Go to Post Things are not always as simple as they seem. - Paul Copioli [more]
Unread 25-02-2009, 01:12
AKA: Dr. Brooks
no team (WRRF)
Re: Implementing Traction Control for an advantage in the 2009 game
On the current measurement front, just order yourself a pair of 620-1106-ND current sensors from Digikey and hook them up. This goes in line with the power leads to the motor and has three pins that you can hook your pwm cable to for the analog input. You can pot it in epoxy after soldering the wiring to it. You might want to filter the output of the sensor as it will follow the chopped current to the motor nicely.
Eugene
The 2009 Control System Q&A Thread crake FRC Control System 59 11-01-2009 10:43
Drive train for 2009 game hihihiflcl81pig General Forum 4 27-12-2008 02:17
Buying the 2009 control system BornaE FRC Control System 9 16-10-2008 17:16
The Access Points on the 2009 Control System Shadow503 Rumor Mill 10 28-04-2008 23:22
UNFAIR ADVANTAGE for CDI and new control system archiver 2000 6 23-06-2002 22:13
