Go to Post Do it the good ol' American way and throw money at the problem. In other words, get out of there and call a professional to take care of it. - sanddrag [more]
  #46   Spotlight this post!
Unread 04-01-2009, 23:34
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Propulsion that does not involve driving wheels
Using a vacuum to create downforce, as long as nothing other than rover wheels are touching the ground should not be illegal or against the spirit of the rules. This would be an innovative solution as you would not be adding anything extra between the physical interaction of the ground and the robot, and as such would not be adding traction. Also the Cof is remaining the same no matter how much downward force is applied, the only thing changing is the normal force which is not friction.
Mentor 2415
  #47   Spotlight this post!
Unread 04-01-2009, 23:42
BigWhiteYeti's Avatar
BigWhiteYeti BigWhiteYeti is offline
FIRST class flier
AKA: Patrick M.
FRC #0857 (Superior Roboworks)
Team Role: Driver
BigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura about
The biggest problem that arises with a slippery floor is the difficulty in precision maneuvering. Large fans or leaf blowers will allow for even less precision than the wheels, so it doesn't really solve anything (it would look cool, though). The only way to increase your stopping distance, turning radius, etc. is to increase your normal force without increasing your mass, as the post above describes. Other than that, your pretty much stuck with the oil slick.
-you're fired
  #48   Spotlight this post!
Unread 04-01-2009, 23:46
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Assuming traction and friction to be synonyms, then anything designed to increase normal force is illegal. Friction is the product of the coefficient of friction and the normal force, so increasing either coefficient of friction (explicitly prohibited by wheel requirements) or increasing normal force will increase traction, which is in violation of R06.
  #49   Spotlight this post!
Unread 05-01-2009, 00:03
FIRST class flier
AKA: Patrick M.
Team Role: Driver
The rule specifically describes ways to change the coefficient of friction like putting rubber on the tires, not changing the normal force. Coefficient of friction is different than friction.
Besides, the only way I can think to change normal force without changing mass is a large fan, which would be impractical and be more pain than its worth.
-you're fired
  #50   Spotlight this post!
Unread 05-01-2009, 00:07
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
hey you can always wear the wheels in such a pattern that it would be really rough and grippy or ad a chemical that would do that
and for propulsion
i have three words pneumatic rocket boosters
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
  #51   Spotlight this post!
Unread 05-01-2009, 00:14
nitsua60 nitsua60 is offline
FRC #2785 (Prometheus)
nitsua60 will become famous soon enoughnitsua60 will become famous soon enough
Another way to increase the normal force: give yourself a nice hydraulic suspension and bounce your way along like an El Camino down the strip -- at the lowest part of the bounce you'll have increased the normal force and can apply more power to the wheels at that time (assuming you don't want your wheels to spin out). Of course, at the top-side of the bounce you've a smaller F_n and can apply less power.
If you don't like how that affects your shooting/tracking/&c., mount ballast (or your batteries, or your control system) on a piston inside your robot and wiggle that up and down to the same effect.
An idea that came over from another thread: an imbalanced two-wheel design. If CoG is forward of wheels so that the trailer (through the hitch) is effectively holding down the back of the robot, then you'll have a higher F_n than solely due to robot weight.
  #52   Spotlight this post!
Unread 05-01-2009, 00:20
You might want to go read <R06> more carefully.
Originally Posted by <R06>
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted. The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads, alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game.
Translation: Your proposed method for more traction is illegal.
  #53   Spotlight this post!
Unread 05-01-2009, 00:24
darkChozo darkChozo is offline
Some guy
darkChozo is an unknown quantity at this point
Have you considered the safety factor of having a fan powerful enough to propel a ~150 pound robot faster than the wheels can? That's going to be quite a lot of wind. Considering that people are usually standing pretty close to the arena, I could easily imagine someone who is already off balance being pushed over and getting hurt by that. Same with light, unsecured equipment, or maybe tablecloths, barriers, etc. that can easily be blown up or away. And that's ignoring the damage that smaller things kicked up by the fan, or even worse, accidentally fed into the fan could do. It's not something I'd want to risk betting on at this point, lest it violate <S01>. I would wait until the Q&A clears things up.
Not to mention, I doubt that the crowd will appreciate being blown upon. Just a thought.
  #54   Spotlight this post!
Unread 05-01-2009, 00:25
AKA: Demolition Man
no im saying those wheels have a concave surface so you make you grind out as much of it as you can
Favorite Phrases:
  #55   Spotlight this post!
Unread 05-01-2009, 00:26
AKA: Demolition Man
yeah with all that force newton says that the robot behind that wind is gonna be pushed around and if you get two or three in a match you wont be able to do anything
Favorite Phrases:
  #56   Spotlight this post!
Unread 05-01-2009, 00:29
Umm... Excuse me? Re-read the bold portion of the rule in my last post. There should be something about altering the surface profile. Grinding down the surface is doing just that.
  #57   Spotlight this post!
Unread 05-01-2009, 00:41
AKA: Demolition Man
no grinding is one thing practicing all everyday with that set of wheels for three weeks is another thing im just saying use the most worn out set of wheels that you have it will give you an edge
Favorite Phrases:
  #58   Spotlight this post!
Unread 05-01-2009, 04:03
Rossetto07 Rossetto07 is offline
FRC #1678
Rossetto07 is an unknown quantity at this point
Originally Posted by computerish View Post
I think RogerHebert is right that you can't use a big fan on top, but what about the idea of pointing a fan (kind of like a leaf blower) over the trailer to deflect balls? Is that legal?
Our team did some tests to see if a leaf blower could deflect an incoming cell, but we had very little success even though the leafblower was significantly stronger than any fan that a 12V CIM could power. The design of the balls just doesn't have enough surface area for them to be affected by air movement.
Too bad.
  #59   Spotlight this post!
Unread 05-01-2009, 08:37
GaryVoshol's Avatar
Cogito ergo arbitro
You could take the robot outside and run it a few laps around the cement parking lot to scuff the wheels too. Just try to pass inspection after that.
(since 2004)
  #60   Spotlight this post!
Unread 05-01-2009, 08:48
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Using the said fan idea is nice, but you would need a skirt to keep an air pillow between the robot and the ground, and to contain the air. This is how current hovercrafts work, and it would provide you with good steering, and manuveurablity, but horrible friction one bump and you would go flying seeing as you have nearly no contact with the ground. Not to mention that you will have trouble picking up balls off the ground, and your skirt will need to be lower then the bumper zone so you can have regulation bumpers.
Is now an engineer thanks to FIRST.
pic: Hey who's that driving the robot? Koko Ed Extra Discussion 10 24-03-2006 05:17
Driving omni-directional wheels VanZuiden General Forum 4 19-01-2006 22:59
Wheels & Driving Ryan Curry General Forum 3 13-01-2002 21:43
Heres a big problem that I think Discreet does not know what they are talking about. wes16zeus 3D Animation and Competition 9 09-01-2002 23:31
