Go to Post Ask two different FIRSTers for an opinion, get three different answers! - pfreivald [more]
Unread 04-01-2009, 21:59
dtengineering's Avatar
AKA: Jason Brett
Round Belting - Solid vs. Hollow, Polycord vs. McMaster
I was admiring some of the robots in the 2006 "Behind the Design" book, and noticed that round belting was commonly used in some of the nicer ball handling mechanisms. Team 121 specifically referred to using Polycord belting material.
Searching back through CD (yes... I do search before I post!) I found this thread as the best reference but it was a bit out of date and didn't quite answer the questions I had, so:
1) McMaster Lists both solid core (you join it by welding the ends) and hollow core (you use a barbed insert) round belting material. The hollow costs a little more, but should be easier to join. There is a welding kit for the solid stuff, but it is expensive, and it should be possible to rig something similar at home. Does anyone have sufficient experience with both the solid and hollow core belt to recommend one over the other? Is it as easy to rig up a welding set up for the solid core stuff as it looks like it should be?
2) The McMaster belt material runs about $1.00/ft (more for hollow, less for solid) in the 1/4" size. Smallparts.com lists similar sized Polycord for $4.20/ft (when buying 10 foot lengths). Has anyone experimented with this enough to compare it to McMaster's offerings?
Thanks,
Jason
Incidentally, if you're stuck for ideas on how to play this year's game, you could do worse than read the Behind the Design book. There are some great ball-handling ideas in there.
Unread 04-01-2009, 22:41
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Round Belting - Solid vs. Hollow, Polycord vs. McMaster
Don't waste $500 on the McMaster "welding kit"; the solid core polycord can be welded with just a lighter. Just cut the cord 10% shorter than the actual distance necessary, melt the ends with the lighter, stick them together (use the inside of aluminum angle to keep them lined up), and wait five minutes. Now use a razor and trim off all the globs of melted cord around the joint so it is smooth and wait another half hour to let it cure and achieve full strength.
I've used the McMaster round belting as well as name-brand Polycord from Small Parts. They are pretty much the same, except McMaster ships a lot faster. Just watch out: the endless belts offered by McMaster are nice in the fact that they already come preset to the length you want, however they are a lot more expensive per foot to buy (0.25" continuous belt is about 4x more expensive per foot than plain belting).
// Also, for anyone else who may be reading this thread: if you want to purchase polycord material from McMaster, don't search for polycord, as this will only bring up one result. Search for round belting to get the whole list of hollow and solid core belting in the various colors (green, orange, clear).
Art Dutra IV
世上无难事,只怕有心人.
Unread 04-01-2009, 22:46
AdamHeard's Avatar
Lead Mentor
What is the advantage of polycord over urethane round belt?
Unread 04-01-2009, 22:51
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
I have bought poly cord in the past but we didn't put it on a 'production' robot.
During AimHigh a girl on a team from Florida showed me how to weld it. She used a lighter and heated the ends and pressed the ends together and clamped it. I cannot remember the setup hold times but if you setup a jig it should go easy.
Also the cord is designed to have a certain amount of tension so you need to figure out how long you really want it then make the cables and then mount them. Think of them as tough rubber bands.
If you know someone that has a nice sheet fed Heidleberg press you can probably some some of this stuff in action.
I'm gonna run on a little more while I'm here.
FYI - we may make a conveyer out of timing belt, probably the XL size, and use plastic pulleys scattered across a drive shaft will filler between the pulleys. the filler will be turned down the the inner pitch diameter of the pulley. plastic pulleys are cheap and you can get them with single, double, and no flange.
timing belt is made in large tubes then is sliced like a giant salami.
you can go buy any width timing belt you want if you order it from www.econobelt.com or www.sdp-si.com , for example 2 foot wide if you like. There are whole families of standard length.
and the belts don't need to be as wide as a moon rock, only wide enough to touch the crown.
and similiar to the timing belt, you can get flat belt (un-timing belt).
right after we shipped aim high robot I went to a Harley Davidson bike ralley and saw some custom bikes with 4 inch wide belts driving between the engine and wheel. It was totally cool looking and had graphics imprinted onto the belt.
does anyone know how to do the printing ?
Ed Barker
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
In 2006 in fact, our robot actually used the belting for our ball gatherer system. This is what I found:
We initially had some of the solid core stuff laying around, so we used it... it was actually pretty difficult to melt though. We used a heat gun to melt the edges and pushed them together and waited for them to dry. The resulting seem was strong, but it was difficult to make, and it required testing to find out how much the joint would shrink/grow from the original cut of the material. We later used the hollow core belts with the barbs. To me this seemed a lot easier. The barbs are simple enough to use, and they allow your loop to be the exact size as the length you cut. We never had a barb pull out in competition, and they were just as strong if not stronger as our weld joints (of course this might have been due to shoddy welding). unless the belting is making particularly tight turns, the barbs should not necessarily be a problem.
