Go to Post I'm pretty sure Andrew Baker and Andy Baker are the same person. Then again, Andy may just be holding out on us. - Amanda Morrison [more]
Unread 04-01-2009, 16:28
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Finding green/pink flags
Hi everyone,
I am trying to use the Axis Camera to locate green and pink flags. However, it fails when actually finding the colors. Here's the relevant portion of my code so far:
		int i = StartCameraTask();
		StartImageAcquisition();
		while (IsOperatorControl())
			double timestamp;
			Image *img = frcCreateImage(IMAQ_IMAGE_HSL);
			int getImage = GetImage(img,&timestamp);
			TrackingThreshold tdata = GetTrackingData(GREEN, PASSIVE_LIGHT);
			ParticleAnalysisReport par;
			int findcolor = FindColor(IMAQ_HSL, &tdata.hue, &tdata.saturation,&tdata.luminance, &par);
		StopImageAcquisition();
		StopCameraTask();
I find the values of par, tdata, getImage, and findcolor using the debugger. It succeeds up to the call to FindColor. I am using the stock green flag. I've tried positioning it differently in front of the camera, but it still doesn't recognize it!
I've tried it with PINK as well with the pink flag, and I've tried changing PASSIVE_LIGHT to FLORESCENT (neither work).
Has anyone had any success with getting the camera to recognize the flags/know what I'm doing wrong?
Thanks,
Kevin
Unread 04-01-2009, 21:22
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
Re: Finding green/pink flags
I have had the same problem. I also tried.
if (StartCameraTask(10, 0, k160x120, ROT_0) == -1){
	printf("Failed to spawn camera task: %s\n",GetVisionErrorText(GetLastVisionError()));
// Set up camera tracking parameters.
tdata.hue.minValue = 67;
tdata.hue.maxValue = 114;
tdata.saturation.minValue = 161;
tdata.saturation.maxValue = 255;
tdata.luminance.minValue = 24;
tdata.luminance.maxValue = 101;
in the init with
if (FindColor(IMAQ_HSL, &tdata.hue, &tdata.saturation, &tdata.luminance, &par)
		&& par.particleToImagePercent < MAX_PARTICLE_TO_IMAGE_PERCENT
		&& par.particleToImagePercent > MIN_PARTICLE_TO_IMAGE_PERCENT) {
	int lightX = (int)(par.center_mass_x_normalized * 1000.0);
	int lightY = (int)(par.center_mass_y_normalized * 1000.0);
	printf("Light found: x: %i y: %i\n", lightX, lightY);
} else {
	if (err)
		printf("Failed to spawn camera task: %s\n", GetVisionErrorText(GetLastVisionError()));
	else
		printf("light not found\n");
in the main loop but that didn't work either
Unread 04-01-2009, 21:25
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Try this,
1. Log into the camera
2. Goto Advanced Settings and set White Balance to Hold
3. Goto Settings and turn down the brightness 20% of what it's set too
4. Goto Live video settings and take a screen shot (Alt + Print Screen)
5. Open MSPaint and Paste in the Picture, save as a JPG
6. Open Labview Vision Assistant, Open the file, and
7. Select Color, then Color Threshold, and then Color Model:HSL
8. Play with the Hue, Sat, Lum levels until most of the target is high lighted red
9. Set the new levels by updating tdata parameters, here is the list, these worked for me. You only need to set the values you changed in Vision Assistant.
//tdata.hue.minValue = 60;
//tdata.hue.maxValue = 80;
//tdata.saturation.minValue = 34;
//tdata.saturation.maxValue = 200;
//tdata.luminance.minValue = 128;
//tdata.luminance.maxValue = 240;
Edit: Also, it's a really good idea to start with the simple tracker demo 100% unmodified. Then you can tell if it's you or the camera values.
Unread 05-01-2009, 11:45
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
My friends and I are trying to get the Axis Camera to find the green/pink flags, but we are having a problem getting the camera to recognize anything and it didn't say it failed to recognize the camera, so what could help make it work?
The camera is just not working all together, but it is connected and on so we are in a jam. any Ideas?
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 05-01-2009, 12:46
Kingofl337's Avatar
AKA: Adam
Did you run the Camera Configuration Utility? Are you using the orange CAT-5 cable? Are you using the example? Does it work connected to your PC?
