Go to Post I have a pocket full of Gracious Professionalism! How about you? - Schnabel [more]
  #31   Spotlight this post!
Unread 04-01-2009, 22:14
xtraman122 xtraman122 is offline
FRC #0061
xtraman122 is an unknown quantity at this point
Re: Propulsion that does not involve driving wheels
I'm pretty sure they'd rule that out as something with means to increase traction and therefore would be disqualified. Although adding lead weights on the top woulkd effectively be doing the same thing as far as interactions between the wheels and the surface so maybe there is an argument there.
  #32   Spotlight this post!
Unread 04-01-2009, 22:16
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Originally Posted by gorrilla View Post
I dont think FIRST would let a team have a large,SHARP!, spinning object on the robots, i mean they already get on us about the sharp corners.....
imagine what would happen if there was a collision, and the fan blade shattered and sent pieces flying everywere
you could get around that by buying a off the shelf floor fan or something like it that comes with its own cage and just use its motor (might break a few rules unsure tho) or rip out the motor use the fan blades and cage and power it with CIMS
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
  #33   Spotlight this post!
Unread 04-01-2009, 22:18
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Originally Posted by Uberbots View Post
However, these fans arent providing more traction- they are increasing the normal force which in turn causes the wheels to have more traction.
perhaps this is a question for the Q&A?
I'd say the call is quite clear... this goes against the spirit of the rules, even if it is not explicitly forbidden in the letter of the rules.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
  #34   Spotlight this post!
Unread 04-01-2009, 22:25
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
The fan on top pushing the robot down is definitly a question for the Q&A... While technically the fan would not be changing the traction, only the Normal Force, and thus the friction, it does get into the whole "lawering the rules" that is frowned apon. If they say we can do it in the Q&A then most certainly go crazy! But until then, it is kind of a dicey issue...
  #35   Spotlight this post!
Unread 04-01-2009, 22:27
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
I have to disagree. I dont see how it is against the spirit of the rules at all. The rule said you had to use the stoke wheels to support the robot, but says nothing about how those wheels have to be propelled. With fans, the wheels are the only thing in contact with the floor and that is 100% in the spirit of the rule.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
  #36   Spotlight this post!
Unread 04-01-2009, 22:30
AKA: Ellen McIsaac
Oh, I think you misinterpreted me. The original idea of the thread, posted by Don Rotolo, with fans propelling the robot horizontally, sounds completely in the spirit of the rules. The idea of using fans in the vertical direction to increase traction sounds against the spirit of the rules. I think we really do agree.
Ellen McIsaac
  #37   Spotlight this post!
Unread 04-01-2009, 22:36
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
First of all, there are a lot of great ideas here. Thanks, Don!
Second, the idea of using a fan for downforce (either blowing down from above or creating a partial vacuum below) is Q&A material, but here's my opinion anyway: I think it's legal, as it doesn't change the traction devices - the wheels - but improves their ability to grip. The last sentence in R06 is pretty clear on its intent:
The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game
- Steve
  #38   Spotlight this post!
Unread 04-01-2009, 22:43
hipsterjr's Avatar
AKA: CJ
To SmurfGirl, I'm sorry, I did misinterpret you. I think using a fan vertically is still legal, but a little useless. Think of all the wasted space (if you wanted an efficient fan) and energy you would sacrifice! Why not just add weight bars!?
  #39   Spotlight this post!
Unread 04-01-2009, 22:46
foote stepped in
AKA: E. Foote
FRC #0868
Originally Posted by RogerHebert View Post
There is <R06> which states "No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted."
<R06>ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted.
A giant fan on top does not contact the ARENA, it's still the ROVER WHEELS. The other forms of traction are things other than the wheels that contact the ARENA.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
  #40   Spotlight this post!
Unread 04-01-2009, 22:47
chmp09 chmp09 is offline
AKA: Marc Pulte
FRC #1702 (Robocubs)
chmp09 is a jewel in the roughchmp09 is a jewel in the roughchmp09 is a jewel in the rough
I don't think that you could use a fan as an effective defense. The shape of the game piece does not make it very resistant to air. Its also kinda heavy, not that heavy, but heavy enough to make it hard to stop.
  #41   Spotlight this post!
Unread 04-01-2009, 22:54
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Don, you are psychic. I hope to see lots of great and waaaay out of the norm ideas coming into play for this game. There may very well be some classy, Newton-era type devices on display this year.
  #42   Spotlight this post!
Unread 04-01-2009, 23:03
For those of you saying that a downforce would be legal:
I'm 99% sure that it's not legal. The wording in the rule is clear: if it increases traction, it's not legal. The idea is to increase the normal force, which increases available frictional force (not friction), which increases traction. That's increasing traction, which is illegal.
The other 1% says to ask Q&A when it comes online and see what they say.
  #43   Spotlight this post!
Unread 04-01-2009, 23:05
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
a prediction: true or false.
"the use of a fan to increase the downward force the robot exerts on the floor will not be allowed if it exceeds 120 lb force."
you could weight or blow yourself downward up to 120 lb force. weight don't use batteries.
But the idea of using fans for horizontal propulsion even though that sounds cool would be noisy beyond description. It would bring the discussion on OSHA noise levels to a whole new level. It would create havoc on the noise front.
Ed Barker
  #44   Spotlight this post!
Unread 04-01-2009, 23:07
The Pre's Avatar
The Pre The Pre is offline
College kid who cant quit FIRST
AKA: JP
FRC #1652 (LakeView Legends)
The Pre will become famous soon enough
Send a message via ICQ to The Pre Send a message via AIM to The Pre Send a message via MSN to The Pre
i really wana see someone build a hovercraft or swamp boat
definitely going to be a great year
i think it would be legal (vert or horiz fan orientation) but i think Q&A would be a great way to figure it out
  #45   Spotlight this post!
Unread 04-01-2009, 23:25
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
I think the biggest problem with using a fan to propel a robot is safety. It takes a bit of work to get an FRC bot moving, and with a fan that sould mean moving as much air as possible as quickly as possible. This presents very real dangers to anyone near the field when debris on the field (or even a grain of sand) is blown into their face or body. It's a great idea, but too risky to everyone involved.
pic: Hey who's that driving the robot? Koko Ed Extra Discussion 10 24-03-2006 05:17
Driving omni-directional wheels VanZuiden General Forum 4 19-01-2006 22:59
Wheels & Driving Ryan Curry General Forum 3 13-01-2002 21:43
Heres a big problem that I think Discreet does not know what they are talking about. wes16zeus 3D Animation and Competition 9 09-01-2002 23:31
