Go to Post I was hoping they'd be selling robots. - Tristan Lall [more]
  #46   Spotlight this post!
Unread 04-01-2009, 13:25
sbrumund sbrumund is offline
FRC #2115 (M cubed)
sbrumund is an unknown quantity at this point
Re: The Game Floor
Based on simple physics principals the friction force is independant of the area.
In reality it may and will be quite different.
If the surface has a slight texture to it there may be an advantage to fiewer wheels. The wheels look like last years kit wheels which have a soft surface compound. With sufficient weight on the wheel the compound will conform to any irregularities in the surface giving you additional traction.
The real question is how much weight is needed per wheel to obtain the optimal compound deformation and the most traction.
If you have a skid steer 4 or 6 wheel drive system you need to generate enough force to slide wheels sideways. Skid steer systems in general do work well on ice becuuse you are limiting your self to kinetic friction which is very low.
Think of a car on ice. As long as you accelerate and turn slowly you remain in control because static friction dominates.
If you slam on your breaks, accelereate fast or turn to quickly all you have is kinetic friction, newtons first law takes over and inertia is the driver.
This surface does seem to give a decided advantage the the established teams with four wheel drive systems that steer each wheel. These are complex drive systems that require a lot of programming and are difficlult to design and debug in 6 weeks.
  #47   Spotlight this post!
Unread 04-01-2009, 13:29
germanystudent's Avatar
germanystudent germanystudent is offline
Trashed and Scattered
AKA: Everett
FRC #2865 (Roboteknix)
germanystudent has a spectacular aura aboutgermanystudent has a spectacular aura aboutgermanystudent has a spectacular aura about
Send a message via MSN to germanystudent
Re: The Game Floor
when dean's bot collided with the other one, it looked just like some of the ice collisions up here in north Idaho... so some tips for ice driving:
1) start slow, otherwise you'll peel out,
2) controlled drifting can stop you faster occasionally
3) anti-lock breaks are your beast friend, or just decreasing speed first
4) more weight does mean more friction, but also you take a LOT longer to stop
5) try to get practice on ice if you have it near where you live.
i just wish that ice rink here in town had a stronger roof... it collapsed under the snow...
Nobody leaves my reality without a note from their mother!
  #48   Spotlight this post!
Unread 04-01-2009, 14:25
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: The Game Floor
The attached photo was posted by our friends at The Blue Alliance Kickoff 2009 on Flickr.
The picture leaves no doubt that the pebbled-surface Glasliner is the "right stuff"...
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
  #49   Spotlight this post!
Unread 04-01-2009, 18:25
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: The Game Floor
They are not the same as last year's kit wheels. The wheels this year have a very hard surface that does not conform at all.
  #50   Spotlight this post!
Unread 04-01-2009, 18:39
Olde Bill Olde Bill is offline
AKA: Bill Holtby
#1006 (FAST EDDIE & The Rebels)
Olde Bill will become famous soon enough
Re: The Game Floor
From the photos and the section of the manual dealing with field layout and marking, I'd guess that they're using Glasliner FRP Basement Liner (8' width rather than standard 4') with fibre-glass tape on the seams. Much easier for field set-up. Is it on top of carpet? At 0.060" thickness, could be very sensitive to the surface it's laying on.
Time flies like an arrow but fruit flies like a banana,
Olde Bill
Ex Obscuritate At Lucem
  #51   Spotlight this post!
Unread 04-01-2009, 18:58
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Re: The Game Floor
I'm assuming they will be using these laminated panels as the floor covering:
http://www.glasteel.com/ingles/Detal...1262_1285.html
Any ideas where these panels can be purchased locally???
  #52   Spotlight this post!
Unread 04-01-2009, 19:00
GillSt.Bernards's Avatar
GillSt.Bernards GillSt.Bernards is offline
AKA: Amanda Cullen
FRC #2458 (Team Chaos)
GillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to all
Send a message via AIM to GillSt.Bernards
Re: The Game Floor
The surface can also be found at most Lowes and Home Depot stores
  #53   Spotlight this post!
Unread 04-01-2009, 19:06
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
Re: The Game Floor
Its been a long time since I have posted on here, I been out of robotics for about 4 years now. Just busy with work. Hopefully getting in involved with my old team this year.... anyway
I am so happy they changed the floor. I was wanting them to change the floor since I was a Member back in 2003. Good luck to all
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
  #54   Spotlight this post!
Unread 04-01-2009, 22:50
heybhaven heybhaven is offline
FRC #3045
heybhaven is an unknown quantity at this point
Buying Regolith
Does anyone know where you could buy or order Regolith?
  #55   Spotlight this post!
Unread 04-01-2009, 22:56
Ellery's Avatar Unsung FIRST Hero
Ellery Ellery is offline
Working on my 10 month old robot...
AKA: Ellery
no team (X-CATS - on Sabbatical)
Ellery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond repute
Send a message via AIM to Ellery Send a message via Yahoo to Ellery
Re: Buying Regolith
FYI there's already a thread on this - Please search for Glasliner FRP per the manual. People have gottem them at HomeDepot and lowes
Xerox Sr. Systems Engineer
Other jobs: Retired X-CATS Team Leader, Inaugural FLR MC and plain ol' nice guy
Team# 191 X-CATS - Est.1992 (www.x-cats.org)
"We don't just build robots we build people..."
  #56   Spotlight this post!
Unread 04-01-2009, 23:00
FRC #3045
Re: Buying Regolith
So u can find it at home depot or lowes?
  #57   Spotlight this post!
Unread 04-01-2009, 23:05
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: The Game Floor
Menards just put these panels on sale starting today thru 1/18/08 if I remember right for about $24
-Mike AA
  #58   Spotlight this post!
Unread 04-01-2009, 23:44
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
Re: Buying Regolith
I found a similar material at Home Depot. The only difference is that it's not the GlasLiner brand. It's still the FRP .09", fiberglass sheet. Of course I would definitely be able to confirm this if FIRST included a sample in the KOP.
$27 for a 4x8 sheet
  #59   Spotlight this post!
Unread 04-01-2009, 23:46
clark_noah's Avatar
clark_noah clark_noah is offline
FRC #1245
clark_noah has a spectacular aura aboutclark_noah has a spectacular aura aboutclark_noah has a spectacular aura about
Re: Buying Regolith
I know! I wish FIRST would have given us some of this stuff.... oh well...
  #60   Spotlight this post!
Unread 04-01-2009, 23:49
cbudrecki's Avatar
Re: Buying Regolith
even just a 6"x6" square would have been fine, just so people who couldn't make it to NH could see exactly what it was! the most important game piece this year, and no sample!!!
174 gets off the floor Tetraman Robot Showcase 9 25-02-2008 17:04
Are the goals bolted to the floor? Leav Rules/Strategy 1 11-01-2005 03:31
Robots Hanging from the Floor Todd Derbyshire Rules/Strategy 16 13-01-2004 14:10
Height of the box stack from the floor tenfour General Forum 4 07-01-2003 10:26
Conduit on the floor Kyle Fenton General Forum 2 06-01-2002 14:49
