
http://www.chiefdelphi.com/forums/sh...ad.php?t=71119
  #39   Spotlight this post!
Unread 04-01-2009, 18:13
GregW11's Avatar
GregW11 GregW11 is offline
Mad-haired biker man
FRC #2261 (Casa MESA)
GregW11 is on a distinguished road
Send a message via AIM to GregW11 Send a message via MSN to GregW11
Don't forget, the trailer is large enough that even without a robot it will still have something to rest against (the bumper would touch the ground before the wheels cause it to fall on its side). Considering that the robot would most likely be powering the lights in the first place (allowing for changed colors if needed) the trailer would be useless without a robot to power it.
  #40   Spotlight this post!
Unread 04-01-2009, 19:27
GaryVoshol's Avatar
Cogito ergo arbitro
The Payload Specialists could still shoot moonrocks and score.
Players may still come to the field without a robot, and the Payload Specialist could shoot.
Depends. If you sent players out, then you would get a score, and if your alliance's score is 2x or 3x the other alliance, you would lose a Cell in your next game. If your team is a complete no-show, then you earn zero points for that game, so you won't lose a Cell in your next match.
The trailer is not powered. They have either red or blue bumper coverings.
Threads will be merged.
(since 2004)
  #41   Spotlight this post!
Unread 04-01-2009, 19:32
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Re: 2 bots v. 3 bots Trailer question
This is an interesting question. An unhitched trailer arm could be pretty damaging to other robots. In the past it has never helped your own alliance in any way if one of your robots can not play.
I'd hate to advise a partner who isn't certain if their robot will run or not to sit it out. A dead robot with a trailer is much more of a detriment to the team that no robot and trailer at all. Heck even a robot that hasn't achieved proficiency at scoring is more of a detriment than an asset if there's an option for them to not be on the field (along with their trailer).
I think FIRST is going to have to have some sort of bot to hook to the trailer. It could be as simple as a chunk of plywood with wheels and bumpers mounted to it, or even the next robot who's going to play in that spot but disabled for the entire match. I definitely do not like the idea of them not putting all three trailers out there.
  #42   Spotlight this post!
Unread 04-01-2009, 23:47
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
I am inclined to think that all 6 trailers will always be on the field no matter how many robots show up to play. Otherwise, everyone would quickly learn the best way to win is to not bring any robots to the field only the human players and the game will become very boring very quickly. The question then becomes if only 2 robots show up which starting location is strategically the best to place start the odd trailer?
  #43   Spotlight this post!
Unread 05-01-2009, 20:13
hayleybayley217 hayleybayley217 is offline
AKA: Hayley
FRC #0217 (ThunderChickens)
hayleybayley217 is on a distinguished road
i totally agree. I am hoping there will be some clearification on this situation, but this is the best suitable idea to make it fair amongst the alliances, or like you said they are leading themselves into a really boring game, where teams will use that too the advantage.
  #44   Spotlight this post!
Unread 18-01-2009, 11:47
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Well the trailers are still there if no one shows up. therefore it would be easier for the oposing team to score on the trailers especially since they begin at the opposing outpost station and furling ports.
  #45   Spotlight this post!
Unread 18-01-2009, 13:56
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Says who?
I have seen no response from the GDC indicating that this is the case.
2001-2004: Team 100
2006-Present: Team 254
pic: Bots on Bots CD 47 Mike Martus Robot Showcase 18 15-02-2007 12:40
A question for ramp bots Cody Carey General Forum 9 28-01-2007 22:23
Art Bots wildcatsfive General Forum 6 28-07-2003 19:09
Bots v Bots archiver 2001 17 23-06-2002 22:06
All these mouse bots gives me an evil idea- CAT BOTS! Patrick Wang General Forum 2 09-03-2002 22:43
