Go to Post You know, I have 2 big addictions in my life right now: ice cream, and FIRST. While the prior may not be great for my health, I think I'm doing just fine with FIRST. - Beth Sweet [more]
Unread 04-01-2009, 19:34
brianc217's Avatar
brianc217 brianc217 is offline
None #1153
brianc217 is an unknown quantity at this point
Labview with Four Motors
Hello all,
A few days ago we tried to start programming our four motor robot using Labview so under the basicrobotmain vi we changed the default open2motor vi to the open4motor vi and then wired the additional two motors and set the inversion for those additional two motors. We used the default arcade drive. When we ran the program we could move forward, backward, and left. When we tried to move right we could move the joystick very slowly to the right and get it to work, but when we tried to make a hard right we lost all control to the system. Does anyone know what could be wrong? We don't think its a wiring problem unfortunately. thanks.
Unread 04-01-2009, 19:49
GregW11's Avatar
GregW11 GregW11 is offline
Mad-haired biker man
FRC #2261 (Casa MESA)
GregW11 is on a distinguished road
Send a message via AIM to GregW11 Send a message via MSN to GregW11
Re: Labview with Four Motors
Check the default arcade drive "code" (look at the program, I mean), since you might have to set something in there to four motors instead of two. And make sure you're not pulling a bit back too, since that might (hopefully not though) cause a problem.
Unread 04-01-2009, 22:07
brianc217's Avatar
None #1153
Ok thanks. I'll check that out tomorrow.
Unread 04-01-2009, 23:58
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
If all else fails you could use a two motor VI and then use a Y-cable from the sidecar to the speed controller.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors DanDon LabView and Data Acquisition 3 29-01-2009 22:13
Labview with Four Motors brianc217 NI LabVIEW 0 04-01-2009 11:52
Why are four states needed with Quadratuer encoders? Issues Programming 14 11-11-2005 15:02
New fossils of dinosaur with four wings found Munkaboo Chit-Chat 3 23-01-2003 00:54
Four motors at the same speed? archiver 2001 8 23-06-2002 22:51
