Go to Post - Just because you can buy 50 giant pixie stix with your roommates Sam's club membership does not mean you should eat them all at once. - Not2B [more]
Unread 04-01-2009, 15:36
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Fisher Price Motor with Bane Bots Transmission
Does anyone know if you can mount a Fisher Price motor to a banebots 36mm gear box?
If so is any extra hardware required?
Thanks,
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 04-01-2009, 16:38
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: Fisher Price Motor with Bane Bots Transmission
Here is a link to the banebots website that should help you.
http://banebots.com/c/MP-36XXX-545
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 04-01-2009, 17:53
Bochek's Avatar
AKA: Adam Bochek
I have already been to their website... What is the shaft size on the FP motor? and is the bolt pattern the same as the banebots RS545 motors?
Unread 04-01-2009, 19:46
Bochek's Avatar
AKA: Adam Bochek
I hate to be a bother, but BUMP
Unread 04-01-2009, 19:54
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
my interpretation of the rule is that you have to use the RS545 motor. It doesn't have to be the one they shipped you in the kit, just the same motor.
so if you just buy the completed assembly from banebots you are good to go.
i dont think there is any limit to the number of RS545 motors you can use.
as for the CIMs you can only have 4.
Ed Barker
Unread 04-01-2009, 21:27
roach1051's Avatar
roach1051 roach1051 is offline
Go Boilers!
AKA: Jack Roach
FRC #1051 (Technical Terminators)
roach1051 is on a distinguished road
The Fisher Price motor is similar to the RS550 motor sold by Banebots. It is not the same motor, but is the same size package. They are both the same mounting configuration and 3.2mm shaft diameter as the RS540 and RS545 motors. All four motors can be installed on the 36mm and 42mm Banebot transmissions. All you need to use the fisher price is a new pinion gear from Banebots for the fisher price motor. Make sure you get the correct pinion gear for the transmission you are using. They have different ones for 3:1, 4:1 and 5:1 first stage transmissions. Also make sure you get the one for the 3.2mm shaft gear too. You have to press the old pinion off the fisher price and press the new one on the shaft the correct depth (compare the pinion spacing from the face of the motor with the spacing on the motor from the Banebot). Be careful not to bend the shaft when replacing the gear. You will also have to trim off the end of the shaft flush with the pinion. We used the Fisher Price, RS540, & RS550 with Banebot trannies on our robot last year with no problems.
Jack
Precision is for amateurs, custom fit is for professionals
Unread 04-01-2009, 22:36
ebarker's Avatar
AKA: Ed Barker
to clarify an earlier point, the RS 545 is in the KOP, so you can use the banebots completed model.
question - you are saying the RS 550 is essentially the same as the FP motor ?
and are RS 540 models acceptable this year ? I don't know of any in the KOP so therefore should not be acceptable.
Ed (from Conway)
Ed Barker
Unread 04-01-2009, 23:09
roach1051's Avatar
Go Boilers!
AKA: Jack Roach
Ed
The FP is similar to the RS550 but it is not an exact duplicate in performance. Since the FP is different every year we get them, they're performance is consantly changing. They are the same physical package as the RS550. You are correct, the RS550 and RS540 are not in the kit this year, only the RS545 will be allowed, and only the number in the kit can be used on the robot. You can have more for spare parts. The FP and RS545 can be installed on either 36mm or 42mm Banebot transmissions.
Jack
Unread 04-01-2009, 23:14
Bochek's Avatar
AKA: Adam Bochek
I am just asking because i need 4 motors on 36mm gearboxes. and knowing the rules, that means i need to use the 2 FP motors and the 2 RS545's
Thank you to everyone who helped,
- Bochek
Fisher Price Motor Macdaddy549 Motors 5 28-04-2007 09:32
Bane Bots transmission sieze Demothesis Motors 3 31-03-2007 21:55
Mini-bike motor on the bane bots gear box free_rider_151 Technical Discussion 2 12-01-2007 21:17
Fisher Price Motor Andrew Y. Motors 2 20-11-2006 07:52
Black & Decker Fisher Price Transmission team222badbrad General Forum 11 18-03-2006 00:27
