Go to Post They call us super nerds. I say thank you :D - Gregor [more]
Unread 04-01-2009, 22:28
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Commets on these drive trains
i came up with these ideas to present to my team tomorrow any commets on them would be appreciated.
the first idea is a air boat type drive train where a giant fan would drive the robot. Then servo powered flaps would direct the air flow for steering. All this would be on caster wheels.
the second idea is kind of like a snowmobile. in the back there is a mini tank drive that would drive the robot. in the front is 2 swerve wheels that would be used to steer the robot. or the tank drive could do the steering and the swerve wheels would just be casters.
ID:	7073  Click image for larger version
ID:	7074  Click image for larger version
ID:	7075  Click image for larger version
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 04-01-2009, 23:49
dtengineering's Avatar
AKA: Jason Brett
Re: Commets on these drive trains
There are lots of possibilities for fans to be used in this game. You should be able, as part of your presentation to your team, however, to be able to estimate how much thrust your fan could develop. The power available to your robot is similar to that available to many radio control airplanes, so you might want to look around in some RC forums for software or empirical data to help you estimate how much thrust you might get. I would suggest that you not ignore the 9 pounds of tractive force that you can get from driving the wheels.
In the second design you probably don't want to leave the front wheels undriven. Depending on where your centre of gravity is you may be giving up 1/3 or more of your robot's pushing/turning abilities.
Jason
Unread 05-01-2009, 00:04
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
Remember you have a trailer attached behind you. All the air your blowing backwards will hit the poles (and balls), reducing your thrust.
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 05-01-2009, 00:08
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
that is what i have been saying as well.
295 Team Captain
Unread 05-01-2009, 00:17
Elgin Clock's Avatar
FRC #0237 (Black Magic)
It won't only reduce your thrust, it will push against something that is attached to you in the scenario you are thinking of & basically become worthless energy as far as moving is concerned.
HOWEVER, if you have your fan pointed towards the opposite side of the bot that the trailer is attached, & you push a goal around instead of pulling it, it may work.
In theory anyways, with a lot more powerful fan & speed of fan blades that you will be able to use with the provided KOP parts I'm guessing. (Unless you want to build a serious transmission to maximize the output of that fan blade to warp speed, which is certainly possible... I guess, but just remember safety as well when making a huge fan with spinning blades!!)
Btw, your first idea you say "all this would be done on caster wheels".
You can only use the wheels they provide you in the kit & not off the shelf caster wheels, so keep that detail in mind.
Unread 05-01-2009, 00:19
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Yeah, I noticed that too. But after looking at the pictures I think he means a caster style wheel using the kit wheels. They would just be free rotating and not powered.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 05-01-2009, 00:24
The Pre's Avatar
The Pre The Pre is offline
College kid who cant quit FIRST
AKA: JP
FRC #1652 (LakeView Legends)
The Pre will become famous soon enough
Send a message via ICQ to The Pre Send a message via AIM to The Pre Send a message via MSN to The Pre
Propulsion that does not involve driving wheels
this is a HUGE thread talking about fans and how they might be used.. might wana skin through the 4pages of it
enjoy and good luck
~jp
Unread 05-01-2009, 00:25
Cooley744's Avatar
Cooley744 Cooley744 is offline
Cooley744
AKA: Lauren
FRC #0744 (Shark Attack)
Cooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to behold
Send a message via AIM to Cooley744
I may be mistaken, but I think you can hook the trailer onto your robot on any side. So if you put your trailer in the front, the fan would still be an option.
For whatever you do, work at it with all your heart, as working for the Lord, not for men.
Colossians 3:23
Proud graduate and now lead strategy mentor and driving coach for 744 Shark Attack.
Unread 05-01-2009, 00:26
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
I have been brainstorming a two wheel bot. Not just two wheel drive, but 2 wheels total. I realize there will be issues with inspection. But just think about this. The trailer connection only rotates in the horizontal plane so the trailer would provide stability. You would want it to be very close to perfect balance since you do not want to transfer robot weight to the wheels on the trailer. To pass inspection, you could have a third wheel that is about 1/16 in off the ground during competition. Comments?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 05-01-2009, 00:32
nitsua60 nitsua60 is offline
FRC #2785 (Prometheus)
nitsua60 will become famous soon enoughnitsua60 will become famous soon enough
Originally Posted by gburlison View Post
...You would want it to be very close to perfect balance since you do not want to transfer robot weight to the wheels on the trailer....
I might argue that you want it out of balance -- in the opposite direction than you mention -- to take some of the trailer's weight onto the robot wheels. A big theme has been about how to increase the normal force and gain traction....
Unread 05-01-2009, 00:48
So just to make sure I understand your point.
Assume the trailer has a tongue weight of 5 pounds.
Build a two wheel drive bot with a third wheel opposite the trailer and balance the bot such that the third wheel has 5 pounds of weight.
Attach the trailer, then the front wheel has no weight and therefore no traction.
All of the robot weight and the tongue weight of the trailer is now on the two drive wheels.
I am trying to figure out the CONS to this approach.
It seems that pushing the trailer would be more difficult, but since it is going to be difficult anyway I don't think many driver will be pushing unless they have to.
Unread 05-01-2009, 01:14
Build a two wheel drive bot with a third wheel opposite the trailer....
Not just two-wheel drive, but two-wheeled, if you like.
I don't see it so much about tongue weight as about the torque that the clevis (or whatever's pinning the hitch) will sustain.
Imagine a robot. Put a pair of wheels on it and hitch a trailer to it. Move some robot weight as far forward of the wheels as necessary to get the trailer hitch to lock up (there's a barrel pinned into C-channel, and you're trying to rotate it the "wrong" way). Now if you move more weight forward it's not just the tongue weight of the trailer pressing down on your hitch, but rather the weight of the trailer -- like you're actually trying to lift the trailer. I haven't built a trailer, but from kicking across some regolith I might estimate it at 20 lb. At max, you could actually have the whole robot+trailer weight balanced on your two wheels, as long as that pin and C-channel hold.
On the PRO side:
Ironically, by trying to flex the hitch in the "wrong" direction and making it harder to flex in the "right" direction, you might make some maneuvering easier.
You've increased F_n (and everything downstream of it) by ~12%
CON:
Minimal resistance to spinning the whole assembly -- you've both taken load off of the trailer's wheels and eliminated the degree of freedom intended in the hitch.
I don't really think it's worth doing, but I think it's well worth reminding ourselves that mg and F_n are not always synonymous.
Unread 05-01-2009, 10:17
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
The idea of turning the fan around and pushing the trailer will not work, as soon as you try to push forward the trailer will jackknife, you will then be pushing against the trailer wheels, and i don't believe you would have the power to do that in your fan. Even if you did thought, you would be an easy target because whenever you try to move the robot you will be pushing against yourself, essentially the same problem you were avoiding.
Unread 05-01-2009, 20:41
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
I've been working this idea since a student mentioned it. The concept seems sound but until we have a working test chassis (or find some mech e's that know how to model it) I'm uncertain.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Drive Trains neoshaakti Technical Discussion 20 02-04-2008 00:11
Drive Trains-help bookworm2011 Technical Discussion 5 21-12-2007 02:48
VEX Drive Trains 2007 Akash Rastogi VEX 23 13-12-2007 11:06
Drive trains Jared Rillings Rules/Strategy 2 10-01-2007 13:17
Drive Trains?!?!?!!!!! archiver 2001 0 23-06-2002 23:08