Hint for using either type: make your loop first, THEN try looping it around where you need it... I made the mistake of trying to stretch it into place and assemble it my first time... Dont make fun of me, I was a freshman!!
Unread 04-01-2009, 22:53
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I would agree with Arthur, don't waste your time with the hollow core. I think i did all the polycord for 610's 06 bot in like an hour by melting the ends with a one of those small table top heaters (melting the material on a piece of AL placed on top of the heater as to not ruin the heater) and then stuck them together and trimmed the excess with a exacto-knife. Polycord make belting systems really easy to put together, not tight enough just cut a bit off and reattach.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 04-01-2009, 23:29
AKA: Jason Brett
Thanks to everyone for the helpful replies. For 1/4" belting the solid core at McMaster is $.90/ft and the hollow is $1.22/ft. It sounds like we can't go wrong by getting either of them, and it is pretty apparent that the custom welding set up won't be needed.
As for the brand-name polycord at smallparts... well... it doesn't sound like the 400% increase in price ($4.20 in 10' lengths) is worth it.
And the tips on the wide belting from econobelt are good too.
Thanks to all,
Jason
Unread 06-01-2009, 06:16
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
But when cutting the polycord, make sure you cut at a 45 degree angle. Creates a MUCH stronger bond when melting the ends together.
Good luck!
FRC78: 2010-Present
FRC121: 2002-2009
Unread 08-01-2009, 02:37
Woodworker88 Woodworker88 is offline
Shop Rat
AKA: Michael Fagan
FRC #0190 (Gompei and the H.E.R.D), FRC #0114 (Eagle Strike)
Woodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the rough
Polycord is a brand name of Habasit for their urethane round belt product. They are the same material.
Unread 08-01-2009, 09:17
Brandon Holley's Avatar
We used the namebrand polycord in our 2006 bot. Just melt the ends and stick and you have a solid connection. We did not break one belt through the entire season. However, from what I've heard you dont need the name brand stuff. Its cheap enough that you can buy a few different types from mcmaster to see whats best for you.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 09-01-2009, 16:54
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
I am not sure if this Dayton Urethane Round Belt is the same quality as mcmaster. But this company has more specifications about the different types of belts (its roughly the same price).
http://www.drillspot.com/products/42...YV9_Round_Belt
What do most people suggest in terms of texture of the belt ?
Orange = Smooth (hardness = Shore A 90)
Green = Rough
Clear = Smooth (hardness = Shore A 80)
What's the difference between clear & orange, mainly hardness ?
How does hardness affect ball collecting ability?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 09-01-2009, 17:35
AdamHeard's Avatar
Lead Mentor
Green = Rough
I would say hardness affects how grippy it is. Shore A is still decently grippy, a colson wheel is 65 A for reference. I imagine if it was too soft, and in the 30-65 range like banebots/colson wheels (just as a reference), it would wear too quick and be too weak.
Unread 09-01-2009, 17:40
CraigHickman
Posts: n/a
Green = Rough
To put things in perspective, the average longboard wheel is between 70a and 81a. An average skateboard wheel is between 90a and 98a, depending on the brand.
Unread 09-01-2009, 22:24
run the trap!!!
Team Role: Human Player
We have some of that green polycord stuff lying around...
We've never used it, it doesn't look like it could apply sufficient grip to lift the balls.
Has anyone tested it out on the balls?
We've always used neoprene o-rings from mcmaster. They'll only last the season before falling apart, but they have tremendous grip and are very strong.
-Philip J. Fry
Unread 11-01-2009, 13:19
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
So I've been searching for these on McMaster, and I've narrowed it down to 3 colors. One of these colors (green) has a larger minimum pulley diameter than the other two. Aside from obviously needing to use a larger pulley, what does this mean about the belt itself? Someone mentioned that the green was more rough than the other colors, it also happens to be the one that needs a larger pulley. Is this because it is more rough?
I also just noticed that the green stuff is $5.40 per foot as opposed to the other ones that are $.99 per foot.
Mens et Manus
Hollow Shaft optical encoders magical hands Control System 2 24-03-2005 09:12
Hollow Shaft optical encoders magical hands Robotics Education and Curriculum 0 03-02-2005 22:56
Polycord Belting Claires4sorrow Technical Discussion 1 31-01-2004 13:37
solid edge solid works ceileachair Inventor 1 21-01-2003 22:03
HELP! ChiefDelphi needs Green 1/4" polycord! Brandon Martus General Forum 1 14-03-2002 19:25
