Go to Post "well.. I think I underestimated the swine..." -Andy Baker - Joel J [more]
Unread 04-01-2009, 21:25
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Finding green/pink flags
Try this,
1. Log into the camera
2. Goto Advanced Settings and set White Balance to Hold
3. Goto Settings and turn down the brightness 20% of what it's set too
4. Goto Live video settings and take a screen shot (Alt + Print Screen)
5. Open MSPaint and Paste in the Picture, save as a JPG
6. Open Labview Vision Assistant, Open the file, and
7. Select Color, then Color Threshold, and then Color Model:HSL
8. Play with the Hue, Sat, Lum levels until most of the target is high lighted red
9. Set the new levels by updating tdata parameters, here is the list, these worked for me. You only need to set the values you changed in Vision Assistant.
//tdata.hue.minValue = 60;
//tdata.hue.maxValue = 80;
//tdata.saturation.minValue = 34;
//tdata.saturation.maxValue = 200;
//tdata.luminance.minValue = 128;
//tdata.luminance.maxValue = 240;
Edit: Also, it's a really good idea to start with the simple tracker demo 100% unmodified. Then you can tell if it's you or the camera values.
Unread 05-01-2009, 11:45
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
My friends and I are trying to get the Axis Camera to find the green/pink flags, but we are having a problem getting the camera to recognize anything and it didn't say it failed to recognize the camera, so what could help make it work?
The camera is just not working all together, but it is connected and on so we are in a jam. any Ideas?
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 05-01-2009, 12:46
Kingofl337's Avatar
AKA: Adam
Did you run the Camera Configuration Utility? Are you using the orange CAT-5 cable? Are you using the example? Does it work connected to your PC?
Unread 05-01-2009, 14:37
AKA: Brad
#0190 ( Gompei and the Herd)
There will be example code posted soon that will do the detection of the two color targets. The code will be able to differentiate between the red and blue alliances.
Brad Miller
Robotics Resource Center
Unread 05-01-2009, 17:22
"Wilfordito"
Alright thanks very much for the help
Unread 05-01-2009, 17:42
"Wilfordito"
Actually it is still not working we used the CAT-5 and still are getting no feedback.
So the programmer and I are at a loss. also the utility isn't working so any ideas what to do?
Unread 05-01-2009, 19:22
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Hey all-
I'm running WindRiver, and I'm running the SimpleTracker example code. I've used the NI Vision Assistant to get color values for my green vision target, and put those into the WindRiver code.
        tdata = GetTrackingData(GREEN, FLUORESCENT);
        tdata.luminance.maxValue = 187;
        tdata.luminance.minValue = 103;
        tdata.hue.minValue = 71;
        tdata.hue.maxValue = 98;
        tdata.saturation.minValue = 56;
        tdata.saturation.maxValue = 111;
I'm getting terminal feedback from the CRIO (finally...but that's another story), but the camera is failing to find any blobs matching the numbers that were obtained using the Vision Assistant.
Help, please?
Unread 11-01-2009, 16:07
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Have you updated all the firmware? Are you using all the most current software?
Unread 13-01-2009, 16:10
Chris1228 Chris1228 is offline
FRC #1228
Chris1228 will become famous soon enough
can someone help me program the camera to track colors in labview? i can get it to recognize a color but i dont know how to get motors/servos to move when it sees a color
Flags???? cprogrammer Programming 4 25-07-2005 20:21
Flags trdragons204 General Forum 2 23-03-2005 10:29
Concerns regarding the green paneling/green shirts Petey General Forum 127 15-01-2005 10:35
6 Flags Raven_Writer Chit-Chat 12 30-07-2004 23:01
Six Flags? Hermione692 Championship Event 29 29-04-2003 21:12