Unread 05-01-2009, 14:37
AKA: Brad
#0190 ( Gompei and the Herd)
There will be example code posted soon that will do the detection of the two color targets. The code will be able to differentiate between the red and blue alliances.
Brad Miller
Robotics Resource Center
Unread 05-01-2009, 17:22
"Wilfordito"
Alright thanks very much for the help
Unread 05-01-2009, 17:42
"Wilfordito"
Actually it is still not working we used the CAT-5 and still are getting no feedback.
So the programmer and I are at a loss. also the utility isn't working so any ideas what to do?
Unread 05-01-2009, 19:22
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Hey all-
I'm running WindRiver, and I'm running the SimpleTracker example code. I've used the NI Vision Assistant to get color values for my green vision target, and put those into the WindRiver code.
        tdata = GetTrackingData(GREEN, FLUORESCENT);
        tdata.luminance.maxValue = 187;
        tdata.luminance.minValue = 103;
        tdata.hue.minValue = 71;
        tdata.hue.maxValue = 98;
        tdata.saturation.minValue = 56;
        tdata.saturation.maxValue = 111;
I'm getting terminal feedback from the CRIO (finally...but that's another story), but the camera is failing to find any blobs matching the numbers that were obtained using the Vision Assistant.
Help, please?
Unread 05-01-2009, 19:59
nickmagus's Avatar
AKA: Nick Clayton
the simple tracker demo 100% unmodified did not find anything...
Unread 05-01-2009, 20:05
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
There are bugs in the current versions of FindColor, GetLargestParticle and InArea. These have been fixed at the beta level and should be published shortly along with the pink-green demo that Brad mentioned above.
Dave D
Unread 06-01-2009, 11:05
nickmagus's Avatar
AKA: Nick Clayton
Oh ok that's good to know. Thanks. Any ideas as to when the code with those functions fixed will be posted. I looked through the functions but couldn't find the error (though I didn't spend that much time since you said its already fixed). The sooner its up the better. On that note I just wanna thank all the people who wrote and are writing this library (it makes all our lives much easier).
Unread 10-01-2009, 12:58
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Dave D
(not directly to dave D)
If you're a team that simply can't wait, you can look at GetLargestParticle and FindColor in TrackApi.cpp. Notice that GetLargestParticle never actually returns the largest particle index to the 2nd parameter. The code to return isn't there, and in the 2nd line of the function it actually blows away the pointer value so it becomes impossible to return the largest particle index. Since it's probably not a good idea to go fiddling with the supplied code unless you know what you're doing, I'll leave it as an exercise to the reader to figure out what to do.
Further, in the full-size version of FindColor, its check for success is incorrect. Rather than "if(largestParticleIndex == 0), it seems that it should be if(largestParticleIndex >= 0) in case the largest particle is not the first one.
Unread 10-01-2009, 18:23
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Dave D
Shortly, eh?
Unread 10-01-2009, 18:42
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
I helped team 1124 make the red/blue target tracker with great success (double thumbs up).
in labview, you basically copy the image from the camera, do a color threshold for each picture, do a particle report for each picture, and decide which one of those reports is the "top" color and which is the "bottom" color.
once you have that data, you run a loop as follows:
for each "top color:
check if the area of the color is big enough. if so:
for each "bottom" color:
check if the bottom color is directly below (with some tolerance) the "top" color.
add the "top" target to the output targets array
that basic algorithm allowed us to differentiate between red/green targets and green/red targets. there was a slight bit of extra post-processing to deal with multiple visible targets (basically you pick the uppermost one or the largest one etc).
what you do with the final target(s) is up to you... we cached the previous target position and velocity to do second-degree motion prediction for the target in case we lose it. (amongst other things)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Flags???? cprogrammer Programming 4 25-07-2005 20:21
Flags trdragons204 General Forum 2 23-03-2005 10:29
Concerns regarding the green paneling/green shirts Petey General Forum 127 15-01-2005 10:35
6 Flags Raven_Writer Chit-Chat 12 30-07-2004 23:01
Six Flags? Hermione692 Championship Event 29 29-04-2003 21:12
