Go to Post I wouldn't want to replay Lunacy -- the Moon is a harsh mistress! - Richard Wallace [more]
Unread 04-01-2009, 22:08
xtraman122 xtraman122 is offline
FRC #0061
xtraman122 is an unknown quantity at this point
Re: Tell me more about the regolith coating.
The bumps on the "regolith" make less of the surface area of the wheel contact it at once which decreases traction even more. It's not bad to walk on beause shoes are made of soft rubber, but we got a sheet of an almost identical product from Home Depot and it was unbelievable how little traction there was between it and the wheel. We couldn't find anything else that had such little traction paired with the wheel, the closest was some sort of hard granite looking tiling used in the cafeteria of my school which we may end up using as a practice area if we don't buy lots more of the plastic/fiberglass surface.
Unread 04-01-2009, 22:11
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by Laaba 80 View Post
The field itself is not that slippery. What makes it slippery is the combination of the field and the wheels. They cant make the field to slippery because imagine what it would be like for Pilots carrying the robot on and off the field. We'd be slipping and falling constantly.
Joey
The field wasn't slippery for walking on with the (dry) Vans sneakers I was wearing at Kickoff in Manchester for the official playing field, so I don't expect it to be an issue as long as you're not wearing high-heels to carry your robot on the field.
HOWEVER, be advised that when we went to pickup the kits, they had a sample of the field in FIRST HQ, and while my sneakers were the same, the snow we tracked inside made it MODERATELY slippery inside there on them material.
Bottom line is, as long as the field stays dry, & no one spills some soda or water on part of the field (or ruptures a compressor hose, and/or leaks some gear oil on the field) then it SHOULD be ok to walk on from a team member's standpoint most of the time.
Be cautions anyways, & always plan for safety first!
Unread 04-01-2009, 22:19
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Yeah my shoes were wet too. In order to see the field at kick off we needed, and living in WI, there is always snow and wet outside. I could tell that the slip was because of the mass amounts of wet shoes on the field, not the field itself.
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 08-01-2009, 14:59
vannade vannade is offline
FRC #2591
vannade is an unknown quantity at this point
In checking out this product with the manufacturer there seems to be two types of Glasteel paneling, one with a smooth coat the other which can be bought at Home Depot (Glasteel wall liner panel sku #88594 49018) has a textured surface. Does anyone know which of these might be the right one.l
Unread 08-01-2009, 15:11
Carbon419's Avatar
Carbon419 Carbon419 is offline
FRC #1718
Carbon419 is an unknown quantity at this point
Yeah, i would have to agree with everyone else, that the "regolith" is basically a thematic name for the playing surface and it is basically ice. And yes ice saters do use it in the off-season to practice on becuase it is so slippery that it is an all around useful material, especially for this game.
Unread 08-01-2009, 19:49
Link2Everything Link2Everything is offline
Link2Everything is an unknown quantity at this point
Call me a necro for reviving a thread but I am looking through websites for teh coefficent of friction and its not adding up. Can anyone help me? I could just use a little.
Unread 09-01-2009, 02:09
ewilgus ewilgus is offline
FRC #2471
ewilgus is an unknown quantity at this point
Exclamation Re: Tell me more about the regolith coating.
SAVE SOME FOR US TEAM 2471, Camas, WA
Product Description:
Structoglas Class A fiberglass reinforced plastic (frp) wall
panels are durable, semi-rigid, and will not mold, mildew,
rot, rust, corrode, stain, dent, peel, or splinter. Panels
exhibit a high strength-to-weight ratio with
expansion/contraction values similar to aluminum
Distributor should be selected carefully for the fiberglass reinforced plastic (FRP). There are manufacturer FRP variations in this product and large price variances. If you buy a sheet from one vendor it may look different than product from another. So, buy all from one place.
Additionally, consider how will this material be stabilized on the substrate? In other words keep it from sliding all over the floor, especially with multiple sheets.
Compatible products are important choices for rapid protyping. Not sure if First uses Class Aor C. Product comes in smooth and texturized. Sample at kick off was texturized so I trust them to show us the correct thing.
Attached is a link to compatible product spec sheet in pdf format
http://www.cranecomposites.com/PDFs/2505_struc_tech.pdf
There are many Vendors selling this product locally. I suggest buying here.
http://www.lowes.com/lowes/lkn?actio...096&lpage=none
Sequentia
Fiberglass Reinforced Wall Panel
Item #: 8566 Model: 77096
4 x 8
Resin rich textured surface resists mold and mildew
Gencom Procurement Specialist
Unread 09-01-2009, 03:27
Best Available Data
FRC #1778 (Chill Out!)
Joey
Well, I imagine drive teams will probably just slide their robots over to the gates this year, instead of wasting energy carrying it. We're goin' to the moon, it's all about efficiency (minus the millions of gallons of Kerosene and LOX we had to burn to get there)!
In all seriousness though, like Elgin said, this stuff isn't slippery to the sneakered foot.
Unread 09-01-2009, 08:22
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by iCurtis View Post
... In all seriousness though, like Elgin said, this stuff isn't slippery to the sneakered foot.
I just hope we don't see any drive team members, referees, emcees, or other volunteers wearing acetal-soled shoes this year. On second thought, maybe acetal soles would be appropriate for some emcees.
Richard Wallace
since 2003
Unread 09-01-2009, 09:36
catsylve catsylve is offline
FRC #3538
catsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond repute
Alright, now Richard, just because you are spending all of your time sliding around on the highways between Missouri and Michigan, doesn't mean we have to make our emcees into hockey pucks as well!
2012 Woodie Flowers Finalist, St. Louis Regional
Crab Steering on Regolith Dan2081 General Forum 33 09-01-2009 16:35
Tell MSNBC About Your FIRST Team! Amanda Morrison General Forum 0 11-09-2007 09:33
Show off your team website picture galleries and tell me a little bit about them!!!! Elgin Clock Website Design/Showcase 14 30-06-2004 11:23
powder coating Ben.V.293 Technical Discussion 0 07-04-2004 22:46
Tell us a little about yourself... Dan 550 Chit-Chat 55 18-11-2002 17:37
